Hi My name is Leonardo and I having some problems with I2C Comunication I having a PIC16f876 as Master and a 16F877 as Slave 1
and a 16f876 as Slave 2 When I send a i2c_write to Slave1 the communications are well , but when I send to Slave 1 and then to Slave 2 is like that i2c_stop never occurs keeping the sdi and scl low (or high) indefinelly
Does someone knows or have implemented i2c with 2 or more Slaves?
Al
Posted: Mon Feb 16, 2004 3:09 am
Hi Leonardo,
Before issuing an i2c_stop you need to issue a no-acknowledge with your last communication before the i2c_stop. For example after doing a series of i2c_reads (issuing an 'acknowledge' each time) as follows.
