allenhuffman
Joined: 17 Jun 2019 Posts: 552 Location: Des Moines, Iowa, USA
5.093: Compiler error with two CCP PWMs |
Posted: Wed Mar 18, 2020 10:52 am |
Due to the "garbage" in the error output, I suspect this is a bug and have already contacted CCS for advice, but thought I'd ask here...
Has anyone used two of the CCPs to generate PWM on a pin? I have this:
Code: | #PIN_SELECT CCP2OUTA=BEEPER_PIN
#use pwm(CCP2, FREQUENCY=4000, DUTY=50, PWM_OFF, STREAM=BEEPER_PWM) |
...which works. And I have this:
Code: | #PIN_SELECT CCP3OUTA=BACKLIGHT_PIN
#use pwm(CCP3, FREQUENCY=4000, DUTY=100, PWM_OFF, STREAM=BACKLIGHT_PWM) |
...which also works. But, I can't build when both of them enabled. I get this:
Quote: | *** Error 99 Line 152(8,75): Option invalid PWM PIN_‰15 already used
I am also unclear on how PIN_SELECT works when both are on the same CCPx. i.e., CCP2OUTA / CCP2OUTB, but there is only CCPx as a parameter for the #use PWM. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ? |
Joined: 01 Jul 2010 Posts: 9229 Location: Greensville,Ontario
Posted: Wed Mar 18, 2020 11:04 am |
Someone who knows will chime in soon,here's my wild idea...
Code/compile/print the listing for the 2 versions.
See which registers get setup, look at datasheet to confirm.
You should (may) be able to cut a third program and 'hard code' the registers the way you want IF possible.
Jay |
