dluu13
How does %w work? |
Posted: Fri Apr 05, 2019 12:22 pm |
I'm using the PIC24FJ128GA204 on Microchip's PIC24 Curiosity dev kit along with CCS PCD 5.082.
I saw a post by Ttelmah a while ago suggesting somebody use the %w format specifier with int32's to avoid using floats.
However, when I try to use it, I get seemingly nonsensical output, with numbers that don't match up.
For example, here is my main function:
Code: | int main(void)
uint32_t test1 = 18;
uint32_t test2 = 123;
uint32_t test3 = 554;
fprintf(PC, "\r\n\r\n");
fprintf(PC, "test1: %1.3w\r\n", test1);
fprintf(PC, "test2: %1.3w\r\n", test2);
fprintf(PC, "test3: %1.3w\r\n", test3);
while(1){}
return 0;
The code gives this output on my serial port:
Code: | test1: 0.040
test2: 0.150
test3: 0.5=0
I have tried plain int32 instead of uint32_t, int16, and different numbers, but I can't notice any pattern at all. |
Posted: Fri Apr 05, 2019 1:14 pm |
I compiled the program below with CCS vs. 5.082, and ran it in the
MPLAB vs. 8.92 simulator. I got this in the output window:
Quote: |
test1: 0.018
test2: 0.123
test3: 0.554
Test program:
Code: | #include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#use rs232(baud=9600, UART1, ERRORS, stream=PC)
#include <stdint.h>
while(TRUE);
dluu13
Posted: Fri Apr 05, 2019 1:18 pm |
Yeah that's what I expected to see.
I just found this super old thread talking about %w giving garbage when using PCD.
https://www.ccsinfo.com/forum/viewtopic.php?p=128178
That's a 9-year old thread though. I wonder if it's still messed up maybe :/
Perhaps it is ok when you are using PCH. However, I don't have any other PICs to test it out with at the moment.
Also, I am 99.99999% sure that my UART is set up properly. I have been using this similar setup for a long time now, and anything other than %w works.
gaugeguy
Posted: Fri Apr 05, 2019 1:25 pm |
Try using %4.3w
The first number should be the total number of digits. |
dluu13
Posted: Fri Apr 05, 2019 1:30 pm |
I have tried various numbers for the first digit. I actually started with %5.2w.
%lw and %w both give the same results.
In this case, %4.3w gives exactly the same result as %1.3w. There must be a pattern, since I get the same result every single time.
Also, as I understand, the first number is the minimum width of the field, and if the number is larger, then the field will grow to fit it.
I'm wondering if it is a compiler bug, since an older user using PCD also had the same issue. I will email CCS and mention here if I get any results. |
Posted: Fri Apr 05, 2019 1:50 pm |
Here are the relevant compiler updates by date and compiler version:
Oct. 2015 -- 5.050 Fixed a bug when negative number were used with %W on 24 bit parts
Mar. 2015 -- 5.044 Corrected a formatting issue in %W (%LU, %LD should not have been affected)
Feb. 2015 -- 5.041 A problem with %w where if the digit after the . was 0 it did not output on the PIC24 is fixed
Jan. 2015 -- 5.037 The PIC24 printf() %w no longer forces the leading zeros
Nov. 2014 -- 5.031 Fixed a PIC24 bug in %w when used with signed numbers |
dluu13
Posted: Fri Apr 05, 2019 2:16 pm |
Unfortunately it looks like I am still having problems haha
I just tested on a PIC24FJ128GA308 and I am having the exact same output as the PIC24FJ128GA204.
Anyway, I am talking with CCS support now, and I have just sent over an LST file so hopefully we get to the bottom of this. |
dluu13
Posted: Mon Apr 08, 2019 1:44 pm |
Update:
I guess it was something with a compiler bug on PCD v5.082, seeing as how PCMP got it to work with PCH.
CCS support emailed me a couple of files to patch things up and it seems to work as expected now. |
