ertansuluagac
S1D13700 driver code |
Posted: Mon Nov 25, 2019 11:35 pm |
ccs c 5.091
processor dsPIC33EP512GM710
I'm looking for the s1d13700 driver code written to the ccs c compiler. Could you share it if you have it? The screen I use NHD-320240WG-BxTGH-VZ#-3VR
thank you very much _________________ Es |
Posted: Tue Nov 26, 2019 12:14 am |
Have a look at:
<http://www.ccsinfo.com/forum/viewtopic.php?t=46223&highlight=s1d13700> |
ertansuluagac
Posted: Tue Nov 26, 2019 12:36 am |
I looked. but it has never been more literally running. _________________ Es |
Posted: Tue Nov 26, 2019 1:36 am |
What do you mean "it has never been more literally running".
You will have to change every 'int16' entry to 'unsigned int16', and every
'int8' to 'unsigned int8', and most of the pin references. Particularly the
byte wide output 'output_d', which you will have to either add a byte wide
output routine to do, or mask the port (the former is probably easier,
just declare a #BYTE variable to talk to the low 8bits of the port you want
to use, and connect the chip to this - set TRIS before using - same for the
read routine). Remember to use LAT for output and the port for input.
Fairly basic tweaking to make it work on the PIC33. |
ertansuluagac
Posted: Tue Nov 26, 2019 1:39 am |
I don't use port d. The pins I can use should be as follows. My hardware is suitable for these pins.
#define S1D13700_Data_A0 PIN_D5
#define S1D13700_Data_RW PIN_D13
#define S1D13700_Data_E PIN_D12
#define S1D13700_Data_CS PIN_D6
#define S1D13700_Data_RST PIN_C9
#define S1D13700_Data_DB0 PIN_F1
#define S1D13700_Data_DB1 PIN_G1
#define S1D13700_Data_DB2 PIN_G0
#define S1D13700_Data_DB3 PIN_F6
#define S1D13700_Data_DB4 PIN_F7
#define S1D13700_Data_DB5 PIN_G14
#define S1D13700_Data_DB6 PIN_G12
#define S1D13700_Data_DB7 PIN_G13
Posted: Tue Nov 26, 2019 2:02 am |
That makes it really hard. Splitting the output byte to bits on several
ports. You will have to do something like (in place of output_d):
void output_byte(uint8_t val) //assumes stdint.h is loaded
if (bit_test(val,0))
output_high(S1D13700_Data_DB0);
output_low(S1D13700_Data_DB0);
if (bit_test(val,1))
output_high(S1D13700_Data_DB1);
output_low(S1D13700_Data_DB1);
if (bit_test(val,2))
output_high(S1D13700_Data_DB2);
output_low(S1D13700_Data_DB2);
if (bit_test(val,3))
output_high(S1D13700_Data_DB3);
output_low(S1D13700_Data_DB3);
if (bit_test(val,4))
output_high(S1D13700_Data_DB4);
output_low(S1D13700_Data_DB4);
if (bit_test(val,5))
output_high(S1D13700_Data_DB5);
output_low(S1D13700_Data_DB5);
if (bit_test(val,6))
output_high(S1D13700_Data_DB6);
output_low(S1D13700_Data_DB6);
if (bit_test(val,7))
output_high(S1D13700_Data_DB7);
output_low(S1D13700_Data_DB7);
and a similar one reading the bits into a byte for input_d.
Though a bit cumbersome, this is as efficient in code terms as any other
solution. Lesson is though when laying out something that uses byte
wide data input/output, do try to put the pins onto consecutive port
bits. Will speed things and save a lot of code....
Joined: 01 Jul 2010 Posts: 9425 Location: Greensville,Ontario
Posted: Tue Nov 26, 2019 5:52 am |
There's also a hardware solution, for maybe $2.
Buy a smaller PIC and code the diplay driver into it. Connect to your PIC on 1 I/O pin, then send display data to it.
There are 'interface modules' like this for the LCD1602 style LCDs, maybe someone makes them for the GLCD you have ? |
Posted: Tue Nov 26, 2019 7:41 am |
It only takes 0.8uSec to run the output_byte as shown. Fast enough I'd suspect
to be totally acceptable. So though not elegant. Good enough.
(assuming he is at 120MHz).
