Reset PIC Method
art
Reset PIC Method
PostPosted: Sun Jul 14, 2019 8:09 am     Reply with quote
I would like to know is there is any method to reset PIC by coding ?
Normally people will connect MCLR pin of PIC to ground.
Hope someone can share their ideas or codes.
Thank you
Mike Walne
PostPosted: Sun Jul 14, 2019 8:51 am     Reply with quote
I don't know which PIC you're using.
The PIC manual shows a software reset instruction for PIC18(L)F2X/4XK22 type chips, and presumably most others.
There SHOULD be something similar in the CCS manual.
If not use the machine code instruction in assembler.
Mike
PS I found it. The CCS version seems to be reset_cpu().
art
PostPosted: Mon Jul 15, 2019 6:00 am     Reply with quote
Thank you mike,
I'm using pic18f4550. I really hope reset_cpu() works.
PostPosted: Mon Jul 15, 2019 6:50 am     Reply with quote
reset_cpu, issues the processor's own reset instruction.
Understand that this gives a different code from 'restart_cause', than
a power on reset (POR).
It also boots quicker than a POR, not giving any oscillator delay (since this
is already running).
Some bits are left unchanged by the reset instruction. For instance
STKFUL and STKUNF are both 'unchanged' by this reset, but are clear
after a POR. Look at the table entitled:
STATUS BITS, THEIR SIGNIFICANCE AND THE INITIALIZATION CONDITION
FOR RCON REGISTER
in the data sheet. This and the next table detail what is reset and what is left
unchanged.
