driver for SPI FRAM CY15B104Q
Goto page 1, 2, 3  Next
micro_debugger
PostPosted: Thu Oct 17, 2019 2:03 pm     Reply with quote
Do you know if drivers library provided with ccsinfo contain driver compatible with SPI FRAM CY15B104Q.
If not I will write my own and share with you.
Thank you and Kind Regards
micro_debugger
PostPosted: Thu Oct 17, 2019 2:18 pm     Reply with quote
Normally FRAM's are reverse compatible with equivalent SPI EEPROM
drivers. I've used several without problems. However the issue here will
be there is not a 4Mbit SPI EEPROM driver in the library. The existing
1MBit driver will need to simply have the size increased, and a couple
of extra bits of address output.
micro_debugger
PostPosted: Thu Oct 17, 2019 2:41 pm     Reply with quote
Thank you !
You are faster than light Very Happy
When finished it will share.
MikeW
PostPosted: Fri Oct 18, 2019 12:00 am     Reply with quote
this might help
https://www.silabs.com/community/wireless/zigbee-and-thread/knowledge-base.entry.html/2017/06/16/extending_the_spifla-0SnN
PostPosted: Fri Oct 18, 2019 1:41 am     Reply with quote
OK. Sat down this morning and modified an SPI EEPROM driver. Think this
should be very close to right (but untested, not even compiled). If it works
we can transfer it to the code library.
//Base attempt at a CY15B104Q FRAM driver
#ifndef __CY15B104Q__ //ensure only loads once
#define __CY15B104Q__
#include <stdint.h>
#ifndef FRAM_SELECT_PIN
 #define FRAM_SELECT_PIN    PIN_B4
#endif
#ifndef FRAM_CLK_PIN
 #define FRAM_CLK_PIN       PIN_C3
#endif
#ifndef FRAM_SDI_PIN
 #define FRAM_SDI_PIN       PIN_A4      //MOSI
#endif
#ifndef FRAM_SDO_PIN
 #define FRAM_SDO_PIN       PIN_A9      //MISO
#endif
#ifndef FRAM_SIZE
 #define FRAM_SIZE          524288       //4Mbit 500Kbytes
#endif
#ifndef FRAM_SPI_BAUD
 #define FRAM_SPI_BAUD      16000000    //16 MHz
#endif
//Optionally, write protect and hold pins can also be defined.
#ifndef FRAM_STREAM
 #use spi(MASTER, MODE=0, CLK=FRAM_CLK_PIN, DO=FRAM_SDI_PIN, DI=FRAM_SDO_PIN, BITS=8, BAUD=FRAM_SPI_BAUD, STREAM=FRAM_STREAM)
 #define FRAM_xfer(x)       spi_xfer(FRAM_STREAM, x)
#else
//Handle where somebody has called with an already defined stream
//ensure transfers are byte sized.
 #define FRAM_xfer(x)       spi_xfer(FRAM_STREAM, x, 8)
#endif
typedef uint32_t FRAM_ADDRESS;
//Command list
typedef enum
   FRAM_CMD_WRSR=0x01,
   FRAM_CMD_WRITE,
   FRAM_CMD_READ,
   FRAM_CMD_WRDI,
   FRAM_CMD_RDSR,
   FRAM_CMD_WREN,
   FRAM_CMS_FSTRD=0xB,
   FRAM_CMD_SLEEP=0xB9,
   FRAM_CMD_RDID=0x9F
} FRAM_CMD;
typedef struct
   uint8_t ManufactureCode;   //should be 0x80
   uint8_t FamDenCode;        //should be 0x26
   uint8_t[7] ManID;       //should be 0x‭7F7F7F7F7F7FC2‬ - ID is 0xC2 rest fillers
} FRAM_ID;
////////////////////////////////// Prototypes /////////////////////////////////
void init_ext_FRAM(void);
uint8_t read_ext_FRAM(FRAM_ADDRESS Address);
void write_ext_FRAM(FRAM_ADDRESS Address, uint8_t Data);
void ext_FRAM_read_id(FRAM_ID *Id);
void ext_FRAM_write_enable(int1 Enable=TRUE);
void read_block_FRAM(FRAM_ADDRESS Address, BYTE * buffer, uint16_t count);
///////////////////////////////////// API /////////////////////////////////////
// init_ext_FRAM()
// Initializes the external FRAM's chip select, hold and write protect pins.
// Should be called before any other external FRAM functions are called.
// Also ensure block protection not enabled
// Parameters - None.
// Returns - Nothing.
   output_high(FRAM_SELECT_PIN);
   output_drive(FRAM_SELECT_PIN);
  #ifdef FRAM_HOLD_PIN //optonal pins.
   output_high(FRAM_HOLD_PIN);
   output_drive(FRAM_HOLD_PIN);
  #endif
  #ifdef FRAM_WRITE_PROTECT_PIN
   output_high(FRAM_WRITE_PROTECT_PIN);
   output_drive(FRAM_WRITE_PROTECT_PIN);
  #endif
  ext_FRAM_write_enable(TRUE); //needs to be set before accessing the SR
  //Now this chip support block protection as well as the WREN bit
  //disable this for simplicity
  output_low(FRAM_SELECT_PIN);
  FRAM_xfer(FRAM_CMD_WRSR);
  FRAM_xfer(0); //turn off protected address range
  ext_FRAM_write_enable(FALSE);
// read_ext_FRAM()
// Reads a byte from the external FRAM from the specified address.
// Parameters:
//    Address - the address within the external FRAM to read.
