bastirn
Problem using a function pointer |
Posted: Wed Jan 08, 2020 7:21 am |
I'm trying to implement a shell in a PIC16F1829.
I'm stuck while i try to call a function using function pointer.
You can see a resumé of the problem.
Thanks in advance for any answer,
Best regards,
Bastien NICAUD
#include <16F1829.h>
#device PIC16F1829
#device PIC16F1829 *=16
#device ANSI
#DEVICE PASS_STRINGS=IN_RAM
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <stdarg.h>
#include <stdbool.h>
#include "bnishell.h"
#DEVICE CONST=ROM
#fuses INTRC_IO // Internal OSC
#use delay (clock=32M)
#use rs232(baud=115200, xmit=PIN_C4, rcv=PIN_C5, stream=PC)
int cmd_test(int argc, char ** argv)
printf("\n\rtest\n\r");
return SHELL_RET_SUCCESS;
void main(){
char *cmd_test_argv;
char **cmd_test_argv2;
cmd_test_argv = 81;
cmd_test_argv2 = &cmd_test_argv ;
int (*toto)(int, char **);
int zz ;
enable_interrupts(INT_RDA);
//shell_init();
//shell_register(&cmd_test, "permet de tester", "0-1", "test");
toto = cmd_test;
zz = cmd_test(1,cmd_test_argv2); // Works but not what we need
// What we want to do :
zz = (*toto)(1,cmd_test_argv2); // Error return : "No valid assignment made to function pointer" in the .err file
printf("%d",zz);
while (1) {
//shell_task();
Posted: Wed Jan 08, 2020 9:25 am |
The problem isn't where you think it is.
It's actually the cmd_test_argv2;
Change the ** declarations to:
int (*toto)(int a, char *b[]);
and the same for the function declaration. CCS does not 'like' pointers
to pointers, but happily accepts pointers to arrays (which give exactly
the same effect).
You need to put a dummy variable name to do this (as I show) |
bastirn
Posted: Thu Jan 09, 2020 8:49 am |
Thank you for you answer, now there is no more compilation error,
unfortunately it doesn't work as i want ...
Here is the code that i used :
#include <16LF1829.h>
//#device PIC16F1829
#device PIC16LF1829 *=16
#device ANSI
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <stdarg.h>
//#include "bnishell.h"
#DEVICE CONST=ROM
int cmd_test(int argc, char * argv[])
printf("\n\r %04X \n\r",&argv);
return 1;
void main(){
delay_ms(20);
char *cmd_test_argv2[];
int zz ;
cmd_test_argv = 81;
toto = cmd_test;
//zz = cmd_test(1,cmd_test_argv2); // Works but not what we need
printf("\n\r %04X \n\r",&cmd_test_argv2);
while (1) {
I should have the same adress resulting of this two printf but they are different. Any suggestion ?
Best regards
Bastien |
Posted: Thu Jan 09, 2020 9:28 am |
It won't.
& means 'give the address of'. Called in the subroutine, this gives the
address of the _temporary_ variable holding the value. Not the address
of the original variable. |
