rolf_edmundo_guse
Driver for a 128x64 graphic lcd with the ST7920 chip |
Posted: Sat Apr 27, 2019 6:30 am |
rolf_edmundo_guse wrote: | I'm new to this forum and I apologize if you're posting something wrong.
I'm struggling to find library glcd 128x64 drive st7920 someone would use pic18f87k22 |
After much work the library is working very well I am sharing mode 8bit mode 4 bit pin
ST7920.h
* DRIVE PARA LCD GRAFICO 128X64 CHIP ST7920 *
* COMANDOS *
* #define mode_8_bit user lcd mode 8 bit
* #define mode_4_bit user lcd mode 4 bit
* glcd_readByte()//LER DADOS DO LCD *
* glcd_check_busy()//VERIFICA SE LCD ESTA OCUPADO * *
* glcd_instruction(instruções)//SETA INTRUÇÕES *
* glcd_data(dados)//ENVIA DADOS PARA LCD *
* glcd_init_basic()//INICIA LCD COMO MODO BASICO *
* glcd_update()//ATUALIZA LCD *
* glcd_init_graph()//INICIA LCD MODO GRAFICO *
* glcd_pixel( x, y, color)//CONTROLE DE PIXEL *
* glcd_fillScreen(on)//ENVIO NIVEL 1 PARA TODOS OS PIXEL DO LCD *
* glcd_fillScreen(off)//ENVIA NIVEL 0 PARA TODOS OS PIXEL DO LCD *
* glcd_plot_image(imagem,largura,altura,coluna,linha,cor) carrega imagem *
* PINAGEM DO LCD *
* Pin 1 ------------> Gnd *
* Pin 2 ------------> +5volts *
* Pin 3 ------------> Contrast *
* Pin 4 ------------> Register Select *
* Pin 5 ------------> Read/Write *
* Pin 6 ------------> Enable *
* Pin 7-14 ---------> Data bits *
* Pin 15 -----------> PSB (parallel=high & serial=low) *
* Pin 16 -----------> NoConnection *
* Pin 17 -----------> Reset *
* Pin 18 -----------> Vout *
* Pin 19 -----------> +5volts *
* Pin 20 -----------> Gnd *
//DEFINIÇÃO DE PINOS
//PIN DEFINITION
#define RS PIN_B2 //COMMNAD/DATA SELECT
#define RW PIN_B3 //READ/WRITE SELECT
#define E PIN_B4 //ENABLE SIGNAL
#define RST PIN_B5 //RESET SIGNAL
#if defined(mode_8_bit)// define pin lcd 8 bit
#define D0 PIN_D0
#define D1 PIN_D1
#define D2 PIN_D2
#define D3 PIN_D3
#define D4 PIN_D4
#define D5 PIN_D5
#define D6 PIN_D6
#define D7 PIN_D7
#define mode 0x10
#if defined(mode_4_bit)// define pin lcd 4 bit
#define D4 PIN_D4
#define D5 PIN_D5
#define D6 PIN_D6
#define D7 PIN_D7
#define mode 0x00
#define set_lcd_bit 0x20 | (mode) //mode 4 bit
#define ext_instru 0x24 | (mode) //Select extended instruction set
#define graphic_on 0x26 | (mode) // Graphic display ON.
#define set_lcd_on 0x0C //display on cursor off and char blink off
#define set_mode_lcd 0x06 //entry mode set
#define clear_lcd 0x01 //display clear
#define DADOS_IN INPUT_D()
#define BUSY_IN PIN_D7
#define ON 1
#define OFF 0
//LCD GRAPHICO 128X64
#define YVAL 64 // DEFINE 64 LINHAS
#define XVAL 8 // DEFINE COLUNAS 8X16=128 COLUNAS
#define GLCD_WIDTH 128 //DEFINE 128 COLUNAS
typedef union
int16 word;
int8 nbyte[2];
} Dots;
typedef struct
int1 refresh;
Dots pix[YVAL][XVAL]; // Max dimensions for display (x,y) = (128,32)
} GD_RAM; // (0,0) corresponds to upper lefthand corner.
