Tm1638 Library
Ömer Faruk
Tm1638 Library
PostPosted: Wed Jan 02, 2019 10:18 am     Reply with quote
Hello everyone.
İ searched tm1638 Library on the internet but i couldn't find it. Could someone share it with me.
PostPosted: Wed Jan 02, 2019 10:46 am     Reply with quote
I'm guessing ??
https://os.mbed.com/components/TM1638-LED-controller-80-LEDs-max-Keyboa/
It'd really help if you posted a link to whatever a tm1638 actually is...
Quite often posters mean a 'module' and not a 'chip', so it's important to provide details !
There's LOTS of Arduino libraries for this module BUT you need to select the correct one ! Some modules have bicolor LEDs, some don't. At $4 a board it's a good deal for 8 7sd, 8 led, 8pb BUT takes a LOT of current if all LEDs are on.
Converting the Arduino library to a CCS driver is easy, maybe 1/2 night project. Quicker if you understand Arduino C !
Jay
PostPosted: Thu Jan 03, 2019 5:10 am     Reply with quote
Though this is not complete, I've just put together a basic set of routines
to write data to the chip and read the key values. Lots of comments inline.
Some settings will depend on whether the matrix is wired as
common cathode or common anode.
Driving the chip itself is very basic. Just SPI:
//Your setup fuses, clock etc..
#use spi(MODE=3, SPI1, BAUD=2MHz, STREAM=TM1638)
//adjust this to use different pins if you want software I2C
//chip supports 2.5MHz max SPI.
#define DISPLAYON 0x84
#define AUTOINC 0x40 //auto increment on write
#define MAX_BRIGHTNESS 0x8F
#define READKEY 0x42 //read key values
#define STB PIN_xx //set to the STB pin
#define ADDR_START 0xC0 //starting address
const unsigned int8 digitToSegment[] = {
 // XGFEDCBA
  0b00111111,    // 0
  0b00000110,    // 1
  0b01011011,    // 2
  0b01001111,    // 3
  0b01100110,    // 4
  0b01101101,    // 5
  0b01111101,    // 6
  0b00000111,    // 7
  0b01111111,    // 8
  0b01101111,    // 9
  0b01110111,    // A
  0b01111100,    // b
  0b00111001,    // C
  0b01011110,    // d
  0b01111001,    // E
  0b01110001     // F
void init_MS(void)
   output_high(STB_PIN); //ensure chip is deselected
   delay_us(1);
void display_block(int8 * disp_data, int8 brightness)
    int8 icnt;
    int8 dummy;
    //write block of display data to chip
    //all sixteen bytes sent
    output_low(STB_PIN);
    delay_us(1);
    //now need to set to send command to autowrite data
    spi_xfer(TM1638, AUTOINC, 8);
    spi_xfer(TM1638, ADDRESS_START, 8);
    //set to start at address 0xC0, and auto increment
    for (icnt=0;icnt<16;icnt++)
        dummy=spi_xfer(TM1638,*disp_data, 8); //send byte
        //using the read ensure write will complete each time before
        //returning.
        disp_data++;
    //Since I wait for the read each time, the STB can be raised immediately.
    //16 bytes sent
    delay_us(1); //minimum 1uSec
    //now command for brightness
    dummy=spi_xfer(TM1638, DISPLAY_ON | (brightness & 7), 8);
    delayus(1);
void read_keys(int8 * key_data)
    //read the keyboard data from the chip
    delay_us(1);
    //Now command to read data
    spi_xfer(TM1638, READKEY, 8);
    //Now read back keyboard
    for (cnt=0;cnt<4;cnt++)
        *key_data=spi_xfer(TM1638, 0, 8); //clock out dummy byte
        key_data++;
    delay_us(1);
    //Now need to switch back to write mode
    dummy=spi_xfer(TM1638, AUTOINC, 8);
    delay_us(1);
    int8 display_data[16]= {nn,nn.......nn,nn};
    //whatever you want to send to the display
    int8 key_data[4]; //key data returned
    init_MS();
    delay_ms(100); //just allow things to settle
    while (TRUE)
        display_block(display_data, 5);
        //Now the display data will have been written to the display
        //Last value here is brightness 0 to 7.
        read_keys(key_data);
        //Now 'key_data' will contain the key value read back. You
        //need to look at this, decide what you are going to do, and
        //update the data if required.
Now the data values you put into the 'display_data' array are the digits.
'digitToSegment' contains constant values for the standard digits.
So if you put digitToSegment[0] into display_data[0], it'd display '0'
for the first digit.
The key values returned are in reverse bit order.
Edited - just realised I had left 'key_data' being sent to the display routine
was originally going to combine the routines, but decided against this
had updated the routine itself, but not the call.
PostPosted: Thu Jan 03, 2019 8:15 am     Reply with quote
Mr. T has given you a GREAT starting point ! Just be sure to read the datasheet for YOUR display module. There are several 'variations' of them so you'll need to setup the 'configuration' as YOUR datasheet says.
Jay
Arsenic
PostPosted: Thu Jun 17, 2021 12:13 am     Reply with quote
I think this may help.
https://informatica-electronica.blogspot.com/2021/06/led-display-matrix-keypad-driver.html
This is the most recent piece of my code, you can control common anode displays with this added feature.
https://informatica-electronica.blogspot.com/2021/06/display-matrix-keypad-driver-pt.html
I hope you like it.
cobaltBlue
PostPosted: Sun Apr 21, 2024 3:16 am     Reply with quote
since a while, I'm using the TM1638 for controlling commen kathode quad 7-segments displays.
In case of common anode, I understand the hardware connections are different, ( have to 'reverse' grids and segments ) but do I need to change software?
Tnx in advance! Marcel
PostPosted: Sun Apr 21, 2024 5:06 am     Reply with quote
yes, I took a quik look at the datasheet and they show how for the digit '0'. I think it was on page #6....
Use that as a guide to create the 'table',each digit needs 5 bytes.
you'll have to send 5 bytes to the device instead on just one though.
cobaltBlue
PostPosted: Mon Apr 22, 2024 5:23 am     Reply with quote
Tnx,
that makes sence and gives me enough convidence!
I'm using mikroE's mikroPascal for AVR.
The common-kathode's work fine, I 'extracted' some code from a C-language ( I know barely C ) and use it in my pascal.
Have a bunch of common-anode's, gonna use them too!
Kind regards. Marcel
PostPosted: Mon Apr 22, 2024 5:26 am     Reply with quote
Er.
So why are you asking here then. This is a forum for CCS C on the PIC.
Not for Pascal, or the AVR. Go to a forum for these..... Sad
cobaltBlue
PostPosted: Mon Apr 22, 2024 5:29 am     Reply with quote
Ttelmah wrote:
Er.
Sorry, I wasn't aware, it was just a common question, don't mind the details.
Kind regards.
cobaltBlue
Temtronic, thanks again! Kind regards!
