I2C2 pic18F26k22
cvargcal
I2C2 pic18F26k22
PostPosted: Sat Mar 02, 2019 1:46 pm     Reply with quote
Hi I am trying use the oled display, but no work in real. simulated yes.
Maybe I need have do it some configuration on this pic?
taken of : https://simple-circuit.com/ssd1306-oled-ccs-c-library/
this the code
Library
 SSD1306 OLED driver for CCS PIC C compiler (SSD1306OLED.c)                   *
 Reference: Adafruit Industries SSD1306 OLED driver and graphics library.     *
 The driver is for I2C mode only.                                             *
 http://simple-circuit.com/                                                   *
 This is a library for our Monochrome OLEDs based on SSD1306 drivers          *
  Pick one up today in the adafruit shop!                                     *
  ------> http://www.adafruit.com/category/63_98                              *
 Adafruit invests time and resources providing this open source code,         *
 please support Adafruit and open-source hardware by purchasing               *
 products from Adafruit!                                                      *
 Written by Limor Fried/Ladyada  for Adafruit Industries.                     *
 BSD license, check license.txt for more information                          *
 All text above, and the splash screen must be included in any redistribution *
#include <stdint.h>
#include <string.h>
//   *****   COM **
#define SSD1306_RST    PIN_B3  // SSD1306 OLED reset pin definition
#use I2C(MASTER, I2C2, FAST = 400000, stream = SSD1306_STREAM)  // Initialize I2C
//------------------------------ Definitions ---------------------------------//
#define SSD1306_I2C_ADDRESS   0x7A
#if !defined SSD1306_128_32 && !defined SSD1306_96_16
#define SSD1306_128_64
#if defined SSD1306_128_32 && defined SSD1306_96_16
  #error "Only one SSD1306 display can be specified at once"
#if defined SSD1306_128_64
  #define SSD1306_LCDWIDTH            128
  #define SSD1306_LCDHEIGHT            64
  #define SSD1306_LCDHEIGHT            32
#if defined SSD1306_96_16
  #define SSD1306_LCDWIDTH             96
  #define SSD1306_LCDHEIGHT            16
#define SSD1306_SETCONTRAST          0x81
#define SSD1306_DISPLAYALLON_RESUME  0xA4
#define SSD1306_DISPLAYALLON         0xA5
#define SSD1306_NORMALDISPLAY        0xA6
#define SSD1306_INVERTDISPLAY_       0xA7
#define SSD1306_DISPLAYOFF           0xAE
#define SSD1306_DISPLAYON            0xAF
#define SSD1306_SETDISPLAYOFFSET     0xD3
#define SSD1306_SETCOMPINS           0xDA
#define SSD1306_SETVCOMDETECT        0xDB
#define SSD1306_SETDISPLAYCLOCKDIV   0xD5
#define SSD1306_SETPRECHARGE         0xD9
#define SSD1306_SETMULTIPLEX         0xA8
#define SSD1306_SETLOWCOLUMN         0x00
#define SSD1306_SETHIGHCOLUMN        0x10
#define SSD1306_SETSTARTLINE         0x40
#define SSD1306_MEMORYMODE           0x20
#define SSD1306_COLUMNADDR           0x21
#define SSD1306_PAGEADDR             0x22
#define SSD1306_COMSCANINC           0xC0
#define SSD1306_COMSCANDEC           0xC8
#define SSD1306_SEGREMAP             0xA0
#define SSD1306_CHARGEPUMP           0x8D
#define SSD1306_EXTERNALVCC          0x01
#define SSD1306_SWITCHCAPVCC         0x02
// Scrolling #defines
#define SSD1306_ACTIVATE_SCROLL                      0x2F
#define SSD1306_DEACTIVATE_SCROLL                    0x2E
#define SSD1306_SET_VERTICAL_SCROLL_AREA             0xA3
#define SSD1306_RIGHT_HORIZONTAL_SCROLL              0x26
#define SSD1306_LEFT_HORIZONTAL_SCROLL               0x27
#define SSD1306_VERTICAL_AND_RIGHT_HORIZONTAL_SCROLL 0x29
#define SSD1306_VERTICAL_AND_LEFT_HORIZONTAL_SCROLL  0x2A
uint8_t _i2caddr, _vccstate;
void ssd1306_command(uint8_t c);
void SSD1306_Begin(uint8_t vccstate = SSD1306_SWITCHCAPVCC, uint8_t i2caddr = SSD1306_I2C_ADDRESS);
