I am currently running a PIC16f877-20/P at 20MHz. I am using the pic to generate a PWM output. The minimium PWM output frequency is too high running at 20MHz so I would like to change this to 4MHz. Can I simply change the clock oscillator and code to change this or do I need to get a PIC16f877-4/P?
AC
Neutone
Posted: Tue Feb 10, 2004 9:20 am
The -20 specifies the maximum rated operating frequency.
Mark
Posted: Tue Feb 10, 2004 10:09 am
Which means DC-20Mhz. You should also change your fuse the XT intead of HS.