The chip itself is a GLCD to basic parallel interface, so probably not worth
trying to switch to using basic text mode.... |
Posted: Tue Nov 26, 2019 8:31 am |
Just written an 'input_byte' for the same configuration:
uint8_y input_byte(void) //assumes stdint.h is loaded
uint8_t rval=0;
if (input(S1D13700_Data_DB0))
bit_set(rval,0);
if (input(S1D13700_Data_DB1))
bit_set(rval,1);
if (input(S1D13700_Data_DB2))
bit_set(rval,2);
if (input(S1D13700_Data_DB3))
bit_set(rval,3);
if (input(S1D13700_Data_DB4))
bit_set(rval,4);
if (input(S1D13700_Data_DB5))
bit_set(rval,5);
if (input(S1D13700_Data_DB6))
bit_set(rval,6);
if (input(S1D13700_Data_DB7))
bit_set(rval,7);
return rval;
replace 'input_d' with a call to this. |
I offered the HW solution as it's 'old skool', had to make several over the decades to upgrade 'reliable' equipment .
hmm, sounds like a 'Flex-GLCD' driver might be an answer !
Jay |
ertansuluagac
Posted: Tue Nov 26, 2019 8:47 am |
I wrote but it doesn't work.
#ifdef DELAYS_48MHZ
#define delay_xt 5
#ifdef DELAYS_20MHZ
#define delay_xt 1
#define GLCD_WIDTH 320
#define GLCD_HEIGHT 240
#define GLCD_CHAR_WIDTH 8
#define GLCD_CHAR_HEIGHT 8
#define ON 1
#define OFF 0
#define COMMAND_MODE output_high(S1D13700_Data_A0);
#define DATA_MODE output_low(S1D13700_Data_A0);
#DEFINE S1D13700_GRAPHICSTART 0x2580
void GlcdPutData(INT8 data);
int8 TakeData(void);
void GLCD_WriteCommand(int8 commandToWrite);
void GLCD_WriteData(int8 dataToWrite);
int8 GLCD_ReadData(void);
void setCursorAddress(int16 addr);
void GlcdGotoTextXY(int16 x, int16 y);
void GlcdPutC(char c);
void FillText(char cara);
void FillGraphic(int1 parameter);
void glcd_RAinit(void);
int8 GLCD_ReadStatus(void);
void GlcdPutData(int8 data)
output_bit(S1D13700_Data_DB0, bit_test(data,0));
output_bit(S1D13700_Data_DB1, bit_test(data,1));
output_bit(S1D13700_Data_DB2, bit_test(data,2));
output_bit(S1D13700_Data_DB3, bit_test(data,3));
output_bit(S1D13700_Data_DB4, bit_test(data,4));
output_bit(S1D13700_Data_DB5, bit_test(data,5));
output_bit(S1D13700_Data_DB6, bit_test(data,6));
output_bit(S1D13700_Data_DB7, bit_test(data,7));
int8 TakeData(VOID)
INT8 data = 0;
data += input (S1D13700_Data_DB0);
data += input (S1D13700_Data_DB1) * 2;
data += input (S1D13700_Data_DB2) * 4;
data += input (S1D13700_Data_DB3) * 8;
data += input (S1D13700_Data_DB4) * 16;
data += input (S1D13700_Data_DB5) * 32;
data += input (S1D13700_Data_DB6) * 64;
data += input (S1D13700_Data_DB7) * 128;
RETURN data;
void GLCD_WriteData(int8 dataToWrite) // Changes
GlcdPutData(dataToWrite);
output_low(S1D13700_Data_E);
DATA_MODE
output_low(S1D13700_Data_RW);
output_low(S1D13700_Data_CS);
delay_cycles(5);
output_high(S1D13700_Data_E);
delay_cycles(5);
output_high(S1D13700_Data_RW);
output_high(S1D13700_Data_CS);
int8 GLCD_ReadData(void) // Changes
int8 tmp;
delay_cycles(5);
delay_cycles(5);
tmp = TakeData();
return tmp;
void S1D13700_INIT(void)
output_high(S1D13700_Data_RST);
//system set
GLCD_WriteCommand(0x40);
GLCD_WriteData(0x30);
GLCD_WriteData(0x87);
GLCD_WriteData(0x07);
GLCD_WriteData(0x27);
GLCD_WriteData(0x2F);
GLCD_WriteData(0xEF);
GLCD_WriteData(0x28);
GLCD_WriteData(0x00);
//scroll
GLCD_WriteCommand(0x44);
GLCD_WriteData(0xF0);
GLCD_WriteData(0x80);
GLCD_WriteData(0x25);
GLCD_WriteData(0x4B);
//HDOT SCR
GLCD_WriteCommand(0x5A);
//OVLAY
GLCD_WriteCommand(0x5B);
GLCD_WriteData(0x01);
//erase all screen
FillGraphic(OFF);
FillText(' ');
//DISP ON
GLCD_WriteCommand(0x58);
GLCD_WriteData(0x56);
//CSRFORM
GLCD_WriteCommand(0x5D);
GLCD_WriteData(0x04);
GLCD_WriteData(0x86);
//DISP ON
GLCD_WriteCommand(0x59);
//CSDIR
GLCD_WriteCommand(0x4C);
//CSRW
setCursorAddress(0x0000);
long count;
//set cursor to 2580h
setCursorAddress(0x2580);
//put 00h in all graphic space
count = 9600;
GLCD_WriteCommand(0x42);
while(count != 0)
GLCD_WriteData(0xFF * parameter);
count--;
long count;
//set cursor to 0000h
//put 00h in all text space
count = 1200;
while(count != 0)
GLCD_WriteData(cara);
count--;
GLCD_WriteData(c);
//x and y : 1 to max
int16 adress = 0;
adress = (y-1)*40;
adress = adress+ x-1;
setCursorAddress(adress);
int8 adress;
GLCD_WriteCommand(0x46);
adress = addr & 0xFF;
GLCD_WriteData(adress);
adress = addr >> 8;
void GLCD_Pixel(int16 x,int16 y, int1 color)
int8 tmp = 0;
int16 address = 0;
address = S1D13700_GRAPHICSTART + (40 * y) + (x/8);
setCursorAddress(address);
GLCD_WriteCommand(0x43);
GLCDPutData(0x00);
set_tris_d(0xFF); // Set the Port D as inputs before I call
// GLCD_ReadData; it doesn't work
// without this line.
