Momboz
spi_xfer_in usage on PIC16F15325 |
Posted: Sun Dec 22, 2019 5:20 am |
I would like to use the function spi_xfer_in for reading an external signal with its clock and the compilation says:
"*** Error 51 "CCS_15325_Micro.c" Line 23(27,28): A numeric expression must appear here"
Here is my code: Code: | #include <CCS_15325_Micro.h>
#define LED PIN_A0
#define DELAY 10
#use spi (SLAVE, CLK=PIN_C0, DI=PIN_C1, MODE=0, BITS=24, STREAM=SPI_1)
unsigned long data_in;
#INT_EXT
void EXT_isr(void) {
output_toggle(PIN_A1);
void main() {
enable_interrupts(INT_EXT);
while(TRUE) {
//Example blinking LED program
output_toggle(LED);
delay_ms(DELAY);
//TODO: User Code
data_in = spi_xfer_in();
and the external signal is a clock with a BCD over 6 nibbles as shown in here:
https://www.yuriystoys.com/2013/07/chinese-caliper-data-format.html
Any help or advice? |
Posted: Sun Dec 22, 2019 5:41 am |
All spi_xfer functions need the stream name....
They say they don't, but there are issues unless you use it.
What PIC are you using?.
If the C0/C1 pins are SPI2, then use 'SPI2'. You can't setup a hardware
SPI, without using all three pins. You can override the unused pin after
it is setup, but using only two pins will setup a software SPI, and this
will not support slave operation.... |
Momboz
Posted: Mon Dec 23, 2019 5:34 am |
Ttelmah wrote: | All spi_xfer functions need the stream name....
Ok. I assume that would mean "data_in = spi_xfer_in(SPI_1,24); in my case"
Quote: |
What PIC are you using?. | It's a PIC16F15325
In my case C0/C1 is SPI1 according to the Microchip datasheet.
Your statement is that I could use the hardware SPI in slave mode(since slave mode is not allowed in software SPI). That means my code will look like this:
Code: | ...
#use spi(FORCE_HW, SLAVE, BITS=24, stream=SPI_STREAM)
data_in = spi_xfer_in(SPI_STREAM,24);
Te compiler still gives error during compilation:
"*** Error 99 "CCS_15325_Micro.c" Line 6(5,54): Option invalid Wrong pins for H/W"
Any advice? Thank you. |
Joined: 01 Jul 2010 Posts: 9169 Location: Greensville,Ontario
Posted: Mon Dec 23, 2019 6:00 am |
I don't use that PIC but downloaded the datasheet..
That PIC has PPS which probably has to be configured BEFORE you use SPI.
There's a 'Sticky' at the top of this page which should help.
Others who use this PIC , or one with PPS, may reply with help. |
jeremiah
Re: spi_xfer_in usage on PIC16F15325 |
Posted: Mon Dec 23, 2019 11:11 am |
Momboz wrote: |
Code: | ...
You need to tell it which hardware SPI you are using. Nothing in the #use spi() says which. Try adding SPI1
Code: | ...
#use spi(SPI1,FORCE_HW, SLAVE, BITS=24, stream=SPI_STREAM)
For some compiler versions, specifying the pins but not the SPI module puts it in software SPI mode instead of hardware.
EDIT: also what size is long for your pic (I don't know offhand for 8bit pics)? you will need to have a 32bit value. Specify it as unsigned int32 to be sure. |
Posted: Mon Dec 23, 2019 2:39 pm |
Yes, his long is only 16bit. Needs to be unsigned int32.
Happy Christmas everyone |