GD_RAM gdram;
unsigned int8 glcd_readByte (unsigned int1 address)//LER BYTE DO LCD
unsigned int8 data; // Stores the data read from the LCD
if(address==1)
output_high(rs);
if(address==0)
output_low(rs);
output_high(rw);//GLCD_RW = RW_READ; // Set for reading
output_high(e);//GLCD_E = 1; // Pulse the enable pin
delay_us(1);
data=DADOS_IN; // Get the data from the display's output register
output_low(e);//GLCD_E = 0;
return (data);
void glcd_check_busy()//VERIFICA SE LCD ESTA OCUPADO
int1 busy=1;
output_low(rs); // LOW RS and High RW will put the lcd to
output_high(rw); // read busy flag and address counter
while(busy)
{ // will cycle until busy flag is 0
output_high(e);
if(!input(BUSY_IN))
busy=0;
output_low(e);
void glcd_instruction(unsigned char x)//ENVIA INSTRUÇÕES PARA LCD
#if defined(mode_8_bit)// 8 bit mode
glcd_check_busy(); //must be satisfied before sending instruction
output_low(rs); // LOW RS and LOW RW will put the lcd to
output_low(rw); // Write instruction mode
Delay_us(5); //Delay
output_bit(D7,bit_test(x,7)); //send data bit 7 pin D7
output_bit(D6,bit_test(x,6)); //send data bit 6 pin D6
output_bit(D5,bit_test(x,5)); //send data bit 5 pin D5
output_bit(D4,bit_test(x,4)); //send data bit 4 pin D4
output_bit(D3,bit_test(x,3)); //send data bit 3 pin D3
output_bit(D2,bit_test(x,2)); //send data bit 2 pin D2
output_bit(D1,bit_test(x,1)); //send data bit 1 pin D1
output_bit(D0,bit_test(x,0)); //send data bit 0 pin D0
Delay_us(10);
output_high(e);//anable
Delay_us(20);
output_low(e);// disable
#if defined(mode_4_bit) // 4 bit mode
Delay_us(5);//Delay
Delay_us(5);
output_high(e); //enable
Delay_us(5);
output_low(e); //disable
Delay_us(5);
output_bit(D7,bit_test(x,3));//send data low bit 3 pin D7
output_bit(D6,bit_test(x,2));//send data low bit 2 pin D6
output_bit(D5,bit_test(x,1));//send data low bit 1 pin D5
output_bit(D4,bit_test(x,0));//send data low bit 0 pin D4
Delay_us(5);
output_high(e);
Delay_us(5);
output_low(e); // disable
void glcd_data(unsigned char x)//ENVIA DADOS PARA LCD
#if defined(mode_8_bit) // 8 bit mode
glcd_check_busy();
output_high(rs); // HIGH RS and LOW RW will put the lcd to
output_low(rw); // Write data register mode
Delay_us(5);
Delay_us(10);
output_high(e);
Delay_us(20);
glcd_check_busy();
Delay_us(5);
output_bit(D7,bit_test(x,7));//send data high bit 7 pin D7
output_bit(D6,bit_test(x,6));//send data high bit 6 pin D6
output_bit(D5,bit_test(x,5));//send data high bit 5 pin D5
output_bit(D4,bit_test(x,4));//send data high bit 4 pin D4
Delay_us(5);
output_high(e);
Delay_us(5);
Delay_us(5);
Delay_us(5);
output_high(e);
Delay_us(5);
void glcd_fillScreen (unsigned int1 color)//GRAVA 1 OU 0 EM TODOS OS PIXEL
int8 v, h;
int16 d;
d = (color == ON ? 0xFFFF : 0x0000);
// d = (color == ON ? 0x0000 : 0xFFFF );
for (v=0; v < YVAL; v++)//32
for (h=0; h < XVAL; h++)//16
gdram.pix[v][h].word = d;
gdram.refresh = TRUE;
void glcd_update ()//ATUALIZA LCD
int8 v, h;
if (gdram.refresh)//verifica se foi atualizado
for (v=0; v <YVAL; v++) //64 linhas
if(v<32)
glcd_instruction( 0x80 | v); // Set Vertical Address.
glcd_instruction( 0x80); // Set Horizontal Address.
glcd_instruction( 0x80 | (v - 32)); // Set Vertical Address.
glcd_instruction( 0x88); // Set Horizontal Address.
for (h=0; h <XVAL; h++) //8x16=128 colunas
glcd_data( gdram.pix[v][h].nbyte[1]); // Write High Byte.
