ralph79
modbus domotic |
Posted: Sat May 23, 2020 9:40 am |
hi all,
I have been trying to make a small modbus protocol with one master and several slaves to make a residential home domotic system. But the main issue is that I have to inquire each slave from time to time (around 100/150ms) to know if they have an new order...that is why I rather prefer to have a different approach, eventually and modbus ethernet (so that each slave could acknowledge directly the master, but I don't have the source code for that, is there any one that has it? By the way, is there any other option to accomplish that? I will have one master and around 20/25 slaves... (push buttons and/or outputs)...
Thanks in advance. |
Posted: Sat May 23, 2020 10:29 am |
That is Modbus TCP/IP. Drivers with the compiler.
How old is your compiler?. The basic modbus 'layer' has been with the
compiler for ages, but the TCP drivers needed were updated a while ago.
You would probably need to talk to CCS. There are a number of examples
for the ModBus TCP, that they can supply separately.
Be 'aware', this is quite a bulky/complex driver, compared to the standard
serial Modbus implementation, and you are going to be adding
Ethernet hardware to each board. |
ralph79
Posted: Sat May 23, 2020 2:44 pm |
My compiler has several months... But somehow I don't have the tcp/ip drivers... But for my system I need somehow a solution similar to the tcp/ip modbus... The idea is to have communication only when is needed ( when you press a button for instance), to reduce at most the power consumption... It is not interesting (IMHO) to have domotic and spend a lot of energy to control the system... |
ralph79
Posted: Sat May 23, 2020 2:49 pm |
Is there any other system/protocol to accomplish this?! The idea is to control my house spending the less energy possible... Just for record, I will use bistable relays..and optocoupler entrys... |
Joined: 01 Jul 2010 Posts: 9207 Location: Greensville,Ontario
Posted: Sat May 23, 2020 4:17 pm |
There are several 'systems' that can be used, RS485 is a popular one. Which depends upon amount of data,'points' or slaves, and speed you require. Everyone has their 'favourite'. For a wired system, I still like what I used 30+ years ago, not fast at 24 baud but 99.999999% hackerproof AND can still communicate if a wire is cut or shorted. |
Posted: Sat May 23, 2020 6:47 pm |
ralph79 wrote: |
Look in the Drivers folder. There are several files. Here is one of them:
Quote: | \drivers\modbus_app_layer_tcpip.c 2/12/2015 |
What is you compiler version ? |
ralph79
Posted: Sun May 24, 2020 4:51 am |
Hi temtronic,
When I thought in the "system" I think immediately in the modbus protocol (stable, with several nodes, good baud rates, etc) but when I come in the developing.. I somehow saw that is not good option (besides de tcp/ip module), it is not good programming inquire each 50ms all the 40/60 slaves checking if a push button was pressed... A and according to that send the data to the other 20/30 slaves for toggling one output... It's a spending a lot of energy for nothing... So i rather prefer to use a system that could trigger directly the master when it is needed... The bau rate I would like to use is something thing like 9600bps... |
ralph79
Posted: Sun May 24, 2020 5:10 am |
hi PCM,
I have two versions (5.089) for the newer chips, and an ancient one: 4.140...in the recent one I have the following files: Quote: | modbus_app_layer_tcpip
modbus_phy_layer_tcpip | (both from 12/05/2015)
but i can't find any basic example of it .. I don't like a lot the version 5.089 because I had several problems with some chips (and you all the guys (Ttelmah, temtronic and also allenhuffman here helped me (a lot), finding the problem).. so when is possible I try to use the ancient one..
Is there any basic example of how to use correctly the tcp / ip library? |
Posted: Sun May 24, 2020 7:27 am |
As I said, you have to ask CCS for the examples. They do supply them with
one of their development kits, but have been friendly in the past and
let other users have them. |
ralph79
Posted: Mon May 25, 2020 11:30 am |
Hi Ttelmah,
I have asked for the examples to CCS, untill now, I didn't receive any info.. I will wait a couple of more hours/days... |
newguy
Posted: Mon May 25, 2020 5:44 pm |
ralph79 wrote: | Hi Ttelmah,
Today is a holiday in the US. You should get a response later this week. |
ralph79
Posted: Wed May 27, 2020 11:26 am |
Hi newguy,
In fact I have received the feedback from CCS yesterday. Thanks in advance. |
