salihonur
HTTP Client doesn't connect to websites |
Posted: Sat Mar 21, 2020 6:24 am |
I have a problem with HTTP Client. It can connect local IP addresses but not internet hosts or internet IPs with and without custom headers. I have tried many website and IP address.
I think HttpClientSetHostNameROM can't resolve DNS. Both SNTP and CCS SNTP doesn't get the epoch also.
Could you help me what is wrong?
CCS TCP/IP Stack version: 5.42.08
Compiler version: 5.081
MCU: PIC18F46K80
TCPIPConfig.h
Code: | #define STACK_USE_ICMP_SERVER 1
#define STACK_USE_TCP 1
#define STACK_USE_UDP 1
#define STACK_USE_DNS 1
#define STACK_USE_ARP 1
#define STACK_USE_DHCP_CLIENT 1
#define STACK_USE_CCS_SNTP_CLIENT 1
#define STACK_USE_CCS_ANNOUNCE 1
//#define STACK_USE_DNS_SERVER 1
#define STACK_CCS_SMTP_TX_SIZE 0
#define STACK_CCS_SMTP_RX_SIZE 0
#define STACK_USE_CCS_HTTP2_SERVER
#define STACK_CCS_HTTP2_SERVER_TX_SIZE 1500
#define STACK_CCS_HTTP2_SERVER_RX_SIZE 500
#define HTTP_NUM_SOCKETS 1
#define HTTP_PORT (80u)
#define HTTP_USE_DOUBLE_ESCAPE 1
#import(RAW, file="mpfs/mpfsimg.bin", location=MPFS_Start)
#define STACK_USE_CCS_HTTP_CLIENT
#define STACK_MY_HTTPC_RX_SIZE 128
#define STACK_MY_HTTPC_TX_SIZE 128
#define STACK_MY_TELNET_SERVER_TX_SIZE 0
#define STACK_MY_TELNET_SERVER_RX_SIZE 0
#define MY_DEFAULT_HOST_NAME "CCS_EXAMPLES"
#define MY_DEFAULT_MAC_BYTE1 (0x0)
#define MY_DEFAULT_MAC_BYTE2 (0x20)
#define MY_DEFAULT_MAC_BYTE3 (0x30)
#define MY_DEFAULT_MAC_BYTE4 (0x40)
#define MY_DEFAULT_MAC_BYTE5 (0x50)
#define MY_DEFAULT_MAC_BYTE6 (0x60)
#define MY_DEFAULT_IP_ADDR_BYTE1 (192ul)
#define MY_DEFAULT_IP_ADDR_BYTE2 (168ul)
#define MY_DEFAULT_IP_ADDR_BYTE3 (1ul)
#define MY_DEFAULT_IP_ADDR_BYTE4 (100ul)
#define MY_DEFAULT_GATE_BYTE1 (192ul)
#define MY_DEFAULT_GATE_BYTE2 (168ul)
#define MY_DEFAULT_GATE_BYTE3 (100ul)
#define MY_DEFAULT_GATE_BYTE4 (1ul)
#define MY_DEFAULT_MASK_BYTE1 (255ul)
#define MY_DEFAULT_MASK_BYTE2 (255ul)
#define MY_DEFAULT_MASK_BYTE3 (255ul)
#define MY_DEFAULT_MASK_BYTE4 (0ul)
#define TCP_CONFIGURATION 2
#define TCP_ETH_RAM_SIZE (STACK_CCS_SMTP_TX_SIZE + \
STACK_CCS_SMTP_RX_SIZE + \
STACK_CCS_HTTP2_SERVER_TX_SIZE + \
STACK_CCS_HTTP2_SERVER_RX_SIZE + \
STACK_MY_TELNET_SERVER_TX_SIZE + \
STACK_MY_TELNET_SERVER_RX_SIZE + \
STACK_MY_HTTPC_TX_SIZE + \
STACK_MY_HTTPC_RX_SIZE + \
100*TCP_CONFIGURATION)
// Define names of socket types
#define TCP_PURPOSE_GENERIC_TCP_CLIENT 0
#define TCP_PURPOSE_GENERIC_TCP_SERVER 1
#define TCP_PURPOSE_TELNET 2
#define TCP_PURPOSE_FTP_COMMAND 3
#define TCP_PURPOSE_FTP_DATA 4
#define TCP_PURPOSE_TCP_PERFORMANCE_TX 5
#define TCP_PURPOSE_TCP_PERFORMANCE_RX 6
#define TCP_PURPOSE_UART_2_TCP_BRIDGE 7
#define TCP_PURPOSE_HTTP_SERVER 8
#define TCP_PURPOSE_DEFAULT 9
#define TCP_PURPOSE_BERKELEY_SERVER 10
#define TCP_PURPOSE_BERKELEY_CLIENT 11
#define TCP_PURPOSE_CCS_SMTP 0x40
#ifndef MAX_HTTP_CONNECTIONS
#define MAX_HTTP_CONNECTIONS 1
#endif
#ifndef MAX_UDP_SOCKETS
#define MAX_UDP_SOCKETS 7
#endif |
main.c
int1 g_MyHttpSending = FALSE;
/* The CCS HTTP Client library is very flexible in the manners of which
data can be sent to the remote HTTP server an how to read response
data from the remote HTTP server. See the ccs_http_client.h file for
a full documentation of this API. */
char tcpResponse[512];
void MyHttpSend(void)
// there are also non-ROM versions of these functions if you want to
// dynamically control the parameters.
