PIC18F26K22 and PLL
gjs_rsdi
PIC18F26K22 and PLL
PostPosted: Tue Nov 05, 2019 8:50 pm     Reply with quote
Hi
CCS PCH C Compiler, Version 5.062
If I am initializing the oscillator as:
#use delay(clock=64MHz,crystal=16MHz)
In the LST file I can see:
Configuration Fuses:
Word 1: 3200 HSH PLLEN PRIMARY NOFCMEN NOIESO
If I initializing the oscillaror as:
#use delay(internal=64MHz)
Word 1: 2800 INTRC_IO NOPLLEN PRIMARY NOFCMEN NOIESO
In the data sheet, page 28 diagram I see that both internal and external oscillators goes to the PLL unit.
How I can initialize Internal oscillator and get the PLL enable?
Best wishes
Joe
PS: I forget to mention the other fuses:
#FUSES INTRC_IO//Internal RC Osc, no CLKOUT
#FUSES PLLEN//4X HW PLL enabled
PostPosted: Wed Nov 06, 2019 12:17 am     Reply with quote
You already are.
Your INTERNAL=64MHz is enabling the internal oscillator with PLL.
The reason for your confusion is this cannot be done in the fuses.
Instead the compiler adds the extra initialisation at the start of the code
to do it.
Reason is in the data sheet Para 2.8.2:
Unlike external clock modes, when internal clock
modes are enabled, the PLL can only be controlled
through software. The PLLEN control bit of the
OSCTUNE register is used to enable or disable the
PLL operation when the HFINTOSC is used.
So the PLL has to be turned on in the software after the boot, and
cannot be enabled in the fuses when using the internal oscillator.
The compiler automatically does this.
Now older compilers did not do this automatically. I think yours is
recent enough that it should be working (how fast is the chip running?),
but it it doesn't then you simply have to add your own
'setup_oscillator' line to set this.
Can confirm (just checked) your compiler does enable the PLL correctly
Fourth line in the generated code:
0000C: BSF OSCTUNE.PLLEN
This is the PLL enable being done right at the start of the code.
gjs_rsdi
PostPosted: Wed Nov 06, 2019 3:16 am     Reply with quote
Thank you Ttelmah for the explanation.
I try to find the above (or part of it) in the LST but didn't find except
NOPLL in the configuration fuses.
Where I should find it?
Best wishes
Joe
PostPosted: Wed Nov 06, 2019 3:32 am     Reply with quote
If you look at the list file you should have something like:
.................... void main(void)
00004:  CLRF   FF8
00006:  BCF    FD0.7
00008:  MOVLW  70
0000A:  MOVWF  FD3
0000C:  BSF    F9B.6
0000E:  BCF    F9B.7
00010:  MOVLB  F
00012:  CLRF   x38
00014:  CLRF   x39
00016:  CLRF   x3A
00018:  CLRF   F77
0001A:  CLRF   F78
0001C:  CLRF   F79
The fifth code line down there is the one enabling the PLL. I had set the
compiler to generate 'symbolic' output, which then gives register
names, and makes knowing what it is doing a lot easier... Smile
gjs_rsdi
PostPosted: Wed Nov 06, 2019 4:27 am     Reply with quote
Thank you again Ttelmah Smile
I am getting old Sad I forget about this option:
set the
And also because my program have already 22% of the memory the setting will be probably at different location than 0000C.
036C8: BSF OSCTUNE.PLLEN
036CA: BCF OSCTUNE.INTSRC
Thank you again and have a nice day
Joe
