Flavio58
Malloc and free |
Posted: Fri Jun 06, 2003 5:08 am |
When I try to use the dynamic allocation methods and free the compiler show me an error in stdlibm.h ....
To use malloc and free I must to include this file ....
This error is :
Error[12] C:\PROGRA~1\PICC\drivers\memmgmt.c 56 : Undefined identifier __DYNAMIC_HEAD
The __DYNAMIC_HEAD is not defined....
Do you known how is possible to use the free function ?
___________________________
Original Post ID: 144515060 |
R.J.Hamlett Guest
Re: Malloc and free |
Posted: Fri Jun 06, 2003 5:54 am |
:=When I try to use the dynamic allocation methods and free the compiler show me an error in stdlibm.h ....
:=To use malloc and free I must to include this file ....
:=This error is :
:=Error[12] C:\PROGRA~1\PICC\drivers\memmgmt.c 56 : Undefined identifier __DYNAMIC_HEAD
:=The __DYNAMIC_HEAD is not defined....
:=Do you known how is possible to use the free function ?
Yes, it works.
The question is which compiler version you have?. For example, the demo code will compile fine on V3.160, and back as early as about 3.114, but on 3.110, will give the error you are quoting.
Any version that comes with the example, should not give this error. The compiler seems to create this variable without being asked. Is it possible you are changing one of the other include files, and preventing this?. Have you tried compiling the example 'as is'?.
The code that is generated, seems 'reasonable'.
What chip are you trying to compile for?. Though some of the files used, mention PCB, most only refer to PCM or PCH. So far, this demo will not compile for me, on any chip using the PCB compiler.
Original Post ID: 144515062 |
Lance Lascari Guest
Posted: Fri Jun 06, 2003 6:30 am |
I've seen malloc work, but it doesn't work in my application.
I finally ended up sending my code to support but I haven't yet heard. In my case it would intermittently work with various power-cycling-conditions. It seems that it somehow is affected by other stuff in ram because it would ALWAYS fail for me if I tried #ZERO_RAM.
Hopefully I'll hear from them on what the deal is...
Anyone else made it work? I didn't get an answer when I asked before myself.
I'm trying to use it with PCH, btw.
Lance
:=:=When I try to use the dynamic allocation methods and free the compiler show me an error in stdlibm.h ....
:=:=To use malloc and free I must to include this file ....
:=:=This error is :
:=:=Error[12] C:\PROGRA~1\PICC\drivers\memmgmt.c 56 : Undefined identifier __DYNAMIC_HEAD
:=:=The __DYNAMIC_HEAD is not defined....
:=:=Do you known how is possible to use the free function ?
:=Yes, it works.
:=The question is which compiler version you have?. For example, the demo code will compile fine on V3.160, and back as early as about 3.114, but on 3.110, will give the error you are quoting.
:=Any version that comes with the example, should not give this error. The compiler seems to create this variable without being asked. Is it possible you are changing one of the other include files, and preventing this?. Have you tried compiling the example 'as is'?.
:=The code that is generated, seems 'reasonable'.
:=What chip are you trying to compile for?. Though some of the files used, mention PCB, most only refer to PCM or PCH. So far, this demo will not compile for me, on any chip using the PCB compiler.
:=Best Wishes
Original Post ID: 144515063 |
Flavio58
Posted: Mon Jun 09, 2003 2:33 am |
The problem is not the free or malloc function but the errror that my compiler show me when I include the stdlibm.h in my projects...
I use the last relase (3.160 - PCH)....
Executing: "C:\Programmi\PICC\Ccsc.exe" "SkyMilCtrl.c" "-I C:\Programmi\PICC\Drivers" +FH +DF +LN +T +A +M -Z +ICD +Y=9 +FH
Skipping link step. Not all sources built successfully.
BUILD FAILED
In this include there is the __DYNAMIC_HEAD that is not defined ...
Original Post ID: 144515103 |
R.J.Hamlett Guest
Posted: Mon Jun 09, 2003 4:50 am |
:=The problem is not the free or malloc function but the errror that my compiler show me when I include the stdlibm.h in my projects...
:=I use the last relase (3.160 - PCH)....
:=Executing: "C:\Programmi\PICC\Ccsc.exe" "SkyMilCtrl.c" "-I C:\Programmi\PICC\Drivers" +FH +DF +LN +T +A +M -Z +ICD +Y=9 +FH
:=Skipping link step. Not all sources built successfully.
:=BUILD FAILED
:=In this include there is the __DYNAMIC_HEAD that is not defined ...
As I have said, it appears to be created automatically. I'd suspect the line '#USE DYNAMIC_MEMORY".
However you are still trying to compile your code 'SkyMilCtrl'. Go back to the question, does the demo itself compile?. On this version for me, it does. Once you have this working, you then have to find out what is different. If it doesn't, then it would possibly imply that one of the command line options is actually interfering with this function.
Original Post ID: 144515104 |
btokarchuk Guest
Posted: Tue Jun 24, 2003 2:03 pm |
:=This error is :
This may not help you, but i have the same problem. Though through moving the #include <STLIBM.H> directive around i found that it now compiles if i put this IMMEDIATELY after the #use RS232 line in my main.h file. I have yet to check to see if this actually works once it's running but at least it compiles now.
Brent.
Original Post ID: 144515538 |
Guest_X44 Guest
Posted: Sat Feb 07, 2004 10:44 pm |
I still have the same problem with CCS compiler ver. 3.173.
Could anyone out there help me out on this. |