void SSD1306_DrawPixel(uint8_t x, uint8_t y, int1 color = TRUE);
void SSD1306_StartScrollRight(uint8_t start, uint8_t stop);
void SSD1306_StartScrollLeft(uint8_t start, uint8_t stop);
void SSD1306_StartScrollDiagRight(uint8_t start, uint8_t stop);
void SSD1306_StartScrollDiagLeft(uint8_t start, uint8_t stop);
void SSD1306_StopScroll(void);
void SSD1306_Dim(int1 dim);
void SSD1306_Display(void);
void SSD1306_ClearDisplay(void);
void SSD1306_DrawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int1 color = TRUE);
void SSD1306_DrawFastHLine(uint8_t x, uint8_t y, uint8_t w, int1 color = TRUE);
void SSD1306_DrawFastVLine(uint8_t x, uint8_t y, uint8_t h, int1 color = TRUE);
void SSD1306_FillRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, int1 color = TRUE);
void SSD1306_FillScreen(int1 color = TRUE);
void SSD1306_DrawCircle(int16_t x0, int16_t y0, int16_t r);
void SSD1306_DrawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername);
void SSD1306_FillCircle(int16_t x0, int16_t y0, int16_t r, int1 color = TRUE);
void SSD1306_FillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, int16_t delta, int1 color = TRUE);
void SSD1306_DrawRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h);
void SSD1306_DrawRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r);
void SSD1306_FillRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r, int1 color = TRUE);
void SSD1306_DrawTriangle(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2);
void SSD1306_FillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, int1 color = TRUE);
void SSD1306_DrawChar(uint8_t x, uint8_t y, uint8_t c, uint8_t size = 1);
void SSD1306_Drawtext(uint8_t x, uint8_t y, char *_text, uint8_t size = 1);
void SSD1306_SetTextWrap(int1 w);
void SSD1306_InvertDisplay(int1 i);
int1 wrap = TRUE;
#define ssd1306_swap(a, b) { int16_t t = a; a = b; b = t; }
const char Font[] = {
0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x5F, 0x00, 0x00,
0x00, 0x07, 0x00, 0x07, 0x00,
0x14, 0x7F, 0x14, 0x7F, 0x14,
0x24, 0x2A, 0x7F, 0x2A, 0x12,
0x23, 0x13, 0x08, 0x64, 0x62,
0x36, 0x49, 0x56, 0x20, 0x50,
0x00, 0x08, 0x07, 0x03, 0x00,
0x00, 0x1C, 0x22, 0x41, 0x00,
0x00, 0x41, 0x22, 0x1C, 0x00,
0x2A, 0x1C, 0x7F, 0x1C, 0x2A,
0x08, 0x08, 0x3E, 0x08, 0x08,
0x00, 0x80, 0x70, 0x30, 0x00,
0x08, 0x08, 0x08, 0x08, 0x08,
0x00, 0x00, 0x60, 0x60, 0x00,
0x20, 0x10, 0x08, 0x04, 0x02,
0x3E, 0x51, 0x49, 0x45, 0x3E,
0x00, 0x42, 0x7F, 0x40, 0x00,
0x72, 0x49, 0x49, 0x49, 0x46,
0x21, 0x41, 0x49, 0x4D, 0x33,
0x18, 0x14, 0x12, 0x7F, 0x10,
0x27, 0x45, 0x45, 0x45, 0x39,
0x3C, 0x4A, 0x49, 0x49, 0x31,
0x41, 0x21, 0x11, 0x09, 0x07,
0x36, 0x49, 0x49, 0x49, 0x36,
0x46, 0x49, 0x49, 0x29, 0x1E,
0x00, 0x00, 0x14, 0x00, 0x00,
0x00, 0x40, 0x34, 0x00, 0x00,
0x00, 0x08, 0x14, 0x22, 0x41,
0x14, 0x14, 0x14, 0x14, 0x14,
0x00, 0x41, 0x22, 0x14, 0x08,
0x02, 0x01, 0x59, 0x09, 0x06,
0x3E, 0x41, 0x5D, 0x59, 0x4E,
0x7C, 0x12, 0x11, 0x12, 0x7C,
0x7F, 0x49, 0x49, 0x49, 0x36,
0x3E, 0x41, 0x41, 0x41, 0x22,
0x7F, 0x41, 0x41, 0x41, 0x3E,
0x7F, 0x49, 0x49, 0x49, 0x41,
0x7F, 0x09, 0x09, 0x09, 0x01,
0x3E, 0x41, 0x41, 0x51, 0x73,
0x7F, 0x08, 0x08, 0x08, 0x7F,
0x00, 0x41, 0x7F, 0x41, 0x00,
0x20, 0x40, 0x41, 0x3F, 0x01,
0x7F, 0x08, 0x14, 0x22, 0x41,
0x7F, 0x40, 0x40, 0x40, 0x40,
0x7F, 0x02, 0x1C, 0x02, 0x7F,
0x7F, 0x04, 0x08, 0x10, 0x7F,
0x3E, 0x41, 0x41, 0x41, 0x3E,
0x7F, 0x09, 0x09, 0x09, 0x06,
0x3E, 0x41, 0x51, 0x21, 0x5E,
0x7F, 0x09, 0x19, 0x29, 0x46
const char Font2[] = {
0x26, 0x49, 0x49, 0x49, 0x32,
0x03, 0x01, 0x7F, 0x01, 0x03,
0x3F, 0x40, 0x40, 0x40, 0x3F,
0x1F, 0x20, 0x40, 0x20, 0x1F,
0x3F, 0x40, 0x38, 0x40, 0x3F,
0x63, 0x14, 0x08, 0x14, 0x63,
0x03, 0x04, 0x78, 0x04, 0x03,
0x61, 0x59, 0x49, 0x4D, 0x43,
0x00, 0x7F, 0x41, 0x41, 0x41,
0x02, 0x04, 0x08, 0x10, 0x20,
0x00, 0x41, 0x41, 0x41, 0x7F,
