pic16f877a timer
aadsan7
pic16f877a timer
PostPosted: Tue Aug 04, 2020 6:39 am     Reply with quote
Hello Dear,
I have a 1 button if I press 3 seconds than continue to project.
How I can do that ?
Thank you
// 4-Digit digital counter using PIC16F877A
// Common anode 7-segment display
// https://simple-circuit.com/
#include <16F877A.h>
#use delay(crystal=8000000)
short s;                       // Used to know button position
unsigned int digit, digit1, digit10, digit100,digit1000;
unsigned long i = 0;
unsigned int seg(unsigned int num) {
  switch (num) {
    case 0 : return 0xC0;
    case 1 : return 0xF9;
    case 2 : return 0xA4;
    case 3 : return 0xB0;
    case 4 : return 0x99;
    case 5 : return 0x92;
    case 6 : return 0x82;
    case 7 : return 0xF8;
    case 8 : return 0x80;
    case 9 : return 0x90;
void main(){
  while(TRUE){
    if(input(PIN_D0) == 1)
      s = 1;
    if(s == 1) {
      if(input(PIN_D0) == 0) {
       s = 0;
       i++;
       if(i > 9999)
         i = 0;
    digit = i % 10;
    digit1 = seg(digit);
    output_c(0x0F);           // Turn off all displays
    output_b(digit1);         // Send ones digit
    output_c(0x07);           // Turn on display for ones
    delay_ms(2);
    digit = (i / 10) % 10;
    digit10 = seg(digit);
    output_b(digit10);        // Send tens digit
    output_c(0x0B);           // Turn on display for tens
    delay_ms(2);
    digit = (i / 100) % 10;
    digit100 = seg(digit);
    output_b(digit100);       // Send hundreds digit
    output_c(0x0D);           // Turn on display for hundreds
    delay_ms(2);
    digit = (i / 1000) % 10;
    digit1000 = seg(digit);
    output_b(digit1000);      // Send thousands digit
    output_c(0x0E);           // Turn on display for thousands
    delay_ms(2);
PostPosted: Tue Aug 04, 2020 7:39 am     Reply with quote
You can check the CCS manual... !!!
'How do I wait only a specified time for a button press?'
is in the FAQ section.
Slightly modified, it could do what you want...
Jay
PostPosted: Tue Aug 04, 2020 7:53 am     Reply with quote
Or look at previous threads. For example:
<http://www.ccsinfo.com/forum/viewtopic.php?t=58888>
