Installing PCB Compiler To Work With PCW
Regular Guy
PostPosted: Sat Oct 24, 2020 7:36 pm     Reply with quote
Our PCW is installed in a separate directory from other CCS compilers.
PICC 4 directory.
This PCW is an Evaluation edition that supports 16F877 and 18F252 PIC's only.
How do we install the PCB to work within PCW please?
Our PCB is the command line version. No Windows IDE.
PIC Hobbyist
PostPosted: Sun Oct 25, 2020 1:22 am     Reply with quote
You don't.
You have an evaluation copy of PCW. This is limited to work with the
evaluation compiler.
PostPosted: Sun Oct 25, 2020 1:45 am     Reply with quote
Use MPLAB vs. 8.92 as the IDE for the PCB compiler.
Download MPLAB vs. 8.92:
http://ww1.microchip.com/downloads/en/DeviceDoc/MPLAB_IDE_8_92.zip
Download the CCS plugin for MPLAB vs. 8.92:
http://www.ccsinfo.com/downloads/setup_mplab_plugin.exe
How to use CCS command line compilers with MPLAB vs. 8.92:
https://www.ccsinfo.com/faq.php?page=ccs_mplab
To get a programmer that works with it, buy a cheap Pickit 3 clone. Example:
https://www.ebay.com/itm/PICKit3-Microchip-Programmer-w-USB-cable-wires-Pic-Kit-3/331941067077
