LineInput (read X characters) routine.
Post new topic   Reply to topic    CCS Forum Index -> Code Library
allenhuffman
PostPosted: Thu Dec 19, 2019 12:08 pm     Reply with quote
For some testing, I ported an old LineInput (modeled after BASIC) I wrote for Arduino to the CCS code. It supports backspace (^h) and CANcel (^x, erase entire line). If you get to the end of the line, it echos the bell character (for terminals that support that).
I originally wrote this back in the late 80's or early 90's for an OS-9 (Unix-like OS) BBS. I dig it out every few years for some other project.
Usage is like this:
char buffer[80];
int bytesRead;
bytesRead = LineInput (buffer, 80);
Simple Line Input routine.
By Allen C. Huffman (alsplace@pobox.com)
www.subethasoftware.com
#define CR           13
#define BEL          7
#define BS           8
#define CAN          24
byte lineInput(char *buffer, size_t bufsize)
  char    ch;
  byte    len = 0;
  boolean done;
// TODO: spinning cursor!
  done = false;
  while(!done)
    //ledBlink();
    //if (Serial.available()>0)
      ch = getch();
      switch(ch)
      case CR:
        //Serial.println();
        printf ("\r\n");
        buffer[len] = '\0';
        done = true;
      case CAN:
        //Serial.println(F("[CAN]"));
        while (len > 0)
            putc (BS);
            putc (' ');
            putc (BS);
          len--;
        //len = 0;
      case BS:
        if (len>0)
          //Serial.write(BS);
            putc (BS);
          //Serial.print(F(" "));
            putc (' ');
          //Serial.write(BS);
            putc (BS);
          len--;
      default:
        // If there is room, store any printable characters in the line.
        if (len<bufsize)
          if ((ch>31) && (ch<127)) // isprint(ch) does not work.
            // UPPERCASE it...
            ch = toupper(ch);
            //Serial.write(ch);
            putc (ch);
            buffer[len] = toupper(ch);
            len++;
          //Serial.write(BEL); // Overflow. Ring 'dat bell.
          putc (BEL);
      } // end of switch(ch)
    } // end of if (Serial.available()>0)
  } // end of while(!done)
  return len;
} // end of lineInput()
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
