EX_ADMM10.C example
art
EX_ADMM10.C example
PostPosted: Wed Jan 15, 2020 2:50 am     Reply with quote
I would like to know, what does " #device ADC=16 " mean ?
In EX_ADMM10.C example it shows that for PCM and PCH, both use this setting. Is it referring to 16 Bit ADC ? if YES, does it mean that PIC18F452 can be set as 16bit ADC ? Follow to datasheet , this PIC18 is a 10 bit ADC.
#if defined(__PCM__)
#include <16F877.h>
#device ADC=16
#elif defined(__PCH__)
#include <18F452.h>
#device ADC=16
#elif defined(__PCD__)
#include <30F2010.h>
#device ADC=16
#use rs232(baud=9600, UART1A)
#endif
PostPosted: Wed Jan 15, 2020 2:58 am     Reply with quote
It tells the compiler ADC functions to justify the ADC results out to 16bits.
The ten bit adc result, is moved so that instead of receiving:
0b000000xxxxxxxxxx
You receive:
0bxxxxxxxxxx000000
With the top bit of the physical result in the 16th bit of the return.
