I2C 16F18325
tems
I2C 16F18325
PostPosted: Mon May 06, 2019 2:35 pm     Reply with quote
I want to communicate tfrom an 18f46k22 to an 16f18325 but have difficulty in getting this to work. The code below is in the slave. I can get the interrupt but cannot read any data. Never passes the first read statement.
#include <16F18325.h>
#use delay(internal=32MHz)
#pin_select SDA1=PIN_A4
#pin_select SCL1=PIN_A5
#use i2c(Slave,Fast=400000,sda=PIN_A4,scl=PIN_A5,force_hw,address=0xA0)
int8 B1;
int8 B2;
int8 B3;
int8 B4;
#INT_SSP
void ssp_isr () //I2C interrupt
   int16 state;
   disable_interrupts(global);
   state = i2c_isr_state();
   IF(state < 0x80) //Master is sending data
      While (!i2c_poll()) // whether in or out does the same thing
      IF(state == 0) // // 1st received byte
         B1 = i2c_read(1);
      IF(state == 1) //2nd received byte
         B2 = i2c_read(1);
      IF(state == 2) //3rd received byte
         B3 = i2c_read(1);
      IF(state == 3) //4th
         B4 = i2c_read(0);
   enable_interrupts(global); //Re-enable interrupts
   setup_adc_ports(NO_ANALOGS);
   i2c_init(1);
   clear_interrupt(INT_SSP);
   enable_interrupts(INT_SSP);
Master is this
#include <18F46K22.h>
#device ICD=TRUE
#use delay(clock=32MHz,crystal=8MHz)
#use i2c(Master,Fast=400000,sda=PIN_C4,scl=PIN_C3,force_hw)
#byte SSP1CON2 =0xFC5
#byte SSP1CON1 =0xFC6
#include <test.h>
#ZERO_RAM
void write_pic_generic()
   i2c_start();
   while (bit_test(ssp1con2,0)==1) // wait for start to complete.
   if (i2c_write(0xA0)==0)  // chip address
            if (i2c_write(5)==1) //  value of the data
            if (i2c_write(1)==1) //  value of the data
            if (i2c_write(0)==1) //  value of the data
            if (i2c_write(64)==1) //  value of the data
   i2c_stop();
   int8 i;
   i=0;
   i2c_init(1);
      if (i==0)
         write_pic_generic();
         i++;
I've used i2c scanner and it does find the slave device. What am i missing.
PostPosted: Mon May 06, 2019 3:37 pm     Reply with quote
Start by using the CCS example file, ex_slave.c, instead of your code
above. Change the #include line and other initial lines to fit your board.
Use the code in the following link for the master:
http://www.ccsinfo.com/forum/viewtopic.php?t=32368&start=3
If the hardware is correct, the above test should also work.
This will prove that the test setup is good.
Then start modifying the code to suit your project.
PostPosted: Mon May 06, 2019 11:54 pm     Reply with quote
and one horrible 'no no'. This:
Must _never_ be called inside an interrupt handler.
You do not need to disable interrupts in the handler. The hardware
already does this for you. The interrupts are re-enabled on the return
from the handler. Calling an enable in the handler means the interrupts
are enabled _before_ the code exits the handler. Result can be the
interrupt being called inside itself. Disaster....