0x04, 0x02, 0x01, 0x02, 0x04,
0x40, 0x40, 0x40, 0x40, 0x40,
0x00, 0x03, 0x07, 0x08, 0x00,
0x20, 0x54, 0x54, 0x78, 0x40,
0x7F, 0x28, 0x44, 0x44, 0x38,
0x38, 0x44, 0x44, 0x44, 0x28,
0x38, 0x44, 0x44, 0x28, 0x7F,
0x38, 0x54, 0x54, 0x54, 0x18,
0x00, 0x08, 0x7E, 0x09, 0x02,
0x18, 0xA4, 0xA4, 0x9C, 0x78,
0x7F, 0x08, 0x04, 0x04, 0x78,
0x00, 0x44, 0x7D, 0x40, 0x00,
0x20, 0x40, 0x40, 0x3D, 0x00,
0x7F, 0x10, 0x28, 0x44, 0x00,
0x00, 0x41, 0x7F, 0x40, 0x00,
0x7C, 0x04, 0x78, 0x04, 0x78,
0x7C, 0x08, 0x04, 0x04, 0x78,
0x38, 0x44, 0x44, 0x44, 0x38,
0xFC, 0x18, 0x24, 0x24, 0x18,
0x18, 0x24, 0x24, 0x18, 0xFC,
0x7C, 0x08, 0x04, 0x04, 0x08,
0x48, 0x54, 0x54, 0x54, 0x24,
0x04, 0x04, 0x3F, 0x44, 0x24,
0x3C, 0x40, 0x40, 0x20, 0x7C,
0x1C, 0x20, 0x40, 0x20, 0x1C,
0x3C, 0x40, 0x30, 0x40, 0x3C,
0x44, 0x28, 0x10, 0x28, 0x44,
0x4C, 0x90, 0x90, 0x90, 0x7C,
0x44, 0x64, 0x54, 0x4C, 0x44,
0x00, 0x08, 0x36, 0x41, 0x00,
0x00, 0x00, 0x77, 0x00, 0x00,
0x00, 0x41, 0x36, 0x08, 0x00,
0x02, 0x01, 0x02, 0x04, 0x02
static uint8_t buffer[SSD1306_LCDHEIGHT * SSD1306_LCDWIDTH / 8] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0x80, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF8, 0xFC, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80,
0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0xFF
#if (SSD1306_LCDHEIGHT * SSD1306_LCDWIDTH > 96*16)
0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00,
0x80, 0xFF, 0xFF, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x8C, 0x8E, 0x84, 0x00, 0x00, 0x80, 0xF8,
0xF8, 0xF8, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xE0, 0xC0, 0x80,
0x00, 0xE0, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xFF, 0xC7, 0x01, 0x01,
0x01, 0x01, 0x83, 0xFF, 0xFF, 0x00, 0x00, 0x7C, 0xFE, 0xC7, 0x01, 0x01, 0x01, 0x01, 0x83, 0xFF,
0xFF, 0xFF, 0x00, 0x38, 0xFE, 0xC7, 0x83, 0x01, 0x01, 0x01, 0x83, 0xC7, 0xFF, 0xFF, 0x00, 0x00,
0x01, 0xFF, 0xFF, 0x01, 0x01, 0x00, 0xFF, 0xFF, 0x07, 0x01, 0x01, 0x01, 0x00, 0x00, 0x7F, 0xFF,
0x80, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x7F, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x01, 0xFF,
0xFF, 0xFF, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x03, 0x0F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xC7, 0xC7, 0x8F,
0x8F, 0x9F, 0xBF, 0xFF, 0xFF, 0xC3, 0xC0, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xFC, 0xFC,
0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xF0, 0xF0, 0xE0, 0xC0, 0x00, 0x01, 0x03, 0x03, 0x03,
0x03, 0x03, 0x01, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x01, 0x01,
0x03, 0x01, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x01, 0x01, 0x03, 0x03, 0x00, 0x00,
0x00, 0x03, 0x03, 0x00, 0x00, 0x00, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x03, 0x03, 0x03, 0x03, 0x03, 0x01, 0x00, 0x00, 0x00, 0x01, 0x03, 0x01, 0x00, 0x00, 0x00, 0x03,
0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
#if (SSD1306_LCDHEIGHT == 64)
0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x1F, 0x0F,
0x87, 0xC7, 0xF7, 0xFF, 0xFF, 0x1F, 0x1F, 0x3D, 0xFC, 0xF8, 0xF8, 0xF8, 0xF8, 0x7C, 0x7D, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x0F, 0x07, 0x00, 0x30, 0x30, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xFE, 0xFE, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xC0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
0x00, 0xC0, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0x3F, 0x1F,
0x0F, 0x07, 0x1F, 0x7F, 0xFF, 0xFF, 0xF8, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF8, 0xE0,
0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00,
0x00, 0xFC, 0xFE, 0xFC, 0x0C, 0x06, 0x06, 0x0E, 0xFC, 0xF8, 0x00, 0x00, 0xF0, 0xF8, 0x1C, 0x0E,
0x06, 0x06, 0x06, 0x0C, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xFC,
0xFE, 0xFC, 0x00, 0x18, 0x3C, 0x7E, 0x66, 0xE6, 0xCE, 0x84, 0x00, 0x00, 0x06, 0xFF, 0xFF, 0x06,
