quichedood
Show a value on lcd, got a "/" :( |
Posted: Mon Feb 02, 2004 3:09 pm |
hi everybody,
i'm new to ccs, and i try to realize my project.
i've done some functions who works but i'm locked on something who looks very easy :p
so here a part of my code :
int temperature;
char mystring[21];
//send a char to lcd
void send_char(char str_eight){
output_high(LCD_RS);
trait_eight = align1(str_eight);
OUTPUT_A (trait_eight);
enable_lcd();
trait_eight = align2(str_eight);
enable_lcd();
//Send a value to lcd
void send_value(int value){
sprintf(mystring,"%u",value);
send_char(mystring);
temperature = 65;
send_value(temperature);
ok so here is the problem the function "send_char" works fine
example : send_char("test"); -> "test" is writtent on my lcd
BUT, now i would like to show the content of "temperature" (who's 65)
so i use the other function : "send_value" but that write a "/" on my lcd.
if someone could help me it would be great
(sorry for my english, but i think you can understand )
DooD |
Re: Show a value on lcd, got a "/" :( |
Posted: Mon Feb 02, 2004 4:38 pm |
quichedood wrote: | hi everybody,
int temperature;
char mystring[21];
enable_lcd();
enable_lcd();
temperature = 65;
DooD |
This is not a CCS problem, but a general 'C' one...
The function 'send_char', expects to receive a single character. It only works with the 'constant' string 'test', because CCS has a 'shortcut', that if a constant string is handed to a function expecting single characters, it will automatically call the function repeatedly to send the individual characters. When you call the function with 'mystring', the _address_ of the RAM string is handed to the function, which happens to display as a '/'...
You can work two different ways. The first is to write 'send_string' function, that takes the address, and steps through the characters one by one, till it sees the end of string ('/0') marker, so:
void send_string(char *str) {
while (*str!='\0') send_char(*str++);
Then call this instead of send_char inside send_value.
or simply use printf, rather than sprintf (which supports sending the output to a function, rather than to a string), so:
printf(send_char,"%u",value);
You then don't need 'mystring' at all.
quichedood
Posted: Tue Feb 03, 2004 2:53 pm |
thanks a lot for your reply ... but it doesn't work anyway :D
here is the code :
Code: | //Send a string to lcd
while (*str!='\0') {
send_char(*str++);
void send_value(int value) {
printf([b]send_string[/b],"%u",value);
the text in bold is a little correction of what you give me (good isn't it ?)
so if anyone have an idea... I will look at it tonight, i'll keep you informed if something works
EDIT : for value=65 it write "q q" on lcd if it can help someone
(not real "q" that's the letter who correspond to this char code : 11100111)
http://home.iae.nl/users/pouweha/lcd/lcd.shtml
EDIT2 ( ) : send_string function doen't work correctly (when using it without send_value function) |
quichedood
Posted: Tue Feb 03, 2004 3:46 pm |
ok so here is my result :p
with that code :
Code: | //Envoi d'une chaine au lcd
send_char(*str++);
//Envoi une valeure au lcd
send_string(mystring);
sending a value works great (thx !!!)
sending a string using send_char works
sending a string using send_string doesn't work
so why the last one doesn't work ? it should no ? |
quichedood
Posted: Tue Feb 03, 2004 4:15 pm |
little screenshot
but sending a string using send_string doesn't work better |
Posted: Tue Feb 03, 2004 4:30 pm |
quichedood wrote: | ok so here is my result :p
with that code :
send_char(*str++);
You are misunderstanding what I posted.
The second example I gave, was an _alternative_ to the first.
You can just use:
The printf function, will call the function given as the first variable, for each character in turn. The 'send_string' routine, was designed to take a string input, if you needed/wanted to do it this way. The printf example would work as posted. Your 'modification', is _wrong_, because the 'send_string' function, expects to receive the _address_ of a string, while the function used by printf, is expected to receive a single character. You are repeating the same mistake...
quichedood
Posted: Wed Feb 04, 2004 2:50 pm |
oops sorry, i re-test like you said and all it's ok
so thx a lot once more for the solution and all your explications !
i'll maybe come back later on this forum, very usefull
see you later.
DooD |
