Does the debugger require #list to work? Because the debugger (v5.085) gives me error "cannot resolve address at line 37" when #nolist is present and I try to step or run to code after #nolist.
#nolist
int somefunc()
int a, b;
return a+b;
Posted: Wed May 22, 2019 11:56 pm
Yes.
nolist, says 'do not generate assembler listing'. The debugger uses this.
So turning off the listing, turns off the ability to debug.
SeeCwriter
Posted: Thu May 23, 2019 10:26 am
I thought the listing was just information for the programmer.
Thanks.
Posted: Thu May 23, 2019 10:42 am
No. The debugger doesn't perform disassembly. What it displays comes
directly from the .lst file.