0x06, 0xFC, 0xFE, 0xFC, 0x0C, 0x06, 0x06, 0x06, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00, 0xC0, 0xF8,
0xFC, 0x4E, 0x46, 0x46, 0x46, 0x4E, 0x7C, 0x78, 0x40, 0x18, 0x3C, 0x76, 0xE6, 0xCE, 0xCC, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x0F, 0x1F, 0x1F, 0x3F, 0x3F, 0x3F, 0x3F, 0x1F, 0x0F, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00,
0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x03, 0x07, 0x0E, 0x0C,
0x18, 0x18, 0x0C, 0x06, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x01, 0x0F, 0x0E, 0x0C, 0x18, 0x0C, 0x0F,
0x07, 0x01, 0x00, 0x04, 0x0E, 0x0C, 0x18, 0x0C, 0x0F, 0x07, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00,
0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x07,
0x07, 0x0C, 0x0C, 0x18, 0x1C, 0x0C, 0x06, 0x06, 0x00, 0x04, 0x0E, 0x0C, 0x18, 0x0C, 0x0F, 0x07,
void ssd1306_command(uint8_t c) {
    uint8_t control = 0x00;   // Co = 0, D/C = 0
    I2C_Start(SSD1306_STREAM);
    I2C_Write(SSD1306_STREAM, _i2caddr);
    I2C_Write(SSD1306_STREAM, control);
    I2C_Write(SSD1306_STREAM, c);
    I2C_Stop(SSD1306_STREAM);
void SSD1306_Begin(uint8_t vccstate = SSD1306_SWITCHCAPVCC, uint8_t i2caddr = SSD1306_I2C_ADDRESS) {
  _vccstate = vccstate;
  _i2caddr  = i2caddr;
  #ifdef SSD1306_RST
    output_low(SSD1306_RST);
    output_drive(SSD1306_RST);
    delay_ms(10);
    output_high(SSD1306_RST);
  // Init sequence
  ssd1306_command(SSD1306_DISPLAYOFF);                    // 0xAE
  ssd1306_command(SSD1306_SETDISPLAYCLOCKDIV);            // 0xD5
  ssd1306_command(0x80);                                  // the suggested ratio 0x80
  ssd1306_command(SSD1306_SETMULTIPLEX);                  // 0xA8
  ssd1306_command(SSD1306_LCDHEIGHT - 1);
  ssd1306_command(SSD1306_SETDISPLAYOFFSET);              // 0xD3
  ssd1306_command(0x0);                                   // no offset
  ssd1306_command(SSD1306_SETSTARTLINE | 0x0);            // line #0
  ssd1306_command(SSD1306_CHARGEPUMP);                    // 0x8D
  if (vccstate == SSD1306_EXTERNALVCC)
    { ssd1306_command(0x10); }
    { ssd1306_command(0x14); }
  ssd1306_command(SSD1306_MEMORYMODE);                    // 0x20
  ssd1306_command(0x00);                                  // 0x0 act like ks0108
  ssd1306_command(SSD1306_SEGREMAP | 0x1);
  ssd1306_command(SSD1306_COMSCANDEC);
  ssd1306_command(SSD1306_SETCOMPINS);                    // 0xDA
  ssd1306_command(0x02);
  ssd1306_command(SSD1306_SETCONTRAST);                   // 0x81
  ssd1306_command(0x8F);
#elif defined SSD1306_128_64
  ssd1306_command(0x12);
    { ssd1306_command(0x9F); }
    { ssd1306_command(0xCF); }
#elif defined SSD1306_96_16
  ssd1306_command(0x2);   //ada x12
    { ssd1306_command(0xAF); }
  ssd1306_command(SSD1306_SETPRECHARGE);                  // 0xd9
    { ssd1306_command(0x22); }
    { ssd1306_command(0xF1); }
  ssd1306_command(SSD1306_SETVCOMDETECT);                 // 0xDB
  ssd1306_command(0x40);
  ssd1306_command(SSD1306_DISPLAYALLON_RESUME);           // 0xA4
  ssd1306_command(SSD1306_NORMALDISPLAY);                 // 0xA6
  ssd1306_command(SSD1306_DEACTIVATE_SCROLL);
  ssd1306_command(SSD1306_DISPLAYON);//--turn on oled panel
void SSD1306_DrawPixel(uint8_t x, uint8_t y, int1 color = TRUE) {
  if ((x >= SSD1306_LCDWIDTH) || (y >= SSD1306_LCDHEIGHT))
    return;
  if (color)
    buffer[x + (uint16_t)(y / 8) * SSD1306_LCDWIDTH] |=  (1 << (y & 7));
    buffer[x + (uint16_t)(y / 8) * SSD1306_LCDWIDTH] &=  ~(1 << (y & 7));
void SSD1306_StartScrollRight(uint8_t start, uint8_t stop) {
  ssd1306_command(SSD1306_RIGHT_HORIZONTAL_SCROLL);
  ssd1306_command(0X00);
  ssd1306_command(start);
  ssd1306_command(stop);
  ssd1306_command(0XFF);
  ssd1306_command(SSD1306_ACTIVATE_SCROLL);
