Reading MCP4725, rotating and concatenating two bytes
nickdc
PostPosted: Sat Nov 16, 2019 3:40 am     Reply with quote
My compiler version is 5.076 and I'm working on a PIC16F1828.
I'm converting the following code from XC8 to CCS.
I want to read the data bits of a MCP4725 DAC device.
I want to convert the data of a two 8 bits to a numerical value of 16 bits.
In XC8 I could do this.
output = (upper8bits<<4) | (lower8bits>>4); // The 16-bit result we want to return.
For example, I set the MCP4725 with a value of 4095.
Reading the data gives a 12 bit value.
In this case, the upper 8 bits are 0xFF. The lower 8 bits are 0xF0.
I want to convert this to 0x0FFF (which is 4095 in decimal notation). So the upper bits are shifted 4 bits to the left, and the lower bits are shifted 4 bits to the right.
However, I get the wrong result in CCS.
I also tried the following methods:
rotate_left(&upper8bits, 1);
rotate right(&lower8bits, 1);
The second argument is the number of bytes.
Then I tried the following:
output = upper8bits + lower8bits;
This doesn't work.
Kind regards
Changed MCP4825 to MCP4725
to correct his typo.
- Forum Moderator
PostPosted: Sat Nov 16, 2019 4:41 am     Reply with quote
Your original code will work, with one tiny change:
output = ((int16)upper8bits<<4) | (lower8bits>>4); // The 16-bit result we want to return.
The 'reason' is fundamental. CCS defaults to using the default integer size of
each processor. So on this chip, an 'int' is 'int8'. You can't rotate an int8
left four bits without losing 4 bits out the top. So it has to be told to do
the rotation on a 16bit value. This is done using the (int16) cast. XC8 defaults
to using 16bit integers.
PostPosted: Sat Nov 16, 2019 12:14 pm     Reply with quote
hmm I can't find an MCP4825, is it really an MCP4725 ?
PostPosted: Sat Nov 16, 2019 12:32 pm     Reply with quote
Yes I think it is.
nickdc
PostPosted: Sat Nov 16, 2019 12:59 pm     Reply with quote
It is the MCP4725. I made a typo, sorry.
I will try the suggesting when I have access to my hardware.
PostPosted: Sat Nov 16, 2019 1:14 pm     Reply with quote
I think the OP is over-thinking this. I just did a test of his method vs.
the most simple way of coding it. The simple way wins, in both speed
and code space.
His method:
vs. the simple method:
data = make16(upper8bits, lower8bits);
data >>= 4;
'data' is an int16.
If you put the printfs in, you get this output in MPLAB vs. 8.92 simulator:
output= 0564
data= 0321
This shows both methods produce right-justified output.
But which one is more efficient ?
Using MPLAB vs. 8.92 Stopwatch with breakpoints, the execution time
of this line is 22 instruction cycles:
For the next two lines, the execution time is 14 cycles:
data >>= 4;
The amount of code generated for his method is:
... output = ((int16)upper8bits<<4) | (lower8bits>>4);
0003A:  CLRF   @@0C
0003C:  MOVFF  upper8bits,@@0B
00040:  RLCF   @@0B,F
00042:  RLCF   @@0C,F
00044:  RLCF   @@0B,F
00046:  RLCF   @@0C,F
00048:  RLCF   @@0B,F
0004A:  RLCF   @@0C,F
0004C:  RLCF   @@0B,F
0004E:  RLCF   @@0C,F
00050:  MOVLW  F0
00052:  ANDWF  @@0B,F
00054:  SWAPF  lower8bits,W
00056:  MOVWF  @00
00058:  MOVLW  0F
0005A:  ANDWF  @00,F
0005C:  MOVF   @00,W
0005E:  IORWF  @@0B,W
00060:  MOVWF  output
00062:  MOVFF  @@0C,output+1
But for the simple method, it is this:
.................... data = make16(upper8bits, lower8bits);
0006E:  MOVFF  upper8bits,data+1
00072:  MOVFF  lower8bits,data
.................... data >>= 4;
00076:  RRCF   data+1,F
00078:  RRCF   data,F
0007A:  RRCF   data+1,F
0007C:  RRCF   data,F
0007E:  RRCF   data+1,F
00080:  RRCF   data,F
00082:  RRCF   data+1,F
00084:  RRCF   data,F
00086:  MOVLW  0F
00088:  ANDWF  data+1,F
Test program:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
int16 output;
int16 data;
int8 upper8bits;
int8 lower8bits;
upper8bits = 0x56;
lower8bits = 0x40;
printf("output= %lx \r", output);
upper8bits = 0x32;
lower8bits = 0x10;
data >>= 4;
printf("data= %lx \r", data);
while(TRUE);
PostPosted: Sat Nov 16, 2019 2:05 pm     Reply with quote
Worth just adding, that the 'simple' method, is just XC8 code.
