Dara Hayes Guest
Declaring Rom Constants |
Posted: Fri Nov 16, 2001 4:22 pm |
Hello
Im new to CCS picc and am using the definition as
given in the FAQ for declaring a few bytes in rom that
I wish to send to an LCD , however the more tables
I add the rom usage stays the same and they all seem
to map in at -009 in the list display
Whats going on , the following compile ok but
dont seem to get into the end result OK
Byte Const TABLE1 [5] = {1,2,3,4,5,0};
___________________________
Original Post ID: 1160 |
Re: Declaring Rom Constants |
Posted: Fri Nov 16, 2001 4:31 pm |
:=I'm new to CCS picc and am using the definition as
:=given in the FAQ for declaring a few bytes in rom that
:=I wish to send to an LCD , however the more tables
:=I add the rom usage stays the same and they all seem
:=to map in at -009 in the list display
:=Whats going on , the following compile ok but
:=dont seem to get into the end result OK
:=Byte Const TABLE1 [5] = {1,2,3,4,5,0};
If you don't access the table with code, the compiler
will not put the table into ROM.
If you only access the table elements individually,
with a numeric array index, the compiler will not put
the table into ROM. Instead, it will create assembly
code that uses the immediate value which corresponds
to the table element. Example:
c = TABLE1[0];
With the above line, you will just see assembly code
which puts the value at index 0 into variable c.
If you want to see the entire table in ROM when you
look at the .LST file, then you must use a variable
as the array index. Example:
for(i = 0; i < 6; i++)
c = TABLE1[i];
If you put in identical tables, the compiler is smart
enough to figure that out, and it will only put one table
into ROM.
Original Post ID: 1161 |
John Goss Guest
Posted: Fri Nov 16, 2001 5:05 pm |
This is the way I do it... It may help,
I store character messages in a group of statements like below:
const char SelfTestMsg[] = {"SELF TESTING...."};
const char NormalMsg[] = {"NORMAL OPERATION"};
Then I also have a function that can write one character to the LCD called: WriteXLCD();
All I now have to do is:
printf(WriteXLCD,"\%S",NormalMsg)
Hope this helps,
John Goss
:=Hello
:=Im new to CCS picc and am using the definition as
:=Thanks
Original Post ID: 1162 |
Dara Hayes Guest
Re: Declaring Rom Constants thanks |
Posted: Sun Nov 18, 2001 6:07 pm |
John ,
that seems to do the trick
many thanks
Dara Hayes
Original Post ID: 1207 |