void SSD1306_StartScrollLeft(uint8_t start, uint8_t stop) {
  ssd1306_command(SSD1306_LEFT_HORIZONTAL_SCROLL);
void SSD1306_StartScrollDiagRight(uint8_t start, uint8_t stop) {
  ssd1306_command(SSD1306_SET_VERTICAL_SCROLL_AREA);
  ssd1306_command(SSD1306_LCDHEIGHT);
  ssd1306_command(SSD1306_VERTICAL_AND_RIGHT_HORIZONTAL_SCROLL);
  ssd1306_command(0X01);
void SSD1306_StartScrollDiagLeft(uint8_t start, uint8_t stop) {
  ssd1306_command(SSD1306_VERTICAL_AND_LEFT_HORIZONTAL_SCROLL);
void SSD1306_StopScroll(void) {
void SSD1306_Dim(int1 dim) {
  uint8_t contrast;
  if (dim)
    contrast = 0; // Dimmed display
  else {
    if (_vccstate == SSD1306_EXTERNALVCC)
      contrast = 0x9F;
      contrast = 0xCF;
  // the range of contrast to too small to be really useful
  // it is useful to dim the display
  ssd1306_command(contrast);
void SSD1306_Display(void) {
  ssd1306_command(SSD1306_COLUMNADDR);
  ssd1306_command(0);   // Column start address (0 = reset)
  ssd1306_command(SSD1306_LCDWIDTH-1); // Column end address (127 = reset)
  ssd1306_command(SSD1306_PAGEADDR);
  ssd1306_command(0); // Page start address (0 = reset)
  #if SSD1306_LCDHEIGHT == 64
    ssd1306_command(7); // Page end address
  #if SSD1306_LCDHEIGHT == 32
    ssd1306_command(3); // Page end address
  #if SSD1306_LCDHEIGHT == 16
    ssd1306_command(1); // Page end address
  for (uint16_t i = 0; i < (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT / 8); i++) {
      // send a bunch of data in one xmission
      I2C_Write(SSD1306_STREAM, 0x40);
      for (uint8_t x = 0; x < 16; x++) {
        I2C_Write(SSD1306_STREAM, buffer[i]);
        i++;
      i--;
void SSD1306_ClearDisplay(void) {
    buffer[i] = 0;
void SSD1306_DrawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int1 color = TRUE) {
  int1 steep;
  int8_t ystep;
  uint8_t dx, dy;
  int16_t err;
  steep = abs(y1 - y0) > abs(x1 - x0);
  if (steep) {
    ssd1306_swap(x0, y0);
    ssd1306_swap(x1, y1);
  if (x0 > x1) {
    ssd1306_swap(x0, x1);
    ssd1306_swap(y0, y1);
  dx = x1 - x0;
  dy = abs(y1 - y0);
  err = dx / 2;
  if (y0 < y1)
    ystep = 1;
    ystep = -1;
  for (; x0 <= x1; x0++) {
    if (steep) {
      if(color) SSD1306_DrawPixel(y0, x0);
      else      SSD1306_DrawPixel(y0, x0, FALSE);
    else {
      if(color) SSD1306_DrawPixel(x0, y0);
      else      SSD1306_DrawPixel(x0, y0, FALSE);
    err -= dy;
    if (err < 0) {
      y0  += ystep;
      err += dx;
void SSD1306_DrawFastHLine(uint8_t x, uint8_t y, uint8_t w, int1 color = TRUE) {
   SSD1306_DrawLine(x, y, x + w - 1, y, color);
void SSD1306_DrawFastVLine(uint8_t x, uint8_t y, uint8_t h, int1 color = TRUE) {
  SSD1306_DrawLine(x, y, x, y + h - 1, color);
void SSD1306_FillRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, int1 color = TRUE) {
  for (int16_t i = x; i < x + w; i++)
    SSD1306_DrawFastVLine(i, y, h, color);
void SSD1306_FillScreen(int1 color = TRUE) {
  SSD1306_FillRect(0, 0, SSD1306_LCDWIDTH, SSD1306_LCDHEIGHT, color);
void SSD1306_DrawCircle(int16_t x0, int16_t y0, int16_t r) {
  int16_t f = 1 - r;
  int16_t ddF_x = 1;
  int16_t ddF_y = -2 * r;
  int16_t x = 0;
  int16_t y = r;
  SSD1306_DrawPixel(x0  , y0 + r);
  SSD1306_DrawPixel(x0  , y0 - r);
  SSD1306_DrawPixel(x0 + r, y0);
  SSD1306_DrawPixel(x0 - r, y0);
  while (x < y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f += ddF_y;
    x++;
    ddF_x += 2;
    f += ddF_x;
    SSD1306_DrawPixel(x0 + x, y0 + y);
    SSD1306_DrawPixel(x0 - x, y0 + y);
    SSD1306_DrawPixel(x0 + x, y0 - y);
    SSD1306_DrawPixel(x0 - x, y0 - y);
    SSD1306_DrawPixel(x0 + y, y0 + x);
    SSD1306_DrawPixel(x0 - y, y0 + x);
    SSD1306_DrawPixel(x0 + y, y0 - x);
    SSD1306_DrawPixel(x0 - y, y0 - x);
void SSD1306_DrawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername) {
