E_Blue
printf with non printable characters |
Posted: Sun Dec 30, 2018 7:17 pm |
I need to send some variable fixed strings of about 15 to 25 bytes but I don't want to do this.
printf(LoadTX2,"%c%c%c%c%c%c%c%c%c%c",0x00,0x02,0x03,0x25,0x00,0x04,0x00,0x14,0x00,0x36);
Because I must to count how many bytes are to know how many %c I must to use.
Also, as you see, there's some null bytes so I think I can't use a string.
On the other hand I need to send a 24 Bit ID
int32 myID = 0x078090;
How I should add that variable to the printf? _________________ Electric Blue |
Posted: Sun Dec 30, 2018 7:30 pm |
Quote: | I need to send some variable fixed strings of about 15 to 25 bytes |
Put the bytes in an array and use putc() in a for() loop to send them.
Use sizeof on the array in the for() loop to get the number of bytes.
How I should add that variable to the printf? |
Use %lx to send it with printf. Or, tell us what format you want to
send it in. |
E_Blue
Posted: Sun Dec 30, 2018 7:39 pm |
I need to send the int32 0x078090 as literal bytes 0x07,0x80,0x90 not as ASCII string.
All this is a security protocol between two processors, so there's non ASCII printable characters.
As for the array, as far I understand, sizeof retrieves the size of the array not the actual byte count; so I guess I must to create a new variable for each string of bytes. Am I correct? _________________ Electric Blue |
Posted: Sun Dec 30, 2018 7:53 pm |
This would do it:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
int8 data[]= {0x00,0x02,0x03,0x25,0x00,0x04,0x00,0x14,0x00,0x36};
int8 i;
for(i=0; i < sizeof(data); i++)
putc(data[i]);
putc(myID >> 16);
putc(myID >> 8);
putc(myID);
while(TRUE);
E_Blue
Posted: Sun Dec 30, 2018 8:11 pm |
Thanks, that help me with a lots of doubts. _________________ Electric Blue |
