This code works fine on a dsPIC30F3012. But not on the 3011.
Is it on a different location on the 3011 ? I search through the datasheet but could not find the answer.
I am using compiler PCWHD Version 5.091
Thank you for any help.
RNR
Posted: Tue Mar 09, 2021 2:14 am
Look on page 3 of the pdf below. This pdf covers the 3011.
It shows the Unit ID area is at 0x8005C0.
Look at section 6.7 on page 21. It says a Bulk Erase will not erase
the Unit ID area. So potentially it could be a problem with your programmer
firmware.
How do you know the ID was written correctly ?
You could have the compiler read it with:
value = getenv("ID");
RNR107
Posted: Tue Mar 09, 2021 3:47 am
Ha.... OK
In that case, I know why it doesn't work.
I have a bootloader on this PIC, therefore it doesn't get erased properly...
