Joined: 25 Mar 2020 Posts: 1 Location: Banned - spammer
USB errors
Posted: Wed Mar 25, 2020 3:16 am
Hello !
I try to use the USB with a dsPIC33EP256MU806 uC. I would like to use CDC communication, with the own library of CCS. I need to send 8192 bytes via USB to a PC where a script receives the bytes and checks them.
The sent example pattern is: 0x11000000..0x110007ff.
I checked the line with scope and I realized that some double words in the message are different than those I wanted to send, so they automatically change right at sending.
Eg.: The previous double word is: 0x11000304 so I expect that the next is: 0x11000305 but it is 0x11000300.
OR
The previous double word is: 0x110003CF so I expect that the next is: 0x110003D0 but it is 0x1100C1D0.
I tried the same code on a PIC18F2550 and the result was wonderful: there were no errors.
Do you have any idea what I should try? Could you help me?
Posted: Wed Mar 25, 2020 4:20 am
First thing. Post your clock settings. What crystal are you using?.
My settings for USB are:
