Fast trigonometric approximations
Post new topic   Reply to topic    CCS Forum Index -> Code Library
PostPosted: Fri Jun 09, 2017 2:50 pm     Reply with quote
Some time ago, I posted a much faster atan2 in the general forum.
Decided to post it here together with another fast set of code for sin and cosine:
The accuracy is better than half a degree, and it is _fast_. Takes about 70uSec on a 40Mhz PIC, while atan2 takes at least ten times longer. It is also smaller.... It only gives positive angles, from 0 to 360 as it's result. This works in degrees but is easy to convert to radians if required.
//Processor defines here....
#include <math.h>
float angle(float X, float Y)
   //routine to give a fast solution for angle, from X/Y co-ordinates - result in degrees
   float AX,AY,ival,oval,aival;
   int8 quad;
   AX=fabs(X);
   AY=fabs(Y);
   //Now the approximation used works for tan from -1 to 1, so we have to keep the
   //values inside this range and adjust the input/output.
   //Four 'quadrants' are decoded -1 to 1, (315 to 45 degrees), then 45 to 135,
   //135 to 225, 225 to 315
   If (X >= 0) //Right hand half of the circle
      If (AY > X)
         If (Y < 0)
             quad = 4;
             ival = -X / Y;
         Else
             quad = 2;
             ival = X / -Y;
      Else
         If (AY > X)
             quad = 4;
             ival = -Y / X;
             quad = 1;
             ival = Y / X;
      //Now the others
      If (Y > AX)
         quad = 2;
         ival = X / -Y;
      Else
         If (AY > AX)
             quad = 4;
             ival = -X / Y;
         Else
             quad = 3;
             ival = -Y / -X;
   //A lot of lines of code, but small and quick really.....
   //Now the solution
   //Now approximation for atan from -1 to +1, giving an answer in degrees.
   aival = fAbs(ival);
   oval = 45 * ival - ival * (aival - 1) * (14.02 + 3.79 * aival);
   //Now solve back to the final result
   If (quad != 1)
      If (quad == 2)
          oval = oval + 90;
      Else
          If (quad == 3)
              oval = oval + 180;
          Else
              oval = oval + 270;
   if (oval<0)
      oval+=360;
   return oval;
//Demo program using pairs of numbers from the array to test
   const signed int16 source[] = {0,300,600,1000,0,-300,-600,-1000};
   int8 ctr,ctr2=0;
   signed int16 X,Y;
   while (TRUE)
      for (ctr=0;ctr<8;ctr++)
         //Now loop through the array, using pairs from two counters as X/Y
         X=source[ctr];
         Y=source[ctr2];
         printf("X %ld, Y %ld, angle %5.1f\n\r", X,Y,angle(X,Y));
      if (ctr2<7)
         ctr2++;
         ctr2=0;
Now I have added this code for sin/cosine. This is in radians for +PI to -PI input range.
//A fast float approximation to sin over the range +/-PI
#define PI2 (PI*PI)
#define INV4  (4/PI)
#define INV4SQ  (-4/(PI2))
#define P  0.225
float fast_sin(float x)
    float y;
    y = (INV4 * x) + (INV4SQ * x * fabs(x));
    return P * (y * fabs(y) - y) + y;
float fast_cos(float x)
{  //This is done by shifting the quadrants
   x += PIDIV2;
   if(x > PI)   // Original x > pi/2
      x -= PI2;   // Wrap: cos(x) = cos(x - 2 pi)
   return fast_sin(x);
  //Test the fast sin algorithm for angles from 0 to PI in steps of PI/128
  float an, res, sres,;
  for (an=0.0;an<(PI);an+=(PI/128))
     //res1=fast_sin1(an);
     res=fast_sin(an);
     sres=sin(an);
     printf ("AN=%5.3f sinfast=%5.3f sin=%5.3f\n",an,res,sres);
     delay_cycles(1);
I don't show a test for the cos, but this works exactly the same. Slightly slower.
tinley
Great code thanks
PostPosted: Tue Jan 07, 2020 7:03 am     Reply with quote
Thanks Ttelmah. This code is exactly what I was looking for. You mention that the quadrants may not be correct. They don't match CCS atan2 function and I think you were right to suspect. I substituted the following:
result = (atan2( input_value_X , input_value_Y ) * 57.2958 ); // 180/pi = 57.2958
With:
result = angle(input_value_X, input_value_Y);
And I had to swap the X and Y to get it to work.
But it does work very well and quickly! Thank you!
tinley
Fast COS
PostPosted: Tue Jan 07, 2020 9:07 am     Reply with quote
As it happens, I can also use your fast COS in the same project. But this did have a couple of bugs which are fixed in the following:
#define PI2 (PI*PI)
#define INV4  (4/PI)
#define P  0.225
#define PIDIV2 (PI/2)
#define PIX2 (PI*2)
    float y;
   x += PIDIV2;
      x -= PIX2;   // Wrap: cos(x) = cos(x - 2 pi)
   return fast_sin(x);
But still save me heaps of time trying to save time! Thank you!
PostPosted: Mon Jan 27, 2020 1:16 pm     Reply with quote
Well done.
Glad you got it sorted. Very Happy
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
