Is this a bad one or ICD2 problems
Hans Wedemeyer
PostPosted: Sun Feb 01, 2004 10:47 pm     Reply with quote
Programming 0x0000 to 0X100F everything works, and verifies OK.
When I use more of the chip 0X0000 to 0X300F it fails to vewrify location
0X114 every time.
The error message:
ICD0161: Verify failed (MemType = Program, Address = 0x114, Expected Val = 0xEF80, Val Read = 0x80)
I tried earsing the part
Erasing Target Device...
...Erase Succeeded
And then reading it
Reading...
...Program Memory (0x0 - 0x7FFF)
.. Config Memory
...Read Succeeded
However the program memory is showing 0000 for everything above 0X0200 !
01F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0200 0000 0000 0000 0000 0000 0000 0000 0000
Memory settings for protection are all disabled.
Any idea what the problem is ?
PostPosted: Sun Feb 01, 2004 11:45 pm     Reply with quote
What PIC are you using ?
Hans Wedemeyer
PIC18LF252
PostPosted: Mon Feb 02, 2004 8:33 am     Reply with quote
Chip is bad
PostPosted: Mon Feb 02, 2004 11:13 am     Reply with quote
I built anothh board and it programmed OK.... Removed the SM PIC and replaced it then everything programmed ok.... Bad chip.
