PIC24F, RTC Alarm
andresteff
PIC24F, RTC Alarm
PostPosted: Sat Mar 21, 2020 6:14 am     Reply with quote
The rtc alarm function on the PIC24F32KA304 does not so work.
The RTC itself works fine.
The alarm should be 2 minutes after start, but the interrupt comes after one minute!
#INT_RTC
void  RTC_isr(void)
      LED_AN;
// Variable time:
      rtc_time_t     write_clock, read_clock;
// Variable alarm:
       rtc_time_t    write_alarm, read_alarm;
// RTC ON
      setup_rtc(RTC_ENABLE, 0);
// time:
      write_clock.tm_year = 20;
      write_clock.tm_mon  = 03;
      write_clock.tm_mday = 19;
      write_clock.tm_wday = 04;
      write_clock.tm_hour = 22;
      write_clock.tm_min  = 00;
      write_clock.tm_sec  = 00;
      rtc_write(&write_clock);
// Alarm:
      setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_MINUTE, 0);
      write_alarm.tm_year = 20;
      write_alarm.tm_mon  = 03;
      write_alarm.tm_mday = 19;
      write_alarm.tm_wday = 04;
      write_alarm.tm_hour = 22;
      write_alarm.tm_min  = 02;
      write_alarm.tm_sec  = 00;
      rtc_alarm_write(&write_alarm);
// Interrupts: INT_RTC
   clear_interrupt(INT_RTC);
   enable_interrupts(INT_RTC);
    while(1){}
PostPosted: Sat Mar 21, 2020 8:12 am     Reply with quote
Use the 'search' option for the forum, there are some previous messages about how it works.....May not be the same PIC, but similar internal RTC peripheral.
jeremiah
PostPosted: Sat Mar 21, 2020 10:41 am     Reply with quote
Keep in mind for that chip if you are using the internal low power RC for the RTC (don't know if you are or not), that in that family of chips most of them have a really wide tolerance on the oscillator (one of a similar chip from that family had plus or minus 15% tolerance.
I don't know if that is playing a part or not, but something to keep in the back of your mind.
Can you provide a complete small example that compiles and reproduces the issue so others could try it out and see what they come up with? Fragments don't help if something seemingly unrelated is causing the problem.
PostPosted: Sat Mar 21, 2020 12:55 pm     Reply with quote
Problem will be the alarm mask. This is totally 'non intuitive'.
Try with RTC_ALARM_YEAR. It shoukld then alarm when everything
below this mask value matches. With minute selected, it'll alarm
when the seconds match.... Not what you want.
andresteff
PostPosted: Mon Mar 23, 2020 5:54 am     Reply with quote
Thanks for the infos, it's goes !
The key is the correct assignment of the alarm mask to the time variables, on page 197.
As Ttelmah has written, it's 'non intuitive'.
An example on the datasheet would be a good idea.
PostPosted: Mon Mar 23, 2020 8:45 am     Reply with quote
Yes the first time I met this I spent the day performing 'wall, head impact
technology testing'....
Glad I could point to the problem. Very Happy
PostPosted: Mon Mar 23, 2020 9:14 am     Reply with quote
re: Yes the first time I met this I spent the day performing 'wall, head impact
that's not too bad..
I remember spending a WEEK of that 'testing' when cutting code between two systems...one used 'LF,CR' formatting the other 'CR,LF'......for 'end of line'...
bad enough around then 9 pin 'RS23' came along and TXD became RXD and vice versa..
sigh... some days I miss the good old days.....
