ibutton DS1990R [Solved]
jake1272
PostPosted: Fri Mar 19, 2021 5:53 am     Reply with quote
The compiler is CCS v5.015
The IDE is MPLAB X IDE v5.40
Hi everyone I am working on a simple project with ibutton
I Noted the value of the last byte printed in the terminal
and then I Placed that value in a variable in my program
I want to add a code to light a green LED if the last byte matches
the variable or a red LED if the last byte does not
match.
Here is my try. I can light the green led but not the red. Any suggestions?
#include <16F1847.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,NOMCLR,NOBROWNOUT
#use delay(clock=8000000)
#use rs232(baud=9600,UART1,STREAM=PC)
#define TOUCH_PIN PIN_B0
#include <touch.c>
#define LED PIN_B4
#define LED PIN_B5
short touch_present();
unsigned char touch_read_byte();
unsigned char value;
void main(){
    printf("\nReady to read...");
    unsigned char buffer[8],i;
    char value=0xD5;
    port_b_pullups(0xFF);
while(1){
    printf("\r\nWaiting for a touch device...\r\n");
    while(!touch_present());
    output_low(PIN_B4);
    output_low(PIN_B5);
    if(touch_present()){
        touch_write_byte(0x33);
        for(i=0;i<8;++i) buffer[i]=touch_read_byte();
        printf("Family:%2X ID:",buffer[0]);
        for(i=6;i!=0;--i)printf("%2X",buffer[i]);
        printf("\r\n");
        if(buffer[1]==value)
            output_high(PIN_B5);
        else output_high(PIN_B4);
PostPosted: Fri Mar 19, 2021 8:38 am     Reply with quote
here's one possible problem..
#define LED PIN_B4
#define LED PIN_B5
I assume you meant to define
#define RED_LED PIN_B4
#define GRN_LED PIN_B5
or maybe
#define GRN_LED PIN_B4
#define RED_LED PIN_B5
also for test purposes, you should print out the value of 'value' along with the Ibutton data. That way you can SEE the data.
bkamen
Re: ibutton DS1990R
PostPosted: Sat Mar 20, 2021 3:19 am     Reply with quote
jake1272 wrote:
#define LED PIN_B4
#define LED PIN_B5
Yea -- definitely having LED defined twice is a no-go.
jake1272
PostPosted: Wed Mar 24, 2021 1:23 pm     Reply with quote
Thanks. It is working now Very Happy
bkamen
PostPosted: Wed Mar 24, 2021 2:21 pm     Reply with quote
Excellent.
Make sure to go to the original message of your thread and edit the subject to include [SOLVED] so it shows up in the forum list as such for other readers.
Smile