  int16_t f     = 1 - r;
  int16_t ddF_x = 1;
  int16_t x     = 0;
  int16_t y     = r;
  while (x < y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f     += ddF_y;
    x++;
    ddF_x += 2;
    f     += ddF_x;
    if (cornername & 0x4) {
    if (cornername & 0x2) {
    if (cornername & 0x8) {
    if (cornername & 0x1) {
void SSD1306_FillCircle(int16_t x0, int16_t y0, int16_t r, int1 color = TRUE) {
  SSD1306_DrawFastVLine(x0, y0 - r, 2 * r + 1, color);
  SSD1306_FillCircleHelper(x0, y0, r, 3, 0, color);
// Used to do circles and roundrects
void SSD1306_FillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, int16_t delta, int1 color = TRUE) {
  int16_t f     = 1 - r;
  int16_t ddF_x = 1;
  int16_t x     = 0;
  int16_t y     = r;
  while (x < y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f     += ddF_y;
    x++;
    ddF_x += 2;
    f     += ddF_x;
    if (cornername & 0x01) {
      SSD1306_DrawFastVLine(x0 + x, y0 - y, 2 * y + 1 + delta, color);
      SSD1306_DrawFastVLine(x0 + y, y0 - x, 2 * x + 1 + delta, color);
    if (cornername & 0x02) {
      SSD1306_DrawFastVLine(x0 - x, y0 - y, 2 * y + 1 + delta, color);
      SSD1306_DrawFastVLine(x0 - y, y0 - x, 2 * x + 1 + delta, color);
// Draw a rectangle
void SSD1306_DrawRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h) {
  SSD1306_DrawFastHLine(x, y, w);
  SSD1306_DrawFastHLine(x, y + h - 1, w);
  SSD1306_DrawFastVLine(x, y, h);
  SSD1306_DrawFastVLine(x + w - 1, y, h);
// Draw a rounded rectangle
void SSD1306_DrawRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r) {
  // smarter version
  SSD1306_DrawFastHLine(x + r, y, w - 2 * r); // Top
  SSD1306_DrawFastHLine(x + r, y + h - 1, w - 2 * r); // Bottom
  SSD1306_DrawFastVLine(x, y + r, h - 2 * r); // Left
  SSD1306_DrawFastVLine(x + w - 1, y + r, h - 2 * r); // Right
  // draw four corners
  SSD1306_DrawCircleHelper(x + r, y + r, r, 1);
  SSD1306_DrawCircleHelper(x + w - r - 1, y + r, r, 2);
  SSD1306_DrawCircleHelper(x + w - r - 1, y + h - r - 1, r, 4);
  SSD1306_DrawCircleHelper(x + r, y + h - r - 1, r, 8);
// Fill a rounded rectangle
void SSD1306_FillRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r, int1 color = TRUE) {
  // smarter version
  SSD1306_FillRect(x + r, y, w - 2 * r, h, color);
  SSD1306_FillCircleHelper(x + w - r - 1, y + r, r, 1, h - 2 * r - 1, color);
  SSD1306_FillCircleHelper(x + r        , y + r, r, 2, h - 2 * r - 1, color);
// Draw a triangle
void SSD1306_DrawTriangle(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2) {
  SSD1306_DrawLine(x0, y0, x1, y1);
  SSD1306_DrawLine(x1, y1, x2, y2);
  SSD1306_DrawLine(x2, y2, x0, y0);
// Fill a triangle
void SSD1306_FillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, int1 color = TRUE) {
  int16_t a, b, y, last;
  // Sort coordinates by Y order (y2 >= y1 >= y0)
  if (y0 > y1) {
    ssd1306_swap(y0, y1); ssd1306_swap(x0, x1);
  if (y1 > y2) {
    ssd1306_swap(y2, y1); ssd1306_swap(x2, x1);
  if (y0 > y1) {
  if(y0 == y2) { // Handle awkward all-on-same-line case as its own thing
    a = b = x0;
    if(x1 < a)      a = x1;
    else if(x1 > b) b = x1;
    if(x2 < a)      a = x2;
    else if(x2 > b) b = x2;
    SSD1306_DrawFastHLine(a, y0, b - a + 1, color);
    return;
  int16_t
  dx01 = x1 - x0,
  dy01 = y1 - y0,
  dx02 = x2 - x0,
  dy02 = y2 - y0,
  dx12 = x2 - x1,
  dy12 = y2 - y1;
  int32_t  sa   = 0, sb   = 0;
  // For upper part of triangle, find scanline crossings for segments
  // 0-1 and 0-2.  If y1=y2 (flat-bottomed triangle), the scanline y1
  // is included here (and second loop will be skipped, avoiding a /0
  // error there), otherwise scanline y1 is skipped here and handled
  // in the second loop...which also avoids a /0 error here if y0=y1
  // (flat-topped triangle).