glcd_data( gdram.pix[v][h].nbyte[0]); // Write Low Byte.
gdram.refresh = FALSE;
void glcd_init_graph()//INICIA EM MODO GRAPHICO
delay_ms(40);
output_low(rst); //reset LCD
delay_us(1);
output_high(rst); //LCD normal operation
glcd_instruction(set_lcd_bit); //set 4 and 8 bit operation and basic instruction set
delay_us(144);
glcd_instruction(0x0C); //display on cursor off and char blink off
delay_us(100);
glcd_instruction(clear_lcd); //display clear
delay_ms(10);
glcd_instruction(set_mode_lcd); //entry mode set
delay_us(72);
glcd_instruction(ext_instru); // Select extended instruction set.
delay_us (72);
glcd_instruction(graphic_on); // Graphic display ON.
delay_us (72);
glcd_fillScreen (OFF); // clear all pixel
glcd_update (); // update display
void glcd_init_basic()//INICIA EM MODO BASICO
delay_ms(40);
delay_us(1);
glcd_instruction(set_lcd_bit); //set 4 bit operation and basic instruction set
delay_us(144);
delay_us(100);
delay_ms(10);
delay_us(72);
// 0 0 0
void glcd_pixel(int8 x, int8 y, int1 color)//GRAVA NOVO VALOR DOS PIXEL
int8 v, h, b;
v = y;
h = x/16;
b = 15 - (x%16);
if (color == ON)
bit_set (gdram.pix[v][h].word, b);
bit_clear (gdram.pix[v][h].word, b);
void glcd_plot_image(ROM char *img,int width,int height,int x,int y,int inverse)//CARREGA IMAGEM
unsigned int i=0, j=0, k=0;
unsigned int16 count=0;
//glcd_fillScreen(OFF); //Clears the screen (opt.)
for(j=0;j<height;j++)//linhas
for(;i<width;)//colunas
for(k=0;k<8;k++)//bite
if(inverse)
{// 0 ,0 ,
glcd_pixel(i+x,j+y,~bit_test(img[count],(k)));
glcd_pixel(i+x,j+y,bit_test(img[count],(k)));
i++;
count++;
i=0;
Last edited by rolf_edmundo_guse on Sun May 19, 2019 3:47 pm; edited 1 time in total |
rolf_edmundo_guse
klebaum
Very good !! |
Posted: Thu May 02, 2019 8:52 am |
Congratulations for your work.
Can you also use this display in serial mode?
See you. |
rolf_edmundo_guse
Re: Very good !! |
Posted: Sun May 19, 2019 3:34 pm |
klebaum wrote: | Congratulations for your work.
See you. |
Hello, at the moment I did not realize a library in serial mode, only in 8-bit and 4-bit. |
MarkchchPIC
Joined: 14 Jan 2015 Posts: 18 Location: Christchurch New Zealand
Great Work |
Posted: Mon May 20, 2019 2:44 pm |
Hi there,
Driver looks very good.
Can you provide an example to show the setup you have used.
