bootloader
SeeCwriter
bootloader
PostPosted: Mon Jun 03, 2019 10:02 am     Reply with quote
I'm using the bootloader example program from a few years ago on a new project, and it works fine. So I took a look at the same program in the current release (5.085) to see if there were any changes I needed to be aware of. And I noticed is a difference in the #org statement for the application function. In the older version, application is given 2-bytes of memory, while the v5.085 version is given 1-byte. Is that correct?
Old version:
#org LOADER_END+2, LOADER_END+4
void application(void) {
  while(TRUE);
New version:
#org LOADER_END+1,LOADER_END+2
  while(TRUE);
PostPosted: Mon Jun 03, 2019 10:47 am     Reply with quote
while I don't use them, I think it's based on which PIC series you're using....
Jay
PostPosted: Mon Jun 03, 2019 12:29 pm     Reply with quote
See this thread. Notice the #if and #elif:
http://www.ccsinfo.com/forum/viewtopic.php?t=57983
SeeCwriter
PostPosted: Mon Jun 03, 2019 2:41 pm     Reply with quote
That post was helpful. It's interesting that the example program as installed does not have that #if..#else statement to set #org. And neither did the version of the example file that the poster posted in his message. If I were using a PIC16, I would have gotten a compiler error and been asking the same questions as the poster.
