How to read a specific bit of a register?
chingB
PostPosted: Mon Feb 02, 2004 5:50 pm     Reply with quote
How can I be able to read a specific bit of a register? I want to know if it is a 1 or 0?
Like the case of LVDCON register were the bit IRVST can't be set but it can be read?
Need your help? thanx
PostPosted: Mon Feb 02, 2004 6:16 pm     Reply with quote
Use a #bit statement to define the bit as a memory variable.
Then read it or write it, just like a variable. See how CCS
does this for the "t1_overflow" bit in the ex_freqc.c file:
http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_freqc.c
Then check the PIC data sheet to find the address and bit number
of the LVDCON register and the IRVST bit, and do it the same way.
Darren Rook
Re: How to read a specific bit of a register?
PostPosted: Mon Feb 02, 2004 6:17 pm     Reply with quote
chingB wrote:
How to test file 0x10, bit 1:
bit_test(*0x10,1)
This function will return TRUE (1) or FALSE (0) depending on the bit.
EDIT: PCM's method is good too. He beat me to the reply. Surprised
h
PostPosted: Tue Feb 03, 2004 5:34 am     Reply with quote
which method requires less memory?
Neutone
PostPosted: Tue Feb 03, 2004 8:01 am     Reply with quote
Try both and look them over in the list file to see if they are different. Sometimes changing syntax reduces code size.
Mark
PostPosted: Tue Feb 03, 2004 8:32 am     Reply with quote
Usually the same amount of memory.
