I want to a few question ask about Bootloader.
ertansuluagac
PostPosted: Wed Oct 23, 2019 1:56 am     Reply with quote
#org LOADER_END+2, LOADER_END+4
This code what does it do?
LOADER_END+2 and LOADER_END+4 what is happening
ccs c  version 5.090
Process steps;
1- In the project wizard I selected processor 18f67j60.
2- I set the crystal and clock speeds to 25MHz.
3- In the project wizard, I clicked on the bootloder option. and I chose PUSH_BUTTON according to 3.3v ethernet Controller Development kit. (PIN_A4)
4- I did the coding.
5- After writing my code, I clicked Build & Run button and upload my program.
6- I run Serial Monitor from Tools option. I made my adjustments. I chose my com port. Then I pressed Reset and PUSH_BUTON. I saw Bootloader Version 1.0 and Waiting For Dowland. From the File menu, clicked Dowload Software. And I loaded my deneme.hex code.
8- Then I made changes to my code. I changed Version 1.0 to Version 1.1 and rebuild it. Then I pressed Reset and PUSH_BUTON again and uploaded deneme.hex file. Now I need to write Version 1.1 on my screen. Why does it say Version 1.0?
my code
#include <18F67J60.h>
#device ADC=10
#FUSES NOWDT                  //No Watch Dog Timer
#use delay(crystal=25MHz)
#define _bootloader
// NOTE - User must include bootloader.h in application program
#include <bootloader.h>
#include <loader.c>
#define PUSH_BUTTON PIN_A4
float version=1.2;
#INT_GLOBAL
void isr(void){
   jump_to_isr(LOADER_END+9*(getenv("BITS_PER_INSTRUCTION")/8));
void application(void) {
  while(TRUE);
   setup_adc_ports(NO_ANALOGS, VSS_VDD);
   // Enter Bootloader if Pin A4 is low after a RESET
   if(!input(PIN_A4))
      printf("\r\nBootloader Version:%2.1f\r\n",version);
      // Let the user know it is ready to accept a download
      printf("\r\nWaiting for download ");
      load_program();
   application();
Es
PostPosted: Wed Oct 23, 2019 2:10 am     Reply with quote
#define _bootloader
This define must only be present in the actual bootloader, not in the
application that is to be loaded. With this present the code will be built
to locate where the bootloader sits, and the bootloader will _not_ load
the code if this is the case. Hence your new code has not been loaded.
Don't 'trust' the wizard, you will waste a lot of time if you do.
Instead look at the examples. The example ex_bootload.c shows how
a file that is going to be 'bootloaded' has to appear.
The ORG statements say 'where' the following code is going to be located
in memory. So in this case, just after the bootloader.
ertansuluagac
PostPosted: Wed Oct 23, 2019 2:18 am     Reply with quote
Understood. But, ex_bootlooder.c file when I compile give error.
Errors given:
>>> Warning 205 "C:\Program Files (x86)\PICC\Drivers\loader.c" Line 185(1,1): Unsigned variable is never less than zero
*** Error 71 "C:\Users\Technopc\AppData\Roaming\PICC\ex_bootloader.c" Line 73(1,2): Out of ROM, A segment or the program is too large MAIN
Seg 00000-00003, 0000 left, need 00049 Reserved
Seg 00004-0000E, 0000 left, need 00049 Orged
Seg 0000F-0033F, 0000 left, need 00049
Seg 00340-00341, 0000 left, need 00049 Orged
Seg 00342-007FE, 04BD left, need 00049 Reserved
Seg 007FF-007FF, 0001 left, need 00049 Reserved
Seg 00800-00FFE, 07FF left, need 00049 Reserved
Seg 00FFF-00FFF, 0001 left, need 00049 Reserved
Seg 01000-017FE, 07FF left, need 00049 Reserved
Seg 017FF-017FF, 0001 left, need 00049 Reserved
Seg 01800-01FFE, 07FF left, need 00049 Reserved
Seg 01FFF-01FFF, 0001 left, need 00049 Reserved
1 Errors, 1 Warnings.
Build Failed.
Es
ertansuluagac
PostPosted: Wed Oct 23, 2019 2:58 am     Reply with quote
Okay. It works. Thanks.
Es
PostPosted: Wed Oct 23, 2019 3:04 am     Reply with quote
Er. You said you had the bootloader already compiled and installed in
the chip. So why are you touching bootloader.c?.
Sequence as follows:
Bootloader.c
Edit to match _your_ chip. Compile, and load into the chip with a
programmer. Don't touch it again.
Your_program.c
Add the #include for bootloader.h
Compile. Then load with the serial.
That is all that is involved. You should not be touching the bootloader
at this point.
The bootloader, and the application are separate. Combing the bootloader
with the application can be done, but is honestly more trouble than it
is worth.
