Low power consumption
Goto page 1, 2  Next
championx
PostPosted: Tue Dec 03, 2019 10:59 am     Reply with quote
Hi! I'm working on a project of a wireless temperature sensor, i have developed a very simple board that reads temp from a DS18B20 digital sensor, then transmit the readings over 2.4ghz using a NRF24L01.
This board is powered from a CR2032 batt, so i need to achieve the lower current consumption possible.
the thing is that i cant lower it more than 35uA.
here is the code:
#include <16f1847.h>                    // Selecciona el PIC
#fuses INTRC_IO,NOPROTECT, PUT, NOMCLR, WDT_SW, BROWNOUT, NOLVP, PLL_SW, NOFCMEN, NOIESO, NOSTVREN
#use delay(clock=8000000)
#use spi(mode = 0, DI=PIN_A7, DO=PIN_B7, CLK=PIN_B6, BITS=8, msb_first)
//#use fast_io(A)
//#use fast_io(B)
#define  RF24_CS        PIN_B4   //RC1;  chipselect nRF24L01+
#define  RF24_CE        PIN_B3   //RC2;  chipEnable nRF24L01+
#define  RF24_IRQ       PIN_B0    // interrupt pin
#define power_on output_high(PIN_A1)
#define power_off output_low(PIN_A1)
int data[8] = {0,0,0,0,0,0,0,0};
#include "1Wire_simple.c"
#include "DS18B20_SIMPLEc.c"
#include <driver_nrf24l01_9bytes_FAST.c>
void transmit_data(int16 ID)
RF_TX_DATA[0] = 'Z';
RF_TX_DATA[1] = make8(ID,1);
RF_TX_DATA[2] = make8(ID,0);
RF_TX_DATA[3] = data[0];
RF_TX_DATA[4] = data[1];
RF_TX_DATA[5] = data[2];
RF_TX_DATA[6] = data[3];
RF_TX_DATA[7] = data[4];
RF_TX_DATA[8] = RF_TX_DATA[0] + RF_TX_DATA[1] + RF_TX_DATA[2] + RF_TX_DATA[3] + RF_TX_DATA[4] + RF_TX_DATA[5] + RF_TX_DATA[6]+ RF_TX_DATA[7];
if(send_shock_burst(master_add1,master_add2,master_add3,master_add4,master_add5)==1)
   //to do
delay_ms(10);
flush_tx();
return;
float temperature = 0;
int segundos_sincro = 0;
int1 debug_mode = 0;
unsigned int8 i;
unsigned int8 status;
unsigned int8 count = 0;
//set_tris_a (0b10100001);   //Ra7-Ra6-Ra5-Ra4-Ra3-Ra2-Ra1-Ra0
//set_tris_b (0b00100010);
output_low(PIN_A6);
setup_adc(ADC_OFF);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_vref(VREF_OFF);
setup_dac(DAC_OFF);
setup_timer_1(T1_DISABLED);
init_rf();
flush_rx();
setup_wdt(WDT_8S);
while (1)
   restart_wdt();
   power_on;
   output_high(PIN_A6);
   delay_ms(10);
   temperature = ds1820_read();
   transmit_data(1); //just testing the transceiver
   power_off;
   output_low(PIN_A6);
   nrf_set_power_down();
   delay_ms(10);
   sleep();
   delay_cycles(1);
any hint? i really don't know what else to test. I have tested putting resistors to ground or VCC on all of the unused pins.
The weird thing is if i touch the ground pin, the current lowers to 15uA...
PostPosted: Tue Dec 03, 2019 11:44 am     Reply with quote
General thing, I/O pins should not be left floating.
All the pins your code does not drive _will_ be floating. They should be
driven high or low. A floating pin will draw power whenever the level
floats between high/low.
PostPosted: Tue Dec 03, 2019 11:47 am     Reply with quote
This is a nominal 3.0v battery, therefore you should be using the "LF"
version of the 16F1847. It is hugely more power-efficient than the "F".
Order a couple of them.
You should set all unused i/o pins to a low level output with:
output_low(PIN_X);
output_low(PIN_Z);
You can turn off Brownout and Watchdog during sleep using the fuses.
You should be able to get sleep current down to less than 1 ua, or
even lower if you turn off brownout and watchdog completely.
PostPosted: Tue Dec 03, 2019 12:01 pm     Reply with quote
some things to do...
off the top of my head, no particular order..
1) Use fast_IO() and set_tris()... Results in fewer operations, less power used
2) reduce clock speed... Slower clock + less power comsumed
3) delete delay_ms()... PIC 'twiddling thumbs' consumes power
4) get rid of float math... BIG consumer of energy(time+cycles)
5) 'trim' code within included files...possible a lot of unneeded code?