  if(y1 == y2) last = y1;   // Include y1 scanline
  else         last = y1 - 1; // Skip it
  for(y = y0; y <= last; y++) {
    a   = x0 + sa / dy01;
    b   = x0 + sb / dy02;
    sa += dx01;
    sb += dx02;
    /* longhand:
    a = x0 + (x1 - x0) * (y - y0) / (y1 - y0);
    b = x0 + (x2 - x0) * (y - y0) / (y2 - y0);
    if(a > b) ssd1306_swap(a, b);
    SSD1306_DrawFastHLine(a, y, b - a + 1, color);
  // For lower part of triangle, find scanline crossings for segments
  // 0-2 and 1-2.  This loop is skipped if y1=y2.
  sa = dx12 * (y - y1);
  sb = dx02 * (y - y0);
  for(; y <= y2; y++) {
    a   = x1 + sa / dy12;
    b   = x0 + sb / dy02;
    sa += dx12;
    sb += dx02;
    /* longhand:
    a = x1 + (x2 - x1) * (y - y1) / (y2 - y1);
void SSD1306_DrawChar(uint8_t x, uint8_t y, uint8_t c, uint8_t size = 1) {
  int8_t i, j;
  if((x >= SSD1306_LCDWIDTH) || (y >= SSD1306_LCDHEIGHT))
    return;
  if(size < 1) size = 1;
  if((c < ' ') || (c > '~'))
    c = '?';
  for(i = 0; i < 5; i++ ) {
    uint8_t line;
    if(c < 'S')
      line = font[(c - 32) * 5 + i];
      line = font2[(c - 'S') * 5 + i];
    for(j = 0; j < 7; j++, line >>= 1) {
      if(line & 0x01) {
        if(size == 1) SSD1306_DrawPixel(x + i, y + j);
        else          SSD1306_FillRect(x + (i * size), y + (j * size), size, size);
      else {
        if(size == 1) SSD1306_DrawPixel(x + i, y + j, FALSE);    // delete pixel
        else          SSD1306_FillRect(x + i * size, y + j * size, size, size, FALSE);
void SSD1306_Drawtext(uint8_t x, uint8_t y, char *_text, uint8_t size = 1) {
  uint8_t cursor_x, cursor_y;
  uint16_t textsize, i;
  cursor_x = x, cursor_y = y;
  textsize = strlen(_text);
  for(i = 0; i < textsize; i++){
    if(wrap && ((cursor_x + size * 5) > SSD1306_LCDWIDTH)){
      cursor_x = 0;
      cursor_y = cursor_y + size * 7 + 3 ;
      if(cursor_y > SSD1306_LCDHEIGHT)
        cursor_y = SSD1306_LCDHEIGHT;
      if(_text[i] == 0x20)
        goto _skip;
    SSD1306_DrawChar(cursor_x, cursor_y, _text[i], size);
    cursor_x = cursor_x + size * 6;
    if(cursor_x > SSD1306_LCDWIDTH)
      cursor_x = SSD1306_LCDWIDTH;
    _skip: ;
void SSD1306_SetTextWrap(int1 w) {
  wrap = w;
void SSD1306_InvertDisplay(int1 i) {
  if (i)
    ssd1306_command(SSD1306_INVERTDISPLAY_);
EXAMPLE
Code
#include <18F26k22.h>
#device PASS_STRINGS = IN_RAM
#device adc=10
#FUSES INTRC_IO        // INTRC_IO Internal RC Osc, no CLKOUT
#FUSES NOFCMEN         //Fail-safe clock monitor disabled
#FUSES NOIESO          //Internal External Switch Over mode disabled
#FUSES NOPUT            //No Power Up Timer
#FUSES NOBROWNOUT       //No brownout reset
#FUSES NOWDT            //No Watch Dog Timer
#FUSES NOPBADEN        //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR          //Master Clear pin NOT enabled
#FUSES NOLVP           //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST         //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NODEBUG         //No Debug mode for ICD
#FUSES CCP2C1
#use delay(internal = 16MHz)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#include "SSD1306OLED.c"   // Include SSD1306 OLED driver source code
#define SELECT    PIN_C0
#define INTO      PIN_C1
#define OK        PIN_A7
void main(void) {
  // Initialize the SSD1306 OLED with an I2C addr = 0x7A (default address)
  SSD1306_Begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  SSD1306_Display();
  delay_ms(2000);
  // Clear the buffer.
