PIC16F19197 PORTF can not read input
esbelektronik
PostPosted: Sat Jan 12, 2019 3:55 pm     Reply with quote
I try read pin_f4 pin but not read. You see my c code and compare to assembly code. I want read pin_f4 but reading pin_a4.
....................        if (input(PIN_f4)==1)
0B1D:  MOVLB  05
0B1E:  BTFSS  0C.4   (pin_a4 address!!)
0B1F:  GOTO   32A
....................             {output_high(pintimeronoffled);
0B20:  MOVLW  C3
0B21:  MOVLB  00
0B22:  MOVWF  14
0B23:  BSF    1A.3
(q p) ESB
( V )
L L
PostPosted: Sat Jan 12, 2019 5:19 pm     Reply with quote
You should post a small program that shows your code AND your compiler version number.
If you have a variable you name PIN_f4 that would not be the same as PIN_F4, if you've got #CASE in your code. I have been caught with 'case sensitive before...
The other possibilty is an error in the compiler.
esbelektronik
PostPosted: Sat Jan 12, 2019 5:36 pm     Reply with quote
If you have a variable you name PIN_f4 that would not be the same as PIN_F4, if you've got #CASE in your code.I have been caught with 'case sensitive before...
Thanks temtronic,
You see if i use portc compare asm file, portc BTFSS 0E.4 address is right. When i use portf, write wrong address:
....................        if (input(PIN_C4)==1)
0B1D:  MOVLW  C3
0B1E:  MOVWF  14
0B1F:  BTFSS  0E.4
0B20:  GOTO   329
it's my main procedure.
#ZERO_RAM
   setup_oscillator(OSC_HFINTRC_32MHZ );
   setup_dac(DAC_OFF);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   setup_lcd(LCD_DISABLED);
   setup_adc(ADC_CLOCK_INTERNAL | ADC_CLOCK_DIV_2 |NO_ANALOGS_P2);
   setup_adc_reference(VSS_VDD);
   setup_adc_ports(sAN0|sAN1|sAN2);
   set_analog_pins(PIN_A0,PIN_A1,PIN_A2);
   setup_zcd(ZCD_ENABLE|ZCD_INT_L_TO_H);
   set_tris_f(0b00011111);
   set_tris_a(0b11111111);
   set_input_level_f(0xFF);
   set_slow_slew_f(0b00000000);
   set_open_drain_f(0b00000000);
   setup_rtc(RTC_ENABLE | RTC_CLOCK_SOSC );
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(T0_INTERNAL|T0_DIV_8);
   setup_timer_1(T1_INTERNAL |T1_DIV_BY_2);
   disable_interrupts(INT_TIMER2);
   disable_interrupts(INT_EXT);
   enable_interrupts(INT_ZCD);
(q p) ESB
( V )
L L
esbelektronik
PostPosted: Sat Jan 12, 2019 5:38 pm     Reply with quote
compiler version is 5.082.
(q p) ESB
( V )
L L
PostPosted: Sat Jan 12, 2019 9:02 pm     Reply with quote
It's a compiler bug. The following work-around code will read the correct
port address. With this method, you have to set the TRIS manually, but
you're already doing that in your main() program anyway.
#include <16F19197.h>
#fuses NOWDT
#use delay(internal=4M)
#byte PORTF = getenv("SFR:PORTF")
int8 temp;
temp = bit_test(PORTF, 4);
while(TRUE);
This bug should be reported to CCS.
esbelektronik
PostPosted: Sun Jan 13, 2019 4:02 am     Reply with quote
#fuses NOWDT
int8 temp;
while(TRUE);
Thanks PCM programmer,
it's work.
....................        if (bit_test(PORTF, 4))
0B81:  BTFSS  11.4
Laughing
(q p) ESB
( V )
L L
esbelektronik
PostPosted: Sun Jan 13, 2019 4:17 am     Reply with quote
#fuses NOWDT
int8 temp;
while(TRUE);
there is similar problem within PORTH!! I solved it with the method. Thanks
(q p) ESB
( V )
L L
PostPosted: Sun Jan 13, 2019 11:53 am     Reply with quote
Please report both to CCS.
It is very difficult for them to keep up with all the nuances of new PIC's,
so feedback from us is vital. Smile
esbelektronik
PostPosted: Sun Jan 13, 2019 3:43 pm     Reply with quote
Yes you are right. I reported to CCS. I think I am the first CCS user to use the PIC16F19197 Laughing Laughing Laughing
(q p) ESB
( V )
L L
PostPosted: Mon Jan 14, 2019 2:37 am     Reply with quote
Yes.
This is why you will see a lot of the 'old hands' here staying with the last generation chips, rather than leaping to new ones. With the rate that MicroChip launches new types, it is very hard for CCS to keep up, and even harder to get everything right...