Cheers
Mark |
rolf_edmundo_guse
Re: Great Work |
Posted: Mon May 20, 2019 7:46 pm |
MarkchchPIC wrote: | Hi there,
Cheers
Mark |
exemple code user main.c
#include <18F87K22.h>
#device ADC=16
#define mode_4_bit //define glcd 4 bit mode
#use delay(CLOCK=64M, CRYSTAL=16M)
#include "imagem.h"
#include "st7920.h"
#include "graphics.c"
#include <math.h>
int16 adc;
float media_adc;
const unsigned char TAB[]={'T','E','S','T','E','-','O','K'};
void Voltage()
set_adc_channel(0);
adc = read_adc();
media_adc = ((adc*.07554945)/1000);
char voltage[9];
sprintf(voltage, "%.2f", (float)media_adc); // Converts adc to text
//sprintf(voltage, "%Lu",(int16)read_adc());
voltage[5] = '\0'; // Limit shown digits to 5
voltage[4] = 'V';
glcd_rect(11, 0, 50, 8, yes, on);
glcd_text57(12, 1, voltage, 1, off);//printf
void mode_basic()//glcd mode basic
glcd_init_basic(); //init glcd basic
glcd_instruction(clear_lcd);// clear glcd
for(int i=0;i<8;i++)
glcd_data(TAB[i]);//printf glcd mode text
Delay_ms(500);
void mode_graphic()
glcd_init_graph();//glcd modo graphico
glcd_fillScreen(OFF);//clear glcd
for(int cont=0; cont<200; cont++)
glcd_plot_image(antena,11,9,0,0,1);//imagem, comprimento, altura, coluna, linha, cor
glcd_plot_image(trator,11,9,0,18,0);//imagem, comprimento, altura, coluna, linha, cor
glcd_plot_image(bico_on,11,9,64,0,0);//imagem, comprimento, altura, coluna, linha, cor
glcd_plot_image(fluxometro,11,9,64,18,0);//imagem, comprimento, altura, coluna, linha, cor
glcd_plot_image(barra,128,5,0,49,0);//imagem, comprimento, altura, coluna, linha, co
glcd_plot_image(bico_off,11,9,0,54,1);//imagem, comprimento, altura, coluna, linha, cor
glcd_plot_image(bico_on,11,9,59,54,0);//imagem, comprimento, altura, coluna, linha, cor
glcd_plot_image(bico_on,11,9,115,54,0);//imagem, comprimento, altura, coluna, linha, cor
voltage();//read ad chanel 0
glcd_update();//update glcd
// Delay_ms(5);
void main ()
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_4);
set_adc_channel(0);
glcd_fillScreen(off);// glcd clear full pixel 0
glcd_update();// glcd update
glcd_plot_image(logo_inicio,128,64,0,0,0);//imagem,width,height,columm,line,color pixel
Delay_ms(2000);//Delay
mode_basic();
mode_graphic();
imagem.h
//imagem 11x9 antena
ROM char antena[]={
0x00, 0x00, 0xFC, 0x01, 0x02, 0x02, 0xF9, 0x04,
0x04, 0x01, 0x72, 0x02, 0x88, 0x00, 0x20, 0x00,
0x00, 0x00
//imagem 11x9 bateria
ROM char bateria[]={
0x04, 0x00, 0x8E, 0x03, 0x04, 0x00, 0xFE, 0x03,
0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02,
0xFE, 0x03};
//imagem 11x9 bico ligado
ROM char bico_on[]={
0xF8, 0x00, 0xF8, 0x00, 0x70, 0x00, 0x20, 0x00,
0x50, 0x00, 0xA8, 0x00, 0x54, 0x01, 0xAA, 0x02,
0x55, 0x05};
//imagem 11x9 bico desligado
ROM char bico_off[]={
0x88, 0x00, 0x50, 0x00, 0x20, 0x00, 0x50, 0x00,
0x88, 0x00};
//imagem 128x5 barra
ROM char barra[]={
0x00, 0xFE, 0xBF, 0xFF, 0xFF, 0xFB, 0xFF, 0xFF,
0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xFD, 0x7F, 0x00,
0x80, 0x11, 0xF1, 0x11, 0x11, 0x1F, 0x86, 0x61,
0x86, 0x61, 0xF8, 0x88, 0x88, 0x8F, 0x88, 0x01,
0x60, 0xAA, 0xAA, 0xAA, 0xAA, 0x2A, 0x49, 0x92,
0x49, 0x92, 0x54, 0x55, 0x55, 0x55, 0x55, 0x06,
0x18, 0x44, 0xE4, 0x44, 0x44, 0xCE, 0x30, 0x8C,
0x31, 0x0C, 0x73, 0x22, 0x22, 0x27, 0x22, 0x18,
0xFC, 0xFF, 0xBF, 0xFF, 0xFF, 0xFB, 0xFF, 0xFF,
0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xFD, 0xFF, 0x3F};
//imagem 11x9 trator
ROM char trator[]={
0x00, 0x00, 0x1E, 0x00, 0x92, 0x00, 0x92, 0x00,
