allenhuffman
Joined: 17 Jun 2019 Posts: 540 Location: Des Moines, Iowa, USA
CCS i2c_slaveaddr() address is 2X from FTDI address |
Posted: Tue Oct 29, 2019 10:19 am |
Just curious ... I know I2C addressing has one of the bits in the 8-bit address to indicate read/write, but I have a question about how CCS uses this.
When I initialize an I2C address to 110 using i2c_slaveaddr() or in the #use I2C line, I have to use half that when talking to it via a PC and FTDI I2C interface. In my case, the PC side needs address 55 for the PIC initialized to 110 to see it. The PIC sees a 110 in the I2C address byte (01101110).
If I initialize the PIC to an odd address, like 111 (01101111), writing to address 55 responds with the PIC I2C address still reporting as 110.
I'm used to the address matching. I was wondering if someone knew why CCS did it this way. Maybe this is common, and the systems I have used just didn't do it this way. It makes some of our PIC code have address values that are larger than the 7-bit address allows. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ? |
Posted: Tue Oct 29, 2019 10:23 am |
CCS uses 8-bit i2c address format. All their functions and #use
statements expect 8-bit format.
7-bit format is used by NXP.
To convert 7-bit format to 8-bit, simply left-shift the 7-bit format by 1.
Do not initialize a slave address to an odd number. It will not work.
Do not use decimal. Think and use hex for i2c addresses.
Do not use reserved i2c addresses for a slave. |
allenhuffman
Posted: Tue Oct 29, 2019 10:29 am |
PCM programmer wrote: | CCS uses 8-bit i2c address format. All their functions and #use
7-bit format is used by NXP. |
Ah, odd to me, but that explains it. The spec says it's a 7-bit format, so I was not understanding why were were using "impossible" values in the PIC code. I ran into this when I was trying to make some common header files between our PC application and the PIC code and realized they can't use the same values for our board addresses :-)
Update: Ah, I find it referenced on some sites:
Quote: | Some vendors incorrectly provide 8-bit addresses which include the read/write bit. Often times, you can determine if this is the case because they will provide one address for writing to the slave device and another to reading from the slave. In this situations. please only use the top seven bits of the address. |
Well, I've seen worse. I was stunned to find that the "DMX" XLR-plug cables I'd used "forever" for stage lighting were NOT using the actual DMX specification connectors. I had never read the spec so I did not realize it was supposed to a DIN connector like my old Radio Shack computer used ;-) _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Tue Oct 29, 2019 10:48 am |
I'm going to just make a macro in the PIC code so I can define all the addresses using the I2C 7-bit standard. Something like this, I guess:
Code: | // Convert standard I2C 7-bit address to non-standard PIC 8-bit address.
// address = 7-bit I2C address
// rw = 0-read, 1-write
#define I2C_ADDRESS_TO_PIC(address,rw) ((address<<1)|(rw)) |
Though maybe the rw bit isn't as necessary...
#define I2C_ADDRESS_TO_PIC(address) (address<<1) |
Joined: 01 Jul 2010 Posts: 9174 Location: Greensville,Ontario
Posted: Tue Oct 29, 2019 1:20 pm |
XLR connectors were cheaper and EASIER to solder up, 'back then'.(yeah I did a LOT of band work 1/2 century ago, prePIC. and yes, MY TRS80 has a 5 pin DIN on the back for cassette tape.
As for the 7 bit vs 8 bit, the original spec was 7 ( a Philips(now NXP) thing). though the standard has 'slid' just like RS-232 which USED to be 25 pins...2 was xmt, 3 rec...that magically got changed and STILL cause me problems as 2 is rec, 3 is xmt and 9 pins....
sigh.....getting old and cranky...
I do like the MACRO idea though, might save losing some sleep..... |
Posted: Tue Oct 29, 2019 1:27 pm |
The distinction is between address and byte.
The 'address byte', has a 7bit address as the top seven bits, then the
R/W bit as the bottom bit. The PIC uses it's addresses in this format.
On the slave hardware address recognition, only the upper seven bits
are used. So only even 'addresses'. When sending the address byte, you
need the same format, but with the R/W bit included. |
allenhuffman
Posted: Tue Nov 05, 2019 8:53 am |
temtronic wrote: | XLR connectors were cheaper and EASIER to solder up, 'back then'.(yeah I did a LOT of band work 1/2 century ago, prePIC. and yes, MY TRS80 has a 5 pin DIN on the back for cassette tape.
"The great thing about standards . . . "
I was doing a bunch of retro TTL/RS-232 work on my old Radio Shack computer in recent years, and was stunned I could still buy DB9-DB25 adapters and TTL converters and such. Long live 232!
#StayOffMyLawn (there. old and cranky by new and hip) _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Tue Nov 05, 2019 8:54 am |
Ttelmah wrote: | The distinction is between address and byte.
Does the hardware do anything with that bit? _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Posted: Tue Nov 05, 2019 8:57 am |
Yes.
It is what flags the data direction for the subsequent transfer. |
allenhuffman
Posted: Tue Nov 05, 2019 9:24 am |
Ttelmah wrote: | Yes.
I'll have to check our existing code. We have command messages that just write, and query messages that write then read a response. I had not noticed if our code is altering the address to set that bit. Or I guess that could be done by something in the API. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Posted: Tue Nov 05, 2019 9:53 am |
The bit is set or cleared in the master write. The slave sees this and reacts
accordingly. |