// Returns:
//    uint8_t - the byte read from the external FRAM or 0x00 if Address
//              was invalid.
   uint8_t Result;
   if(Address < FRAM_SIZE)
      FRAM_xfer(FRAM_CMD_READ);
      FRAM_xfer(make8(Address, 2)); //top 3 bits of address
      FRAM_xfer(make8(Address, 1));
      FRAM_xfer(make8(Address, 0)); //LSB
      Result = FRAM_xfer(0);
      Result = 0;
   return(Result);
// write_ext_FRAM()
// Writes a byte to the external FRAM to the specified address.  If an
// invalid address is specified nothing is written.
// Parameters:
//    Address - the address within the external FRAM to write.
//    Data - the byte to write to the specified address.
      //Enable writes, ext_FRAM_write_enable()
      FRAM_xfer(FRAM_CMD_WRITE);
      FRAM_xfer(make8(Address,2);
      FRAM_xfer(Data);
      //Disable writes
// ext_FRAM_read_id()
// Function for reading the external FRAM's identification.
// Parameters:
//    Id - pointer to FRAM_ID structure to return read identification to.
   uint8_t count;
   BYTE * ptr;
   ptr=ID; //quicker than casting for every operation
   FRAM_xfer(FRAM_CMD_RDID);
   for (count=0;count<sizeof(FRAM_ID);count++)
      ptr[count]=FRAM_xfer[0]; //clock entire ID from chip
// ext_FRAM_write_enable()
// Function use enable or disable write functions.
// Parameters:
//    Enable - if TRUE writes are enabled, if FALSE writes are disabled.
   if(Enable)
      FRAM_xfer(FRAM_CMD_WREN); //set the WREN bit
      FRAM_xfer(FRAM_CMD_WRDI);
// read_block_FRAM()
// Function used to perform a block read from the chip
// Parameters:
//    Address - start address in the memory
//    buffer - pointer to RAM area to receive the data
//    count - number of bytes to read
      FRAM_xfer(FRAM_CMD_FSTRD);
      FRAM_xfer(0); //dummy byte needed after this command
      while (count-->0)
         *(buffer++) = FRAM_xfer(0));
      //now transfer 'count' bytes ASAP
   return;
#endif
micro_debugger
PostPosted: Sat Oct 19, 2019 6:23 pm     Reply with quote
Thank you very much for your work !!
I will have hardware this week, so test it and release to common library.
PostPosted: Sat Oct 19, 2019 10:50 pm     Reply with quote
Look forward to hearing how you get on... Smile
micro_debugger
PostPosted: Sat Oct 26, 2019 3:52 pm     Reply with quote
Just received assembled hardware and putting everything together.
Will keep you informed.
BR
micro_debugger
PostPosted: Sun Oct 27, 2019 2:38 pm     Reply with quote
Not working, until now. Need to setup a protocol analyzer to see what is done inside, as with simple dso see it properly.
More news next 1-2 days.
PostPosted: Sun Oct 27, 2019 11:30 pm     Reply with quote
What PIC are you using?. What pins?. What clock rate?.
OK I've just spotted one error. Made a one line change to the posted code.
micro_debugger
PostPosted: Thu Oct 31, 2019 6:37 am     Reply with quote
Sorry for my late replying.
Just was inside of the IC :-)
I'm using DSPIC33EP512MU810
but PCB received with bug, and now trying to solve it.
They used a wrong pin for SPI1, so the only solution was to use common PIN for SDO and SDI as software SPI is too slow for this.
BAUD=16000000
#define FRAM_HOLD_PIN      PIN_A14
#define FRAM_WP_PIN         PIN_A5
#define FRAM_SELECT_PIN    PIN_A15
#define FRAM_CLK_PIN       PIN_F1
#define FRAM_SDI_PIN       PIN_G1      //MOSI
#define FRAM_SDO_PIN       PIN_G1      //MISO
#pin_select REFCLK = PIN_G13
/////////////// SPI Set-up START ////////////////
#pin_select SCK1OUT      =    PIN_F1            //DSP Pin 66
#pin_select SDI1        =    PIN_G1             //DSP Pin 68  MOSI1 DO PIN_G7
#pin_select SDO1        =    PIN_G1             //DSP Pin 67 MISO1 DI PIN_G6
#use spi(MASTER, SPI1, FORCE_HW, MODE=0, BITS=8, SAMPLE_RISE, MSB_FIRST, BAUD=16000000, stream=FRAM_STREAM)
Soon will be back to you with positive news (hope and wish).
BR
PostPosted: Thu Oct 31, 2019 7:30 am     Reply with quote
That is going to give you major issues.
Problem is SDO drives the pin, so data can't be received on it from the chip.
You are going to see unwanted heating when both chips try to drive, and
going to have to change the TRIS explicitly in the code whenever data
actually wants to be read. I have a nasty suspicion it is not going to work.
Honestly better to cut the 'wrong' track and make a hardware bodge.
micro_debugger
PostPosted: Thu Oct 31, 2019 7:59 am     Reply with quote
OK. Thank you, taking my knife for action and microscope
soon back to you
micro_debugger
PostPosted: Thu Oct 31, 2019 8:44 am     Reply with quote
Found that F8 is used as test point, so easy to solder a wire, as to 100 pins TQFP is very difficult to solder anything on pins, so isolated the FRAM SO, but pushing it up, and solder a bridge to F8, checking now.
BR
PostPosted: Thu Oct 31, 2019 8:56 am     Reply with quote
I've learnt the 'delights' of making changes to SM chips. Found it worth
bringing anything I've not already debugged to a patch area near the chip
when laying out the PCB. Saves a lot of grief....
Page 1 of 3
