SPI error on Pic24fj128ga010 with RFM69 [Solved]
joseph20480
PostPosted: Sun Mar 31, 2019 4:04 am     Reply with quote
Dear forum,
I'm back with a new question.
I'm working to write a code for a project. I use a DevBoard Microchip Explorer16 with a PIM 24FJ128GA010.
Connected on board, a RFM69 module.
I have some troubles with the written mode. I'm able to read all registers perfectly (Compared with default value) But i can not write inside....
Do you have an idea ?
Please see my code... simple but with troubles:
#use spi(SPI1,MASTER, BITS=8, MSB_FIRST)
#define   pin_reset   pin_d6
#define pin_select    pin_e8
void rfm69_reset(void);
unsigned int8 rfm69_read8(unsigned int8);
void rfm69_write8(unsigned int8,unsigned int8);
void rfm69_write8(unsigned int8 addr,unsigned int8 data)
   output_low(pin_select);
      spi_write(addr | 0x80);
      spi_write(data);
      delay_us(25);
   output_high(pin_select);
unsigned int8 rfm69_read8(unsigned int8 addr)
   unsigned int8 valeur;
         spi_write(addr);
         valeur=spi_read(0);
      delay_us(100);
   return valeur;
   delay_ms(10);
   output_high(pin_reset);
   delay_ms(1);
   input(pin_reset);
   delay_ms(10);
   setup_spi(SPI_MASTER | SPI_SCK_IDLE_LOW | SPI_XMIT_L_TO_H | SPI_CLK_DIV_256);
   while (rfm69_read8(0x01)!=0x04)
      delay_ms(10);
   output_high(pin_a0);
PostPosted: Sun Mar 31, 2019 4:58 am     Reply with quote
Please post a link to the datasheet for the RFM69 module you're using. You've got 'extra stuff' in what I'd think should be simple 'read and writes'. That may be causing problems....
A 'module' has parts other than the basic 'chip', so the datasheet should explain proper setup, config, operation.
Jay
joseph20480
PostPosted: Sun Mar 31, 2019 8:14 am     Reply with quote
Jay
Ok, no problem... Dont' forget to use the correct power supply on your devboard and not only the power from programmer (PicKit3). On board there is some volatge translator who need 5v...
CLOSE !