The reason his second method didn't work, was that he was only
rotating one bit, when it needs four.
The optimised method is rather nice. Use the make8 instruction that
is nicely optimised, and then just rotate the entire word. Smile
nickdc
PostPosted: Mon Nov 18, 2019 1:44 am     Reply with quote
When I try the optimized method, I get for 4095 (decimal) the following:
upper8bits: 00ff
lower8bits: 00f0
output: 00ff
When I try:
I get:
upper8bits: 00ff
lower8bits: 00f0
output: 00ff
PostPosted: Mon Nov 18, 2019 1:52 am     Reply with quote
Post a complete test program (as I did) that shows the problem.
nickdc
PostPosted: Mon Nov 18, 2019 2:13 am     Reply with quote
This is my (shortened) program:
#include <16F1828.h>
#fuses HS,NOWDT,PROTECT,NOLVP,BROWNOUT
#use delay(clock=18.432M, CRYSTAL)  // xtal-frequency
#use rs232(STREAM = UART_Display, baud=115200,UART1,parity=N,bits=8, ERRORS)
#use i2c(master, scl=PIN_B6, sda=PIN_B4)
#define DEBUG
#include <stdbool.h>
#include <stdint.h>
#define MCP4725_CMD_WRITEDAC       (0x40)  // Writes data to the DAC
#define MCP4725_CMD_WRITEDACEEPROM (0x60)  // Writes data to the DAC and the EEPROM (persisting the assigned value after reset)
typedef struct {
    uint8_t address;
} mcp4725_dac_t;
mcp4725_dac_t dac;
void StdDacWrite(mcp4725_dac_t dac, uint16_t input, bool writeEeprom){
    char data = 0x00;
    i2c_start();
    i2c_write(0xCC);
    if (writeEeprom)
        i2c_write(MCP4725_CMD_WRITEDACEEPROM);
        i2c_write(MCP4725_CMD_WRITEDAC);
    // /16 in 1 instruction
    data = (char)(input >> 4); // Upper data bits (D11.D10.D9.D8.D7.D6.D5.D4)
    i2c_write(data);
    data = (char)(input % 16) << 4; // Lower data bits (D3.D2.D1.D0.x.x.x.x)
    i2c_write(data);
    i2c_stop();
int16 StdDacReadDac(mcp4725_dac_t dac){
    int16 output;
    int8 upper8bits;
    int8 lower8bits;
#ifdef DEBUG
    char status;
    char output4 = 0x00;
    char output5 = 0x00;
#endif
    i2c_start();
    i2c_write(0xCD);
    //I2CAckBit();
#ifdef DEBUG
    status = i2c_read();
#else
    i2c_read();
#endif
    upper8bits = i2c_read();
    lower8bits = i2c_read();
    i2c_read();
    i2c_read();
    i2c_stop();
#ifdef DEBUG
    printf("status: %x\r\n", status);
    printf("upper8bits: %4x\r\n", upper8bits);
    printf("lower8bits: %4x\r\n", lower8bits);
    printf("output4: %x\r\n", output4);
    printf("output5: %x\r\n", output5);
#endif
    //rotate_left(&upper8bits,4);
    //rotate_right(&lower8bits,4);
//    output = make16(upper8bits, lower8bits);
//    output >>= 4;
    printf("output: %4x\r\n", output);
    //printf("output: %d\r\n", output);
    return output;
int16 ApplicationReadVoltage(mcp4725_dac_t dac){
    return StdDacReadDac(dac);
/* Set value via I2C. */
void ApplicationSetVoltage(mcp4725_dac_t dac, uint16_t input, bool writeEEPROM){
    StdDacWrite(dac, input, writeEEPROM);
void main(void) {
    printf("start\r\n");
    ApplicationSetVoltage(dac, 4095, false);
    ApplicationReadVoltage(dac);
    while(TRUE){
    return;
EDIT:
It seems to have been an error with the printf formatter. When I use %lx instead of %4x, I get the correct output printed.
PostPosted: Mon Nov 18, 2019 2:43 am     Reply with quote
You would. %x, says to print an 8bit integer. The 'L' says instead to print
a 16 or 32bit integer. Smile