debug_writeln("\rHttp client");
HttpClientSetHostNameROM((rom char*)"kontrol3.com");
HttpClientSetUrlROM((rom char*)"/test/index.php");
HttpClientSetHostPort(80);
//char header[1024];
//strcpy(header, "Connection: keep-alive");
//strcat(header, "\rUpgrade-Insecure-Requests: 1");
//strcat(header, "\rUser-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.149 Safari/537.36");
//strcat(header, "\rAccept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9");
//strcat(header, "\rAccept-Encoding: gzip, deflate");
//strcat(header, "\rAccept-Language: tr-TR,tr;q=0.9,en-US;q=0.8,en;q=0.7");
//strcat(header, "\r\n");
//HttpClientSetCustomHeaders(header);
//HttpClientSetCustomHeaders("nAccept: *.*\r\nAccept-Language: tr-tr\r\nHost: kontrol3.com\r\nAccept-Encoding: gzip\r\nConnection: Close\r\n\r\n");
HttpClientStart();
debug_write("Status while busy: ");
debug_writeln(HttpClientGetResult());
Code: | if (TRIGGER && !g_MyHttpSending) // todo: specify action condition, like a button press
TRIGGER = 0;
g_MyHttpSending = TRUE;
MyHttpSend();
else if (!HttpClientIsBusy() && g_MyHttpSending)
// todo: if you want to see the pass/fail of the request,
// use HttpClientGetResult()
// TODO: if you want to see the file returned from the server,
// the methods for doing this depend on if you called
// HttpClientSetResponseBuffer(). See the documentation
// in ccs_http_client.h for more information.
HttpClientSetResponseBuffer(tcpResponse, sizeof(tcpResponse)); // Global degisken olmali
int httpStatus = HttpClientGetResult();
debug_write("Status while not busy: ");
debug_writeln(httpStatus);
if( !httpStatus ) // OK
//while(HttpClientIsGetReady());
debug_writeln(tcpResponse);
Internet connection result
Code: | Http client
Status while busy: 5
Status while not busy: 3
Http client
Http client
Http client
Http client
Status while not busy: 3 |
Local IP connection result
Code: | Http client
Status while not busy: 0
{"Base":"BTC","Target":"TRY","Ask":0.005,"Bid":5,"Timestamp":654564564}
Http client
{"Base":"BTC","Target":"TRY","Ask":0.005,"Bid":5,"Timestamp":654564564} |
Posted: Mon Mar 23, 2020 2:45 am |
Look at the driver dns.c and the example ex_dnslookup.c
Understand the TCPIP driver, does not itself automatically perform DNS
lookup. |
salihonur
Posted: Tue Mar 31, 2020 4:35 pm |
Finally I have solved the problem. I have added theese lines the end of IPAddressInit function:
AppConfig.PrimaryDNSServer = AppConfig.MyGateway.Val;
AppConfig.SecondaryDNSServer.Val = 0;
IPAddressInit
Code: | void IPAddressInit(void)
//AppConfig.Flags.bIsDHCPEnabled = 0;
//DHCPEnable(0);
//MAC address of this unit
MY_MAC_BYTE1=MY_DEFAULT_MAC_BYTE1;
MY_MAC_BYTE2=MY_DEFAULT_MAC_BYTE2;
MY_MAC_BYTE3=MY_DEFAULT_MAC_BYTE3;
MY_MAC_BYTE4=MY_DEFAULT_MAC_BYTE4;
MY_MAC_BYTE5=MY_DEFAULT_MAC_BYTE5;
MY_MAC_BYTE6=MY_DEFAULT_MAC_BYTE6;
//IP address of this unit
MY_IP_BYTE1=MY_DEFAULT_IP_ADDR_BYTE1;
MY_IP_BYTE2=MY_DEFAULT_IP_ADDR_BYTE2;
MY_IP_BYTE3=MY_DEFAULT_IP_ADDR_BYTE3;
MY_IP_BYTE4=MY_DEFAULT_IP_ADDR_BYTE4;
//network gateway
MY_GATE_BYTE1=MY_DEFAULT_GATE_BYTE1;
MY_GATE_BYTE2=MY_DEFAULT_GATE_BYTE2;
MY_GATE_BYTE3=MY_DEFAULT_GATE_BYTE3;
MY_GATE_BYTE4=MY_DEFAULT_GATE_BYTE4;
//subnet mask
MY_MASK_BYTE1=MY_DEFAULT_MASK_BYTE1;
MY_MASK_BYTE2=MY_DEFAULT_MASK_BYTE2;
MY_MASK_BYTE3=MY_DEFAULT_MASK_BYTE3;
MY_MASK_BYTE4=MY_DEFAULT_MASK_BYTE4;
