I need to run Timer 1, not the core, from an external 32KHz low power crystal so I have a crystal on pins 47 and 48 (RC13/RC14) with 27pF capacitors to ground.
As a comment, you do not want SYNC, if this is going to be used when
the chip is in sleep mode. Since you have selected to run when IDLE,
it suggests you do. Understand that SYNC syncronises to the master
oscillator, which won't be available when 'IDLE'.....