0xFE, 0x03, 0xFB, 0x07, 0xF1, 0x03, 0x9B, 0x02,
0x8E, 0x03};
//imegem 11x9 fluxometro
ROM char fluxometro[]={
0xF8, 0x00, 0x24, 0x01, 0xAA, 0x02, 0x72, 0x02,
0xDE, 0x03, 0x72, 0x02, 0xAA, 0x02, 0x24, 0x01,
0xF8, 0x00};
ROM char logo_inicio[]={
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0,
0x0F, 0x00, 0xFC, 0xFF, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
0x10, 0x00, 0xFE, 0xFF, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xF8,
0x3F, 0x00, 0xFE, 0xFF, 0x03, 0x00, 0x00, 0x00,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0xC5, 0x07,
0x40, 0x00, 0x1E, 0x80, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
0x40, 0x00, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0xC0, 0x00, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0x40, 0x01, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0x40, 0x02, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0x40, 0x04, 0xFE, 0xFF, 0xFF, 0xFF, 0x07, 0x00,
0x40, 0x08, 0xFE, 0xFF, 0xFF, 0xFF, 0x0F, 0x00,
0x40, 0x10, 0xFE, 0xFF, 0x07, 0x80, 0x0F, 0x00,
0x40, 0x20, 0x1E, 0xFC, 0xFF, 0xFF, 0x0F, 0x00,
0xC0, 0xFF, 0x07, 0xF0, 0xFF, 0xFF, 0x0F, 0x00,
0x40, 0x20, 0x01, 0xC0, 0xFF, 0xFF, 0xFF, 0x03,
0x40, 0x10, 0x01, 0xC0, 0xFF, 0xFF, 0xFF, 0x07,
0x40, 0x88, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0x07,
0x40, 0x84, 0xC0, 0x81, 0xFF, 0xFF, 0x83, 0x00,
0x40, 0x42, 0x20, 0x02, 0xFF, 0xFF, 0x01, 0x01,
0x40, 0x41, 0x90, 0x04, 0xFF, 0xFF, 0x38, 0x02,
0xC0, 0x40, 0x50, 0x05, 0xFF, 0x7F, 0x44, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC4,
0x43, 0x40, 0x90, 0x04, 0x01, 0x40, 0x82, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24,
0x44, 0x40, 0x20, 0x02, 0x01, 0x40, 0x92, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x14,
0x48, 0x80, 0xC0, 0x81, 0x00, 0x40, 0x82, 0x04,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0xC5, 0x8F,
0x51, 0x00, 0x01, 0x40, 0x00, 0x40, 0x44, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x4C,
0x32, 0x00, 0x01, 0x40, 0x00, 0x80, 0x38, 0x02,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48,
0x12, 0x00, 0x06, 0x30, 0x00, 0x00, 0x01, 0x01,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88,
0x11, 0x00, 0x18, 0x0C, 0x00, 0x00, 0x82, 0x00,
0x08, 0x00, 0xE0, 0x03, 0x00, 0x00, 0x7C, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0,
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
graphic.c
//// graphics.c ////
//// This file contains functions to draw lines, rectangles, bars, ////
//// circles and text to a display. A function which draws a ////
//// single pixel must be defined before calling the functions in ////
//// this file. Call it glcd_pixel(x, y, color) where x is the ////
//// horizontal coordinate, y is the vertical coordinate, and ////
//// color is 1 bit to turn the pixel on or off. ////
//// * Note: (0, 0) is treated as the upper left corner ////
//// glcd_line(x1, y1, x2, y2, color) ////
//// * Draws a line from the first point to the second point ////
//// with the given color ////
//// - color can be ON or OFF ////
//// glcd_rect(x1, y1, x2, y2, fill, color) ////
//// * Draws a rectangle with one corner at point (x1,y1) and ////
//// the other corner at point (x2,y2) ////
//// - fill can be YES or NO ////
//// glcd_bar(x1, y1, x2, y2, width, color) ////
//// * Draws a bar (wide line) from the first point to the ////
//// second point ////
//// - width is the number of pixels wide ////
//// - color is ON or OFF ////
