PIC24FJ128GA204 SPI
georpo
PIC24FJ128GA204 SPI
PostPosted: Fri May 22, 2020 12:56 am     Reply with quote
Hello!
I am using PIC24FJ128GA204 with SPI but I have some problems.
#include <24FJ128GA204.h>
#fuses HS,NOWDT,DEBUG,NOPROTECT,NOPR,FRC_PLL,OSCIO
#use delay(clock=32M,int)
#pin_select U1TX = PIN_C9
#pin_select U1RX = PIN_C8
#pin_select SDO1 = PIN_B15
#pin_select SCK1OUT = PIN_B13
#pin_select SDI1 = PIN_B12
#use rs232(BAUD=115200,UART1)
#use    fast_io(A)
#use    fast_io(B)
#use    fast_io(C)
#word PORTA=getenv("SFR:PORTA")
#word PORTB=getenv("SFR:PORTB")
#word PORTC=getenv("SFR:PORTC")
#word LATA=getenv("SFR:LATA")
#word LATB=getenv("SFR:LATB")
#word LATC=getenv("SFR:LATC")
#word TRISA=getenv("SFR:TRISA")
#word TRISB=getenv("SFR:TRISB")
#word TRISC=getenv("SFR:TRISC")
#word SPI1BRGL=getenv("SFR:SPI1BRGL")
void Main(){
   TRISA=0b0000000000000000;
   TRISB=0b0001000100000000;
   TRISC=0b0000000100000000;
   LATA=0;
   LATB=0;
   LATC=0;
   setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H);
   SPI1BRGL=0;
   while(1){
     spi_read(85);
    delay_us(100);
The code above works and the SPI clock is according to the SPI1BRGL register.
But if I try this:
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H SPI_CLK_DIV_2);
No matter the SPI_CLK_DIV_ X value, I see no clock output!
Compiler version 5.049
Any ideas?
George.
PostPosted: Fri May 22, 2020 1:01 am     Reply with quote
| 'or' missing in what you post:
Needs to be:
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_2);
Note the extra |
georpo
PostPosted: Fri May 22, 2020 1:11 am     Reply with quote
Yes of course.
I typed the code here as an example and made a typo.
Of course it is:
It does not work.
George.
georpo
PostPosted: Fri May 22, 2020 1:25 am     Reply with quote
Also just for the record this works:
CNPU2|=0x20;            //enable PIN_B9 (CN21) pull-up
This does not work.
SET_PULLUP(PIN_B9);      //enable PIN_B9 (CN21) pull-up
George.
PostPosted: Fri May 22, 2020 1:39 am     Reply with quote
OK.
The reason is simple. Those options don't exist....
If you look at the datasheet for that PIC, it doesn't have a prescaler
option for the SPI. The #defines were removed almost immediately
afterwards (5.053 doesn't have them). The bit patterns being loaded
by the incorrect entries do things like disable the clock output....
You can't use a prescaler on this clock.
The reason is that the chip has a 16bit BRG, so shouldn't need a
prescaler. The people setting up the files at CCS made a mistake
including this option, and realised it soon afterwards.
georpo
PostPosted: Fri May 22, 2020 1:52 am     Reply with quote
As always Ttelmah you know everything and I thank you for this Very Happy
So for my case I should just use the SPI1BRGL register. Right?
George.
PostPosted: Fri May 22, 2020 2:56 am     Reply with quote
Or just use setup_spi.
setup_spi(1000000);
Gives you 1Mbps on the SPI (if the hardware supports it).
Etc. etc., for whatever baud rate you want.
Means you don't have to be working out BRG values yourself.
georpo
PostPosted: Fri May 22, 2020 3:14 am     Reply with quote
This did not work.
George.
PostPosted: Fri May 22, 2020 4:05 am     Reply with quote
Yes, just checked with your compiler, and this makes the same mistake
as for the SPI_CLK_DIV_2. It tried to write a prescaler to the SPI1CON1
register. A couple of versions later, both faults are fixed... Sad
