Interrupt handler uses too much stack
TheGaut
PostPosted: Mon Feb 09, 2004 12:04 pm     Reply with quote
I get this error: Interrupt handler uses too much stack
What was that??????
PostPosted: Mon Feb 09, 2004 12:34 pm     Reply with quote
What was that ?
Are you calling a lot of nested subroutines from your isr ?
You shouldn't.
In an isr, you should just:
1. Fetch a char and stuff it in a fifo buffer.
or
2. Increment a counter, or two.
or
3. Set a flag.
Don't do much more than that.
If this doesn't answer your question, then post your isr code,
and also post the PIC and version of the compiler you're using.