//// glcd_circle(x, y, radius, fill, color) ////
//// * Draws a circle with center at (x,y) ////
//// glcd_text57(x, y, textptr, size, color) ////
//// * Write the null terminated text pointed to by textptr with ////
//// the upper left coordinate of the first character at (x,y) ////
//// Characters are 5 pixels wide and 7 pixels tall ////
//// - size is an integer that scales the size of the text ////
//// * Note - This function wraps characters to the next line ////
//// use #define GLCD_WIDTH to specify a display width ////
//// (C) Copyright 1996, 2010 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#ifndef GRAPHICS_DRAWING_FUNCTIONS
#define GRAPHICS_DRAWING_FUNCTIONS
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
#ifndef YES
#define YES 1
#ifndef NO
#define NO 0
//// Defines a 5x7 font
const unsigned int8 FONT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x04, 0x02, 0x7F, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76};// R
const unsigned int8 FONT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x41, 0x41, 0x36, 0x08, 0x00, // }
0x02, 0x01, 0x02, 0x04, 0x02};// ~
// Purpose: Draw a line on a graphic LCD using Bresenham's
// line drawing algorithm
// Inputs: (x1, y1) - the start coordinate
// (x2, y2) - the end coordinate
// color - ON or OFF
// Dependencies: glcd_pixel()
#ifdef LARGE_LCD
void glcd_line(unsigned int16 x1, unsigned int16 y1, unsigned int16 x2, unsigned int16 y2, int1 color)
#else
void glcd_line(unsigned int8 x1, unsigned int8 y1, unsigned int8 x2, unsigned int8 y2, int1 color)
unsigned int16 dy, dx;
signed int8 addx=1, addy=1;
signed int16 P, diff;
#ifdef LARGE_LCD
unsigned int16 i=0;
dx = abs((signed int16)(x2 - x1));
dy = abs((signed int16)(y2 - y1));
#else
unsigned int8 i=0;
dx = abs((signed int8)(x2 - x1));
dy = abs((signed int8)(y2 - y1));
if(x1 > x2)
addx = -1;
if(y1 > y2)
addy = -1;
if(dx >= dy)
dy *= 2;
P = dy - dx;
diff = P - dx;
for(; i<=dx; ++i)
glcd_pixel(x1, y1, color);
if(P < 0)
P += dy;
x1 += addx;
P += diff;
x1 += addx;
y1 += addy;
dx *= 2;
P = dx - dy;
diff = P - dy;
for(; i<=dy; ++i)
if(P < 0)
P += dx;
y1 += addy;
P += diff;
x1 += addx;
y1 += addy;
// Purpose: Draw a rectangle on a graphic LCD
// fill - YES or NO
// Dependencies: glcd_pixel(), glcd_line()
#ifdef LARGE_LCD
void glcd_rect(unsigned int16 x1, unsigned int16 y1, unsigned int16 x2, unsigned int16 y2, int1 fill, int1 color)
#else
void glcd_rect(unsigned int8 x1, unsigned int8 y1, unsigned int8 x2, unsigned int8 y2, int1 fill, int1 color)
if(fill)
#ifdef LARGE_LCD
unsigned int16 i, xmin, xmax, ymin, ymax;
#else
unsigned int8 i, xmin, xmax, ymin, ymax;
if(x1 < x2) // Find x min and max
xmin = x1;
xmax = x2;
xmin = x2;
xmax = x1;
if(y1 < y2) // Find the y min and max
ymin = y1;
ymax = y2;
ymin = y2;
ymax = y1;
for(; xmin <= xmax; ++xmin)
for(i=ymin; i<=ymax; ++i)
glcd_pixel(xmin, i, color);
glcd_line(x1, y1, x2, y1, color); // Draw the 4 sides
glcd_line(x1, y2, x2, y2, color);
glcd_line(x1, y1, x1, y2, color);
glcd_line(x2, y1, x2, y2, color);
// Purpose: Draw a bar (wide line) on a graphic LCD
// width - The number of pixels wide
#ifdef LARGE_LCD
void glcd_bar(unsigned int16 x1, unsigned int16 y1, unsigned int16 x2, unsigned int16 y2, unsigned int8 width, int1 color)
#else
void glcd_bar(unsigned int8 x1, unsigned int8 y1, unsigned int8 x2, unsigned int8 y2, unsigned int8 width, int1 color)
unsigned int8 half_width;
signed int8 addx=1, addy=1, j;
signed int16 P, diff, c1, c2;