  SSD1306_ClearDisplay();
 // text display tests
  char txt[9];
  SSD1306_DrawText(2, 7, "Hello, world!", 1);
  sprintf(txt, "%.6f", 3.141592);
  SSD1306_DrawText(2, 16, txt, 1);
  SSD1306_DrawText(2, 26, "0x", 2);
  sprintf(txt, "%LX", 0xDEADBEEF);
  SSD1306_DrawText(26, 26, txt, 2);
  SSD1306_Display();
  delay_ms(2000);
But I use this
without RESET PIN but not matter I think.
PostPosted: Sat Mar 02, 2019 1:55 pm     Reply with quote
Run the i2c scanner program on it. See if it finds the i2c slave at the
expected slave address:
http://www.ccsinfo.com/forum/viewtopic.php?t=49713
PostPosted: Sat Mar 02, 2019 2:07 pm     Reply with quote
Yes, 1st thing to do with EVERY I2C device, run PCM P scanner program. You may find that the address of the device is '7 bit' mode not the CCS '8 bit' default.
Easy to convert....scanner will find it.
Also...
change the clock to 8MHz, at least for test purposes. I've had some I2C devices not like fast clocks,probably due to wiring, capacitance, wrong pullups.
8MHz has always worked.My current 26k22 project does run at 16MHz but not at 32MHz.
cvargcal
PostPosted: Sat Mar 02, 2019 3:04 pm     Reply with quote
Thanks this is the answer
Found
Start:
Start:
Start:
ACK addr: 78
Number of i2c chips found: 1
I change that 7A by 78 but still not work, I have pull up 10k... I think that is not problem
PostPosted: Sat Mar 02, 2019 3:27 pm     Reply with quote
Check the schematic of the display and see if it has I2C pullups already. Some do, some don't.
To me 10K is too high, for a fast device at 3 volts( I'm assuming both PIC and display are powered from 3 volts....)
To some very basic tests...cut code to read a register, then write to it, then read it back.
Also very carefully check the driver for other addreses other than the base address or variables that refer to the base address.
cvargcal
PostPosted: Sat Mar 02, 2019 3:46 pm     Reply with quote
Thank you, now its ok I changed the pullup to 5.6K, Smile
Today I learned new things about i2c
PostPosted: Sun Mar 03, 2019 12:23 am     Reply with quote
Even 5K6 is large.
I2C is dependant on _current_ in the pull-up. Running off 3.3v, the
current drawn by the pull-up for a given resistor is less.
The pull-ups, have a minimum, and maximum 'range' that can be used.
The maximum is dependant on the bus speed, and the capacitance of
the bus. The lower the resistor, the more capacitance the bus can have.
The minimum resistor value is calculated as:
Rp(min) = (Vcc-Vol(max))/Iol
Iol depends on the devices being used, but I2C requires all devices
to be able to sink at least 3mA. Vol is specified as 0.4v.
The maximum value depends on the bus capacitance, the input
voltage range that has to occur, and the speed of the bus. This
simplifies to:
Rp(max) = tr/(0.8473*Cb)
Where tr is the rise time required, and Cb is the bus capacitance.
For a 400KHz I2C bus, tr is 300nSec.
So for the min calculation, at 3.3v:
(3.3v-0.4v)/0.003 = 966R
Then lets allow for a reasonable bus capacitance. Each chip is going
to have an input capacitance of at least perhaps 5pF. A few inches of
wire and PCB tracks on the display will give at least 20pF, so a nice
safe figure assuming the bus is not too long is to assume 100pF
total.
So
300E-9/(0.8473*100E-12) = 3540R
Sp for a 100pF bus, the minimum resistor value is 966R, and the max
3540R.
Your 5K6 limits your maximum bus capacitance to 63pF. Probably
OK if there is only one device on the bus and it is short. However
not perhaps much margin...
On 5v, 4K7 is a good 'safe bet' resistor, likely to work on most busses.
On 3.3v, 3K3 is the equivalent.
on 5v, 10K, is OK for a _standard mode_ bus (100KHz max). However
for a faster 400K bus, a lower value should be used.
PostPosted: Sun Mar 03, 2019 5:55 am     Reply with quote
All the complicated (but serious) math that Mr. T nicely wrote about can be remembered easily.
5 volt PIC use 5K resistors, 3 volt PICs use 3K resistors.
4k7 and 3k3 are 5% resistors and should be laying round everyone's workbench.
The older you get the more you need easy ways to remember stuff !
cvargcal
PostPosted: Sun Mar 03, 2019 6:44 pm     Reply with quote
Great information!!
thanks
