Which file to load in microcontroller
silent_killer
PostPosted: Mon Dec 14, 2020 9:01 am     Reply with quote
Hi guys
I want to know if i write a program and want to give a file to other user to load it into microcontroller, then which file i should give to him so that he have not the source code but only hex file ?
After compile the program following files appears in folder:
C source file (6KB)
C object file (28KB)
ERR File (1KB)
ESYM File (12KB)
C object file (3KB)
C Output file (20KB)
C Output file (2KB)
C Output file (3KB)
C Output file (2KB)
PostPosted: Mon Dec 14, 2020 10:48 am     Reply with quote
programname.hex
silent_killer
PostPosted: Mon Dec 14, 2020 11:40 am     Reply with quote
temtronic there is no file with .hex extension
PostPosted: Mon Dec 14, 2020 12:18 pm     Reply with quote
You have probably got your explorer set to not display extensions....
Right click on each of the ones described as 'C output file'. Select 'Properties'.
It'll then give the path and full filename actually involved.
PostPosted: Mon Dec 14, 2020 2:04 pm     Reply with quote
You have no .LST file and no .HEX file. This means you have errors in
your program and it didn't do a successful build. Fix all the errors and
recompile. Then you will see the .HEX file.
silent_killer
PostPosted: Wed Dec 16, 2020 3:02 am     Reply with quote
Thanks Ttelmah i checked each C output File and hex file was in one of them.
PCM Programmer there was no error in the code. only format of the files was not showing.
Thanks alot