#ifdef LARGE_LCD
unsigned int16 i=0;
#else
unsigned int8 i=0;
half_width = width/2;
c1 = -(dx*x1 + dy*y1);
c2 = -(dx*x2 + dy*y2);
if(x1 > x2)
signed int16 temp;
temp = c1;
c1 = c2;
c2 = temp;
addx = -1;
if(y1 > y2)
signed int16 temp;
temp = c1;
c1 = c2;
c2 = temp;
addy = -1;
if(dx >= dy)
P = 2*dy - dx;
diff = P - dx;
for(i=0; i<=dx; ++i)
for(j=-half_width; j<half_width+width%2; ++j)
glcd_pixel(x1, y1+j, color);
if(P < 0)
P += 2*dy;
x1 += addx;
P += diff;
x1 += addx;
y1 += addy;
P = 2*dx - dy;
diff = P - dy;
for(i=0; i<=dy; ++i)
if(P < 0)
P += 2*dx;
y1 += addy;
P += diff;
x1 += addx;
y1 += addy;
glcd_pixel(x1+j, y1, color);
// Purpose: Draw a circle on a graphic LCD
// Inputs: (x,y) - the center of the circle
// radius - the radius of the circle
// fill - YES or NO
#ifdef LARGE_LCD
void glcd_circle(unsigned int16 x, unsigned int16 y, unsigned int16 radius, int1 fill, int1 color)
#else
void glcd_circle(unsigned int8 x, unsigned int8 y, unsigned int8 radius, int1 fill, int1 color)
#ifdef LARGE_LCD
signed int16 a, b, P;
#else
signed int8 a, b, P;
a = 0;
b = radius;
P = 1 - radius;
do
if(fill)
glcd_line(x-a, y+b, x+a, y+b, color);
glcd_line(x-a, y-b, x+a, y-b, color);
glcd_line(x-b, y+a, x+b, y+a, color);
glcd_line(x-b, y-a, x+b, y-a, color);
glcd_pixel(a+x, b+y, color);
glcd_pixel(b+x, a+y, color);
glcd_pixel(x-a, b+y, color);
glcd_pixel(x-b, a+y, color);
glcd_pixel(b+x, y-a, color);
glcd_pixel(a+x, y-b, color);
glcd_pixel(x-a, y-b, color);
glcd_pixel(x-b, y-a, color);
if(P < 0)
P += 3 + 2 * a++;
P += 5 + 2 * (a++ - b--);
} while(a <= b);
// Purpose: Write text on a graphic LCD
// Inputs: (x,y) - The upper left coordinate of the first letter
// textptr - A pointer to an array of text to display
// size - The size of the text: 1 = 5x7, 2 = 10x14, ...
#ifdef LARGE_LCD
void glcd_text57(unsigned int16 x, unsigned int16 y, char* textptr, unsigned int8 size, int1 color)
#else
void glcd_text57(unsigned int8 x, unsigned int8 y, char* textptr, unsigned int8 size, int1 color)
unsigned int8 j, k, l, m; // Loop counters
unsigned int1 inv=~color;
unsigned int8 pixelData[5]; // Stores character data
//if(color==1)inv=0;
//else inv=1;
for(; *textptr != '\0'; ++textptr, ++x)// Loop through the passed string
if(*textptr < 'S') // Checks if the letter is in the first font array
memcpy(pixelData, FONT[*textptr - ' '], 5);
else if(*textptr <= '~') // Check if the letter is in the second font array
memcpy(pixelData, FONT2[*textptr - 'S'], 5);
memcpy(pixelData, FONT[0], 5); // Default to space
// Handles newline and carriage returns
switch(*textptr)
case '\n':
y += 7*size + 1;
continue;
case '\r':
x = 0;
continue;
if(x+5*size >= GLCD_WIDTH) // Performs character wrapping
x = 0; // Set x at far left position
y += 7*size + 1; // Set y at next position down
for(j=0; j<5; ++j, x+=size) // Loop through character byte data
for(k=0; k < 7; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l < size; ++l) // These two loops change the
{ // character's size
for(m=0; m < size; ++m)
glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
glcd_pixel(x+m, y+k*size+l, inv); // Draws the pixel
#endif |
MarkchchPIC
Thanks |
Posted: Tue May 21, 2019 3:28 pm |
Thanks for the example, Really helpful.
Cheers
Mark |
alfredoBH
Re: Driver for a 128x64 graphic lcd with the ST7920 chip |
Posted: Sun Aug 11, 2019 3:30 pm |
That's really great job.
Can you post the macro definition codes you used in the example you posted?
Thanks!!! |
