Convert 2 8-bits data to 16-bit data [Solved]
emaxxenon
PostPosted: Tue Jan 28, 2020 5:04 am     Reply with quote
I have 2 8-bits data.
I have to combine these two and make 16 bits.
Data sent to me:
Sensor1 = A1 + A2*2 + A3*4 + A4*8 + A5*16 + A6*32 + A7*64 + A8*128
Sensor2 = B1 + B2*2 + B3*4 + B4*8 + B5*16 + B6*32 + B7*64 + B8*128
(A=1 or 0)
(B=1 or 0)
The data i see:
Sensor1 max value = 255
Sensor2 max value = 255
I'm trying to make 16 bits.
( AAAAAAAA BBBBBBBB ) = max value 65535
I need to combine the data.
is there any auxiliary code to do this?
Thank you.
EDIT:
SENSOR =make16(Sensor2, Sensor1);
I solved my problem. I couldn't find this code. sorry.
PostPosted: Tue Jan 28, 2020 5:39 am     Reply with quote
Try this CCS function...
//CCS example  from the manual
long x;
int hi,lo;
x = make16(hi,lo);
// this should work for you
unsigned int16 combined;
unsigned int8 Sensor1, Sensor2;
result=(Sensor1,Sensor2); // make 16bit from 2 8 bit values
If you're using MPLAB, pressing F11, opens the CCS manual while your project is open.
Jay
PostPosted: Tue Jan 28, 2020 8:26 am     Reply with quote
This
Gives you BBBBBBBBAAAAAAAA
It needs to ne
SENSOR =make16(Sensor1, Sensor2);
To give you AAAAAAAABBBBBBBB
which is what you originally posted.
Jay
emaxxenon
PostPosted: Tue Jan 28, 2020 8:41 am     Reply with quote
Thank you.
Another question;
Slave:
if(state >= 0x80)
i2c_write(A);
i2c_wrie(B);
Master:
i2c_start();
i2c_write(slave);
A=i2c_read(0);
B=i2c_read(0);
Answer: S 13 A 04 N FF N p
But must be: 04 and 08 (FF false)
Can I send one after another?
No problem if i do it separately.
Master:
i2c_start();
i2c_write(slave);
i2c_write(1);
i2c_stop();
i2c_start();
i2c_write(slave);
A=i2c_read(0);
i2c_stop();
i2c_start();
i2c_write(slave);
i2c_write(2);
i2c_stop();
i2c_start();
i2c_write(slave);
B=i2c_read(0);
i2c_stop();
Slave:
if(state >= 0x80)
if(master==1)
i2c_write(A);
if(master==2)
i2c_wrie(B);
it works like this.
Can't I send it together?
PostPosted: Tue Jan 28, 2020 8:58 am     Reply with quote
emaxxenon wrote:
A=i2c_read(0);
B=i2c_read(0);
Only the _last_ transaction want 0.
The 0 is actually a flag to say to the master 'this is the end of the
transaction'. Is needed on the last byte transfered but not before.
emaxxenon
PostPosted: Tue Jan 28, 2020 11:35 pm     Reply with quote
Ttelmah wrote:
emaxxenon wrote:
A=i2c_read(0);
B=i2c_read(0);
transaction'. Is needed on the last byte transferred but not before.
Master:
i2c_start();
i2c_write(slave);
A=i2c_read();
B=i2c_read(0);
Slave:
if(state >= 0x80)
i2c_write(A);
i2c_write(B);
is it true this way?
or is the structure below more accurate?
Slave:
if(state >= 0x80)
if(state==0x80)
i2c_write(A);
if(state==0x81)
i2c_write(B);
allenhuffman
PostPosted: Wed Jan 29, 2020 1:40 pm     Reply with quote
The CCS compiler has some neat things that generate some nice assembly. I was curious about the difference of doing this in C versus using the CCS statement. Nice results. It's less than half the lines to use the make16() call.
....................    value = (a << 8) | b;
0041A:  MOV.B   CA0,W0L
0041C:  MOV.B   W0L,B
0041E:  CLR.B   W5
00420:  MOV.B   CA1,W0L
00422:  CLR.B   1
00424:  MOV.B   W0L,CA2
00426:  CLR.B   CA3
00428:  MOV     W5,W0
0042A:  IOR     CA2
....................    value = a * 256 + b;
0042C:  MOV.B   CA0,W0L
0042E:  CLR.B   1
00430:  MOV.B   W0L,W0L
00432:  MOV.B   W0L,B
00434:  CLR.B   W5
00436:  MOV     CA0,W4
00438:  LSR     W4,#8,W4
0043A:  ADD     W5,W4,W0
0043C:  MOV     W0,CA2
....................    value = make16 (a, b);
0043E:  MOV.B   CA1,W0L
00440:  MOV.B   W0L,CA2
00442:  MOV.B   CA0,W0L
00444:  MOV.B   W0L,CA3
Nicely done, CCS.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
PostPosted: Wed Jan 29, 2020 1:55 pm     Reply with quote
Yes, saves a lot of space AND x2 or more faster !
allenhuffman
PostPosted: Wed Jan 29, 2020 1:57 pm     Reply with quote
It makes me wonder what other goodies are in there that I should be using.
A coworker suggested using a union, so I added a third test case that seems to be the best way to do it in generic C. Something like...
....................    union
....................       struct {
....................          unsigned int8 a;
....................          unsigned int8 b;
....................       } Bytes;
....................       unsigned int16 value;
....................    } value2;
....................    value2.Bytes.a = a;
0043E:  MOV.B   CA0,W0L
00440:  MOV.B   W0L,CA4
....................    value2.Bytes.b = b;
00442:  MOV.B   CA1,W0L
00444:  MOV.B   W0L,CA5
...but hopefully with better structure/union/variable names ;-)
PostPosted: Wed Jan 29, 2020 2:31 pm     Reply with quote
Yes, I like unions for things like this. Have campaigned to encourage
people to use these in the past. It is 'generic C', and gives efficient code.
And (of course) the same union can be used 'both ways' both to combine
and to split data. Smile
You can be even more ingenious with these. For example, if you are passing
a float to a function that then internally wants to use the bytes or words
from this, you can declare the function with the union, directly pass the
float, and in the function directly access the bytes, without having to use
any intermediate variable. The compiler is smart enough to realise that
the union can accept the float, and doesn't complain.
