bme 280 problem? HOW CAN I READ TEMP OR PRESSURE VALUE?
Goto page Previous  1, 2
jaka
PostPosted: Wed Nov 04, 2020 10:24 am     Reply with quote
I just tested to compile the bme280.c driver with 877a. You need to add #separate directives to either _bme280_compensate_P_int32() or _bme280_compensate_H_int32() functions, or both.
Like this:
#separate
static unsigned int32 _bme280_compensate_P_int32(signed int32 adc_P)
It compiles without errors and consumes 48% of ROM on 877A. Tried with compiler 5.076.
akay
PostPosted: Wed Nov 04, 2020 12:53 pm     Reply with quote
Thank you for your valuable comments my friend.
akay
PostPosted: Wed Nov 04, 2020 1:02 pm     Reply with quote
Like this:
#separate
My friend first of all thank you.. Could you pls send me your compile code?
akay
PostPosted: Wed Nov 04, 2020 1:45 pm     Reply with quote
It's work but my sensor is ''gy-bme280-3.3''. i2c address 0x77 when connect the SDO to Vcc to select i2c 0x77. I changed to i2c address of driver but it not work.
PostPosted: Wed Nov 04, 2020 6:29 pm     Reply with quote
Those are 7-bit i2c addresses. CCS uses 8-bit addresses.
Multiply them by 2 to convert them to 8-bit:
0x76 x 2 = 0xEC
0x77 x 2 = 0xEE
akay
PostPosted: Thu Nov 05, 2020 5:14 am     Reply with quote
0x76 x 2 = 0xEC
0x77 x 2 = 0xEE
I don't understand. What can i do? Could you pls explain inside to program.
PostPosted: Thu Nov 05, 2020 5:19 am     Reply with quote
You said you had changed the BME280_I2C_ADDRESS. The point is this needs
to be 0xEC for a bme280 (7bit) address of 0x76, or 0xEE for a bme280
address of 77.
0x76 & 77, won't work. The address needs to be translated to 8bit format.
The 7bit address *2.
akay
PostPosted: Thu Nov 05, 2020 10:43 am     Reply with quote
address of 77.
so how can i translate to 8bit format.. i dont know how can i do?
newguy
PostPosted: Thu Nov 05, 2020 10:48 am     Reply with quote
address of 77.
He told you how: multiply the 7 bit address by 2.
Page 2 of 2