6) transmit temp sensor 12bits NOT a float
7) 'pack' data,to reduce bytes sent = less power used
8) read the uchip ap on saving power(2 decades+ old but real useful)
9) remove ALL LEDs !
10) read chaprt 9 - sleep mode - has some 'todo' items....
if a real project, not just a 'class project'... use a bigger battery.
Jay
championx
PostPosted: Tue Dec 03, 2019 2:38 pm     Reply with quote
Thanks for all the answers, i will test it tomorrow and post the results!
temtronic, thanks for the suggestions, sadly, i can't change the battery size, it is not a class project, and i need it to be light and small, so i can't use any other battery.
Thanks!!
championx
PostPosted: Sat Dec 07, 2019 10:38 pm     Reply with quote
Hi all! i tested your suggestions and i got 11,2uA its very good, but i think i could go lower...
I used fast_io and tris, all pins as outputs (just for testing purposes) and disconnected everything (no temp sensor, no NRF24, nothing, just the pic, some decoupling caps a resistor with a led and a pullup resistor(4k7) for onewire sensor).
I set the unused pins as output and drive them high. disabled brownout and tested disabling the wdt, but that didnt make any considerable change.
here is the code:
#fuses INTRC_IO,NOPROTECT, PUT, NOMCLR, WDT_SW, NOBROWNOUT, NOLVP, PLL_SW, NOFCMEN, NOIESO, NOSTVREN
#use fast_io(A)
#use fast_io(B)
unsigned int8 i;
set_tris_a (0b00000000);   //Ra7-Ra6-Ra5-Ra4-Ra3-Ra2-Ra1-Ra0
set_tris_b (0b00000000);
output_low(PIN_A6);
setup_adc(ADC_OFF);
setup_dac(DAC_OFF);
setup_wdt(WDT_8S);
while (1)
   restart_wdt();
   delay_ms(10);
   output_b(0xff);
   output_a(0xff);
   output_low(PIN_A6);
   delay_ms(10);
   sleep();
   delay_cycles(1);
do you have any other suggestion?
PostPosted: Sun Dec 08, 2019 1:33 am     Reply with quote
Are you using the 16F1847 or the "LF" version ?
championx
PostPosted: Mon May 18, 2020 2:02 pm     Reply with quote
Hi! sorry for the delay! I'm using the LF version. The strange thing is that the pic sometimes consume 33uA and if i move it to other side of the desk the current drops to 8uA.....???????? so, i assume some pin is getting "noise"... or some pin is not well drived... i will check the hardware again tonight.
Then i probably use a new board with just the pic and the minimum hardware to power it and test the code to achieve the lowest power consumption...
This thing is really driving me crazy... i have to use a CR2032 because the board has to be wearable and very small...
any suggestion will be welcome!
(sorry for my english)
PostPosted: Tue May 19, 2020 12:07 am     Reply with quote
What do you have connected to the MCLR pin?.
This does not have an output driver, so _must_ be pulled either
high or low by your hardware.
championx
PostPosted: Tue May 19, 2020 7:46 pm     Reply with quote
yes, the MCLR pin is drived high with a 1Mega resistor.
I stripped down the hardware to just the pic, the NRF24l01+ , a led and a tact switch connected to B0 input and a 1M pullup.
championx
PostPosted: Tue May 19, 2020 8:04 pm     Reply with quote
well... this is really annoying... i manage to make it run using only 0.005mA but, then i move the circuit to another place and the multimeter shows 0.040ma.... Evil or Very Mad Evil or Very Mad Evil or Very Mad
championx
PostPosted: Tue May 19, 2020 8:14 pm     Reply with quote
ok, done... before the sleep instruction I added a tris for each port setting all pins as outputs, only B0 (wake up) as input. And that's it... now it consumes 0.002mA everywhere! Smile Smile Smile Smile Smile
PostPosted: Wed May 20, 2020 1:06 am     Reply with quote
As we said, 'pins must not be left floating'...
It really is vital to ensure that the pins are physically driven either high
or low, by something.
Glad you now have a starting place to making a low power system. Smile
championx
PostPosted: Wed May 20, 2020 7:41 am     Reply with quote
Hi Ttelmah, thanks for your help. I thought that pins that are not connected or routed must be driven.. but even the input pins connected to other modules (in this case NRF24L01) should be set as output and drive them to a logical state.
thanks!!
PostPosted: Wed May 20, 2020 8:06 am     Reply with quote
It is alright to leave them as inputs, _provided the other module is driving
them
_. The key point is that a lot of 'modules' only turn on their
output pins, when they are selected.
The NRF only drives it's output pins, when the CE pin is high.
Goto page 1, 2  Next
Page 1 of 2
