sebalitter
Interrupt variable type |
Posted: Wed May 20, 2020 7:52 am |
Hi
what kind of variable should i put to toggle between two INTERRUPT types like INT_IOC_A3_H2L and INT_IOC_A5_H2L.
let me explain what i have in mind.
int32 interrupcion = INT_IOC_A3_H2L;
if(toggle_sensors_vcc==1){
interrupcion = (int32)INT_IOC_A5_H2L;
set_timer1(0); // clear timer
clear_interrupt(interrupcion); // Error#51 A numeric expression must appear here ::
cant =0;
while(!interrupt_active(interrupcion) && cant<4000 ){ //same error here
cant++;
ticks = get_timer1();
thank you |
Joined: 01 Jul 2010 Posts: 9169 Location: Greensville,Ontario
Posted: Wed May 20, 2020 8:00 am |
quick answer...
According to the manual the clear_interrupt(...) function requires a CONSTANT not a variable.... so you MUST put the 'name' of the interrupt you're using.
The PIC header file will have a list of available interrupts and their names. |
sebalitter
Posted: Wed May 20, 2020 8:19 am |
temtronic wrote: | quik answer...
Thanks for the answer!
in the header file it says...
_bif void clear_interrupt(int32 interrupt);
_bif int1 interrupt_active(int32 interrupt);
But thats fine, so my solution was this one..
if(toggle_sensors_vcc)
clear_interrupt(INT_IOC_A5_H2L);
clear_interrupt(INT_IOC_A3_H2L); //clear interrupt flag
cant =0;
// wait for CCP1 interrupt. CCP1 will interrupt when PIN_ULTRASONIC_ECHO
// goes low due to CCP_CAPTURE_FE passed to setup_ccp1()
while(!interrupt_active(INT_IOC_A5_H2L) && cant<4000 ){
cant++;
}else{
while(!interrupt_active(INT_IOC_A3_H2L) && cant<4000 ){
cant++;
It should be another improved solution for this. please let me know. |
Posted: Wed May 20, 2020 9:34 am |
Header files normally have this format ...
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL 0xF2C0
#define PERIPH 0xF240
#define INT_RTCC 0x00F220
#define INT_TIMER0 0x00F220
#define INT_TIMER1 0x009D01
#define INT_TIMER2 0x009D02
#define INT_TIMER3 0x00A002
#define INT_EXT_L2H 0x5000F210
#define INT_EXT_H2L 0x6000F210 |
... this is part of the PIC18F46K22.h file |
jeremiah
Posted: Wed May 20, 2020 10:35 am |
sebalitter wrote: | temtronic wrote: | quik answer...
Note that those lines in the header file have the _bif in front of them, that's an annotation meant to indicate that those are just declarations used to help IDE's identify which builtin functions are created by the compiler. Always check versus the compiler manual as some functions are compile time constant only (and the C language does not provide a way to express that, so the function declaration doesn't help there). |
Posted: Wed May 20, 2020 5:39 pm |
there are NO _bifs in the PIC18F46K22.h file tha I use.... |
Posted: Wed May 20, 2020 7:20 pm |
You're using an old compiler version. |
jeremiah
Posted: Wed May 20, 2020 7:38 pm |
temtronic wrote: | there are NO _bifs in the PIC18F46K22.h file tha I use.... |
They added it some time ago...I forget when, sometime after MPLABX v2 because it was highlighting all the CCS functions as undefined (with the syntax highlighter). |
Posted: Thu May 21, 2020 4:23 am |
re: Quote: | You're using an old compiler version. |
yeah, it's old, I'm old, sigh.....
not getting any younger , the older I get
great...now I depressed too ! |