// The rest is the same.
tmp = GLCD_ReadData();
set_tris_d(0x00); // Port D as outputs again.
if(color == ON)
tmp |= (1 << (7 - (x % 8)));
tmp &= ~(1 << (7 - (x % 8)));
GLCD_WriteData(tmp);
void GLCD_GraphicGoTo(int16 x,int16 y)
setCursorAddress(S1D13700_GRAPHICSTART + (y * 40) + x/8);
int8 tmp;
delay_cycles(5);
delay_cycles(5);
delay_cycles(5);
tmp = takedata();
return tmp;
Posted: Tue Nov 26, 2019 8:58 am |
You were told by Ttelmah to do this:
But you didn't do it. |
ertansuluagac
Posted: Tue Nov 26, 2019 9:03 am |
so I did. It did not work.
#ifdef DELAYS_48MHZ
#define delay_xt 5
#ifdef DELAYS_20MHZ
#define delay_xt 1
#define ON 1
#define OFF 0
void GlcdPutData(unsigned int8 data);
unsigned int8 TakeData(void);
void GLCD_WriteCommand(unsigned int8 commandToWrite);
void GLCD_WriteData(unsigned int8 dataToWrite);
unsigned int8 GLCD_ReadData(void);
void setCursorAddress(unsigned int16 addr);
void GlcdGotoTextXY(unsigned int16 x, unsigned int16 y);
unsigned int8 GLCD_ReadStatus(void);
int8 TakeData(VOID)
unsigned unsigned int8 data = 0;
RETURN data;
void GLCD_WriteData(unsigned int8 dataToWrite) // Changes
DATA_MODE
delay_cycles(5);
delay_cycles(5);
unsigned int8 GLCD_ReadData(void) // Changes
unsigned int8 tmp;
delay_cycles(5);
delay_cycles(5);
tmp = TakeData();
return tmp;
//system set
//scroll
//HDOT SCR
//OVLAY
//erase all screen
FillGraphic(OFF);
FillText(' ');
//DISP ON
//CSRFORM
//DISP ON
//CSDIR
//CSRW
long count;
count = 9600;
while(count != 0)
count--;
long count;
count = 1200;
while(count != 0)
count--;
GLCD_WriteData(c);
unsigned int16 adress = 0;
adress = (y-1)*40;
unsigned int8 adress;
adress = addr >> 8;
void GLCD_Pixel(unsigned int16 x,unsigned int16 y, int1 color)
unsigned int8 tmp = 0;
unsigned int16 address = 0;
GLCDPutData(0x00);
if(color == ON)
void GLCD_GraphicGoTo(unsigned int16 x,unsigned int16 y)
unsigned int8 tmp;
delay_cycles(5);
delay_cycles(5);
delay_cycles(5);
tmp = takedata();
return tmp;
Posted: Tue Nov 26, 2019 9:05 am |
and..
there could be a timing probem.
delay_cycles(xx) is based upon the clock value.
if the original code was written where delay_cycle(1) = 1 us , that will be 5X faster( .2us), if your PIC clock is 5X faster than the original program.
there also might be the '5V PIC - 3V peripheral' problem, thoug I think that PIC is 3 Volts ? but what is the GLCD VDD ? |
ertansuluagac
Posted: Tue Nov 26, 2019 9:13 am |
pıc 3volt
dsPIC33EP512GM710 _________________ Es |
