Problem with driver "can-18xxx8.c"
Uwe Koch
PostPosted: Tue Feb 17, 2004 10:38 am     Reply with quote
Hello together,
I think there is a mistake inside CCS-Can-driver
"can-18xxx8.c". In the function to get the received ID
can_get_ID(...) a problem occurs if extended ID's were used.
The line
ret|=((int32)*ptr & 0xE0) << 18;
try to get the Bits 7..5 of RxBnSIDL and clears Bit4..0.
Up to this point all is OK.
Then these 3-Bits "should be" shifted to Bit 18..20 (16 extended-Bits
+ 2 extended-bits -> 0..17).
But they will be shifted to Bit 23..25 !!!
My suggestion:
ret|=((int32)*ptr & 0xE0) << 13;
Perhaps someone of CCS will take this.
By the way: Is there someone who has changed this driver
for PIC18F6680 (more filters...) ?
Kind regards
Uwe Koch
int32 can_get_id(int * addr, int1 ext) {
int32 ret;
int * ptr;
ret=0;
ptr=addr;
if (ext) {
ret=*ptr; //eidl
ptr--; //eidh
ret|=((int32)*ptr << 8);
ptr--; //sidl
ret|=((int32)*ptr & 0x03) << 16;
// ret|=((int32)*ptr & 0xE0) << 18; CCS-Fehler, die 3-Bits werden zu weit geschoben. Ich vermute die haben gedacht sie würden rechtsbündig im Register stehen(Bit0..2), dann wäre es OK.
ptr--; //sidh
ret|=((int32)*ptr << 21);
PostPosted: Tue Feb 17, 2004 9:53 pm     Reply with quote
My suggestion:
I found the same problem about 2 weeks ago
while testing a board. (Exact same solution, too).
CCS tech support doesn't directly watch this board.
You should send them an email to tell them about
this problem, and your solution. Email it to:
support@ccsinfo.com
