TCP/IP |
Posted: Mon Feb 16, 2004 8:00 pm |
Can any provide me (or direct me to a web site) a simple implementation of TCP/IP using PIC as the microcontroller.
What I need is a really simple schematic showing a PIC, and other components required and a small workable code (that compiles using CCS) just to show how the TCP/IP is implemented. |
Izolator
Joined: 10 Feb 2004 Posts: 12 Location: Denmark, (Scandinavia-Europe)
Posted: Wed Feb 18, 2004 12:18 pm |
Hi there :-)
I have combined and used the following with great success:
Pic16F877 - Microchip.com
Packet Whacker - edtp.com
EDTP's example:
http://www.edtp.com/download/pw/whacky.exe
Note:
It might take ½hour to figure out what it does/can do, but basicly it is set up for this, amung af few other features:
telnet server / TCP
Echo packet / UDP
Blink led / UDP
Ping / ICMP
I myself didnt have use for the TCP part, only UDP, so I simply removed the telnetserver part, along with all the complex TCP functions.
I think UDP is way easier to figure out.
You will have to decide whether or not to use TCP, UDP or both as per default. |
rwyoung
Posted: Wed Feb 18, 2004 12:24 pm |
Try and find a copy of Bentham's book TCP/IP Lean
Or Jan Axelson's book Embedded Ethernet and Internet Complete: Designing and Programming Small Devices for Networking
I think both are available through Amazon.com and if you are lucky maybe a local bookstore _________________ Rob Young
rnielsen
Posted: Thu Feb 19, 2004 8:24 pm |
Or you could do what I did, and cheat. I used a network module, from www.lantronix.com, called XPORT. It will interface with the PIC via RS232 and take care of communications to the network.
Ronald |
Kieran
Packet Whacker |
Posted: Thu Nov 04, 2004 1:17 pm |
EDTP Packet Whacker
I have one of these hooked up to a 18F452 and have all the demo programs running.
I want to extend the UDP features and I am stuck.
I am trying to send a string back to a PC with the following
triggered by an incomming UDP message from the PC.
Src and Dest are derived from the incoming message.
byte dat_buff[128];
// Src source PORT
// Dest PORT
// *dat string to send
send_UDP(int16 Src, int16 Dest, byte *dat)
int16 package_len;
memset(&packet[UDP_data],0,50); // Flush UDP data section of packet
txlen = strlen(dat) + 8; // UDP data + header len
ip_packet_len = 20 + txlen; // Allow for IP header
// Set IP header up
packet[ip_pktlen] = make8(ip_packet_len,1);
packet[ip_pktlen+1] = make8(ip_packet_len,0);
setipaddrs();
// UDP header
packet[UDP_srcport] = make8(Src,1);
packet[UDP_srcport + 1] = Src;
packet[UDP_destport] = make8(Dest,1);
packet[UDP_destport + 1] = Dest;
printf("send %s len %ld\r",dat,txlen);
packet[UDP_len] = make8(txlen,1); // Should be 0 - buffer size
packet[UDP_len + 1] = txlen;
// Write data to packet
strcpy(&packet[UDP_data],dat);
//calculate the UDP checksum
packet[UDP_cksum] = 0x00;
packet[UDP_cksum+1] = 0x00;
hdr_chksum =0;
hdrlen = 0x08;
addr = &packet[ip_srcaddr];
cksum();
hdr_chksum = hdr_chksum + packet[ip_proto];
hdrlen = 0x02;
addr = &packet[UDP_len];
cksum();
hdrlen = make16(packet[UDP_len],packet[UDP_len+1]);
addr = &packet[UDP_srcport];
cksum();
chksum16= ~(hdr_chksum + ((hdr_chksum & 0xFFFF0000) >> 16));
packet[UDP_cksum] = make8(chksum16,1);
packet[UDP_cksum+1] = make8(chksum16,0);
// Calculate length and send
txlen = ip_packet_len + 14; // total packet len
if(txlen < 60)
txlen = 60;
package_len = txlen + 4;
pageheader[enetpacketLenH] = make8(package_len,1); // ????????
pageheader[enetpacketLenL] = package_len;
dump_header();
show_packet();
data_L = make8(txlen,0);
data_H = make8(txlen,1);
// Data to RTL8019
write_creg(CR,0x22);
write_creg(TPSR,txstart);
write_creg(RSAR0,0x00);
write_creg(RSAR1,0x40);
write_creg(ISR,0xFF);
write_creg(RBCR0,data_L);
write_creg(RBCR1,data_H);
write_creg(CR,0x12);
for(i=0;i<(txlen);++i)
write_creg(RDMAPORT,packet[enetpacketDest0+i]);
byte_read = 0;
while(!bit_test(byte_read,RDC))
read_creg(ISR);
write_creg(TBCR0,txlen - 4);
write_creg(TBCR1,make8(txlen,1));
write_creg(CR,0x24);
Calls and variables are from the packet whacker code.
If I replace the code from below the checksum with the Packet Whacker echo_packet() function then all is well. Any ideas?
Kieran |
