Counter Chip
aaronik19
Counter Chip
PostPosted: Sun Feb 09, 2020 7:22 am     Reply with quote
Dear all,
I know that this might be above the scope of this forum, but I am sure that most of you are electronic enthusiasts and you might help me. In my circuit i would like to insert a counter where the client is freely to configure from 0.1s to 100hr. I came across this counter (https://lsicsi.com/datasheets/LS7213R.pdf)
Apart from LSI since it is hard to purchase these chip to Europe, do you know about another semiconductor company (such as Maxim, Microchip or STMicro) which manufactures this chip? I must say that this chip has the perfect features for my project which is able to handle all the timings and avoid to overload my PIC Micro with excess code.
Very much looking forward for your suggestions.
PostPosted: Sun Feb 09, 2020 7:36 am     Reply with quote
You might try www.banggood.com, they have 1,000s of 'modules', bound to have something....
Obviously the cheapest soultion would be to program a 50 cent PIC for the job. Microchip have 'application notes' about doing this. Or it could have been in their 'tip 'n tricks' book....I have a hardcopy of it here, somewhere.....
Since you have the LSI datasheet, you could program the PIC with those features you need, even 'cloning' the device.
PostPosted: Sun Feb 09, 2020 8:44 am     Reply with quote
The reason you are having problem buying these, is that they no longer
exist!...
LSI was bought by Avago a little while ago. This product was discontinued
soon afterwards.
Note 'DISCONTINUED BY MANUFACTURER; here:
<https://www.radwell.co.uk/en-GB/Buy/LSI%20COMPUTER%20SYSTEMS/LSI%20COMPUTER%20SYSTEMS/LS7213-S?redirect=true>
They were not a popular chip, since these days everything they did can be
done cheaper and easier using something like a basic PIC. Given that the
timing is based on an RC oscillator you will be lucky to get even +/- 20%
accuracy, while a PIC with a calibrated internal oscillator could do 10* better
than this...
PostPosted: Sun Feb 09, 2020 9:53 am     Reply with quote
gee I got curious....
https://lsicsi.com/products/Timers/LS7213R_LS7213R-S
says still in full production, so WHO do you believe ?
I used their dual encoder chips for years, still have a tube of them 'somewhere'...
still, I'd program a PIC to emulate it though....
aaronik19
PostPosted: Sun Feb 09, 2020 10:20 am     Reply with quote
Sorry but seems that lsi/csi are still alive. Last month i sent them an email and they replied but to ship in europe it was super expensive the shipping.
aaronik19
PostPosted: Sun Feb 09, 2020 10:35 am     Reply with quote
This is the application note from Microchip that you mentioned:
http://ww1.microchip.com/downloads/en/devicedoc/51682a.pdf
PostPosted: Sun Feb 09, 2020 11:23 am     Reply with quote
I found that on this partcular chip, they had not elected to do a Rohs
version. So the version needed for European use, is not in
production. This is why I pointed to that site.
I happened to do a unit about ten years ago that uses this, so
at present we are using ones from 'old stock', and going to replace it
when these run out.
This is why the European distributors don't do it....
The page you point to Jay, lists it as Rohs, which disagrees with what they
said....
Suggestion. Find somebody Stateside. Get them to order the ones you want
and have them post them on. Rohs or not, if there are only a few, nobody
will care.
PostPosted: Sun Feb 09, 2020 1:28 pm     Reply with quote
I agree with Jays comment about just emulating this in a PIC.
Should be doable in less than an hour or programming. Only difference
would be the exact pinout, since the power pins won't agree.
Something like a PIC16F15324, will draw less power, cost 1/3rd the
price, need no timing capacitors, & give timings within +/-2% for
normal temperature ranges. Has programmable pullups on all
pions so makes the jumpering to change speed easy.
PostPosted: Sun Feb 09, 2020 8:36 pm     Reply with quote
That Microchip pdf link isn't the one I know about, it's too new !! It was about a'multifunction' timer, using assembler of course. The book was about 1/2" thick.....that's when books were made, yeesh, I feel old.....
I may try to locate the boxes that were in my library tomorrow...
