Is "else" always necessary?
ressas
PostPosted: Fri Oct 09, 2020 6:34 am     Reply with quote
Hi.
When I use if in the program, do I have to use else after it?
While checking any button or condition checking
if(input(pin_b0))
output_high(pin_D0);
//else ????
if(hsEnable>3)
hsOut = 0;
//else ???
PostPosted: Fri Oct 09, 2020 6:42 am     Reply with quote
Usually yes...
Consider your code example:
if(input(pin_b0))
The first time this test is made, and if true, the pin goes high
it will stay high forever unless your code 'elsewhere' resets the pin.
If you want the output pin to 'follow' or 'mimic' the input pin, you'll need the 'else' half of the IF statement.
Others can probably explain it better...
Jay
ressas
PostPosted: Fri Oct 09, 2020 10:29 am     Reply with quote
temtronic wrote:
usually yes...
consider your code example
if(input(pin_b0))
the first time this test is made, and if true, the pin goes high
if you want the output pin to 'follow' or 'mimic' the input pin, you'll need the 'else' half of the IF statement.
Jay
Thanks temtronic.
What you said in the button example makes sense. However, is it also necessary for the variable? When the HSENABLE variable in the example is less than 3, I don't want to do anything. Then?
PostPosted: Fri Oct 09, 2020 10:41 am     Reply with quote
re:
if(hsEnable>3)
hsOut = 0;
In this code,
the FIRST time hsEnable = 4, 5,6,....
then hsOut will be set ot 0.
AND stay there, forever.
It will not be changed to say 255 or 3 or 1, whenever hsEnable <4.
Jay
dluu13
PostPosted: Fri Oct 09, 2020 2:39 pm     Reply with quote
It's not strictly necessary. For example, if you want to do some kind of action where your else statement basically says "do nothing", then you can just not put anything after the "if" statement.
However, for my own sake, I usually prefer to do this in order to remind myself that I purposely want no action if my condition is not satisfied:
if (stmt)
   // do stuff
else {}
PostPosted: Fri Oct 09, 2020 3:17 pm     Reply with quote
The problem with not specifying an 'else', action is that once the if (condition) is met and 'something is set or done, it will NOT be reset or undone.
In his first test, when the input pin B0 is high, the D0 pin gets sets high and stays high forever, even when the input pin goes low.
dluu13
PostPosted: Fri Oct 09, 2020 3:51 pm     Reply with quote
temtronic wrote:
the problem with not specifying an 'else', action is that once the if (condition) is met and 'something is set or done, it will NOT be reset or undone.
Yes in his case it's probably a good idea. But that's why I said it's not strictly necessary. In my example maybe you'd just increment a counter or something.
PostPosted: Fri Oct 09, 2020 11:56 pm     Reply with quote
Exactly.
It is perfectly reasonable to have a set of operations that you want to
occur 'if' a set of conditions are met, with no need for an 'else'.
However in probably 90% of situations, there will be 'other things' that
have to happen if the conditions are not met, and in this case an 'else'
is the way to go.
Draw out the situations:
Condition met, needs to do xxxxx.
Condition not met needs to do yyyyy.
If there is nothing in the 'yyyyy' section, then no 'else' is wanted or needed.
asmallri
PostPosted: Mon Oct 12, 2020 1:33 am     Reply with quote
Ttelmah wrote:
Exactly.
is the way to go.
It's a personal programming style thing. In my own case, the 90% is the other way around. Most of the time there are no else statements.
For example:
// msg is a pointer to some prebuilt string.
if (RadioActive)
         SendMessage(msg, Radio);
if (ConsoleActive)
        SendMessage(msg, Console);
if (LoggingActive)
        LogData(msg);
There is no "else" execution required in this scenario
Regards, Andrew
PostPosted: Mon Oct 12, 2020 3:38 am     Reply with quote
I must admit for my customers, there would have to be handling to
ensure that if none of the outputs were 'active', some form of emergency
reporting was done.
PostPosted: Mon Oct 12, 2020 4:57 am     Reply with quote
re:
if (RadioActive)
Question. Do you reset 'RadioActive' within the called function 'SendMessage(msg, Radio); ' ?
I'm assuming you do, otherwise once 'RadioActive' was set, you'd always call the 'sendmsg' function. I've been caught in that 'trap' a few times...
Sad
Now I always reset the 'flag' on the FIRST line of the called function, well mostly....
Jay
asmallri
PostPosted: Mon Oct 12, 2020 6:04 am     Reply with quote
No. These values are set in the initialisation logic during the hardware and configuration phase. Is there are Radio plugged in? If so use it etc
Regards, Andrew
jeremiah
PostPosted: Mon Oct 12, 2020 6:32 am     Reply with quote
For example:
if (RadioActive)
if (ConsoleActive)
if (LoggingActive)
        LogData(msg);
I am in a similar boat (though not 90/10...more like 70/30). Most of my code ends up being validation, and using if's without else's is a much cleaner method for me as it sets up a type invariant pattern to work with. I'm often times working through a list of invariants at the beginning of a function so that when I get to the bottom of my function and start doing math or whatever logic, I know that the data types I am using are safe to use within that context:
if(error_condition1){
   return error_code1;
if(error_condition2){
   return error_code2;
if(error_condition3){
   return error_code3;
if(error_condition4){
   return error_code4;
// now do logic knowing values won't overflow or be in an invalid state
It's really useful for message validation before acting on a command for example. If/else chaining quickly becomes unreadable and a huge maintenance hazard due to how many levels deep it starts to get. Some of it is also personal preference for me as well.
